CVSNT: What is a "repository prefix"? [message #45778] |
Sat, 02 April 2005 15:45  |
Originally posted by: arstrube.web.de
I have just set up Eclipse to use CVSNT. Everything went fine up to the
point when I wanted to share my first project. Then Eclipse complains as
follows:
CVSNT repository ':pserver:arnd@NYMPHE:/CVS' is convigured to use a
repository prefix. However, ...<snip> The use of a repository prefix should
be disable if the full functionality of the Eclipse CVS client is desired.
[OK]
After this, 'Share Poject' appears to continue normally, but it looks like
it's not really added to the repository. At least, I get no context menu
option to add the contained files to the repository.
Question (1): What is a 'repository prefix'? I've looked all over Eclipse,
Eclipse help, CVSNT and its help and two fat tomes on Eclipse, but this term
is nowhere to be found.
Question (2): How do I know my project has been successfully shared? Why
can't I add files? It also doesn't show up in CVS perspective.
any help much appreciated,
Arnd
Re: CVSNT: What is a "repository prefix"? [message #46689 is a reply to message #46554] |
Mon, 04 April 2005 06:39  |
thank you, Adrian, that was the 'missing link'. I'd never have guessed that
this option was related ;-)
"Adrian Herscu" <bmf1972@axentra.net> wrote in message
news:d2r35d$n92$1@news.eclipse.org...
> If you use a new CVSNT (i.e. 2.x) then look at the CVS control
> panel under the compatibility tag and check the "Respond as cvs
> ... to version request" checkbox.
> > follows:
should
desired.
> > [OK]
like
Eclipse,
term
> > Arnd
FUDForum. Page generated in 0.31330 seconds
