Home » Eclipse Projects » Plugin Development Environment (PDE) » Why the Unpack the plug-in archive after the installation doesn't work?
Why the Unpack the plug-in archive after the installation doesn't work? [message #45869] Mon, 09 February 2009 09:52 Go to next message
Originally posted by: jiaoxw.css.com.cn
Hi All:
I followed the article http://www.vogella.de/articles/EclipsePDEBuild
/article.html,and successed in building my rcp with ant script。My rcp
has three plugins , all is .jar ,but I want it is a directory (becase
my rcp application will acess the conf file in the directory,it can't
find the file when it is a jar which puzzled me a lot. ) .
1) first problem : in the feature project,I selected "the Unpack the
plug-in archive
after the installation ",but it doesn't work.Can anybody tell me
why?And how can I get the three plugins in a single directory ?
2) the second : when I exe my rcp application,it displays in wrong
encoding ?How can I compile my rcp with <javac encoding="UTF-8",so I can
get the correct encode when I run my rcp application.
Any help would be greatly appreciated.
sunway.
Re: Why the Unpack the plug-in archive after the installation doesn't work? [message #46230 is a reply to message #45869] Tue, 10 February 2009 10:21 Go to previous messageGo to next message
sunway wrote:
> (becase my rcp application will acess the conf file in the directory,it can't
Are you not able to load the file from the bundle?
(Platform.getBundle("id").getResource("name")) Then you don't need a
folder to access the file.
Re: Why the Unpack the plug-in archive after the installation doesn't work? [message #46655 is a reply to message #46230] Wed, 11 February 2009 20:34 Go to previous message
于 2009-02-10 23:21, Matthias Kappeller 写道:
>> directory,it can't
I tryed this ,but it doesn't work.It seems that in 3.5 will solve this
problem? see this :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=157562,
http://eclipsesource.com/blogs/2009/01/20/tip-eclipse-bundle shape/
Re: Why the Unpack the plug-in archive after the installation doesn't work? [message #591748 is a reply to message #45869] Tue, 10 February 2009 10:21 Go to previous message
Re: Why the Unpack the plug-in archive after the installation doesn't work? [message #591890 is a reply to message #46230] Wed, 11 February 2009 20:34 Go to previous message
>> directory,it can't
problem? see this :
Previous Topic:OSGi running my own embedded Jetty, dependent plugins not starting?
Next Topic:Access Restrictions - How to get rid of these?
Current Time: Tue Jul 22 13:06:41 EDT 2025
Powered by FUDForum. Page generated in 0.06280 seconds
