CDO and Boolean [message #45872] |
Tue, 22 August 2006 03:08  |
Hi all,
I tried to youse a Boolean field in my model.
If I read this field from db I get a classcast exception.
I use mysqldb.
Had anyone also this problem?
Chris
Re: CDO and Boolean [message #45936 is a reply to message #45872] |
Tue, 22 August 2006 03:31  |
Originally posted by: stepper.sympedia.de
Chris,
This problem has not been reported before.
If you have modified the model *after* it has been persisted once, you have to delete or edit the generated mapping file to reflect the changes.
In some cases (only adding new classes) this is sufficient and CDO will create the additional tables automatically.
If you have changed existing classes you have to adjust the existing tables as well.
Please open a Bugzilla, if you believe that this is an issue with CDO.
And don't forget to attach client and server logs.
Only with these I'm able to understand what happened.
Cheers
/Eike
Chris Lenz schrieb:
> Hi all,
> I use mysqldb.
> Chris
Re: CDO and Boolean [message #585846 is a reply to message #45872] |
Chris,
Cheers
/Eike
Chris Lenz schrieb:
> Hi all,
> I use mysqldb.
> Chris
FUDForum. Page generated in 0.04011 seconds
