Stable Build: S20040628 doesn't work [message #45798] |
Fri, 02 July 2004 08:39  |
I've installed all the pre-requisites and get this errors:
!ENTRY org.eclipse.core.runtime 4 2 jul 02, 2004 14:30:50.100
!MESSAGE Plug-in "org.eclipse.ve.java.core" was unable to instantiate
class "org.eclipse.ve.internal.java.core.JavaVEPlugin".
!STACK 0
java.lang.NoSuchMethodException:
org.eclipse.ve.internal.java.core.JavaVEPlugin.<init>(org.eclipse.core.runtime.IPluginDescriptor)
!ENTRY org.eclipse.osgi jul 02, 2004 14:30:50.116
!MESSAGE An error occured while automatically activating bundle
org.eclipse.ve.java.core (205).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.compatibility.PluginActivator.star t() of bundle
org.eclipse.ve.java.core.
Any hint will be greatly appreciated.
Which VE version is recommeneded for Eclipse 3.0?
Re: Stable Build: S20040628 doesn't work [message #45858 is a reply to message #45828] |
Fri, 02 July 2004 09:00  |
Thanks a lot!!!
It now works ok :-D
Jeff Myers wrote:
> Try removing the configuration directory in your eclipse directory and
> restarting. These sort of problems can occur with overriding plug-ins
> with the same version number... Eclipse doesn't understand that it needs
> to reinitialize them. Removing the configuration directory forces
> Eclipse to refresh its cached information about the installed plug-ins.
> - Jeff
> > !STACK 0
> > !STACK 0
Re: Stable Build: S20040628 doesn't work [message #593603 is a reply to message #45798] |
Fri, 02 July 2004 08:45  |
- Jeff
> !STACK 0
> !STACK 0
Re: Stable Build: S20040628 doesn't work [message #593617 is a reply to message #45828] |
Thanks a lot!!!
It now works ok :-D
> - Jeff
> > !STACK 0
> > !STACK 0
FUDForum. Page generated in 0.12150 seconds
