null as value in OCL? [message #45753] |
Mon, 03 December 2007 15:51  |
I have an OCL semantics question.
How do I treat cases, where I want to return "null"?
And as a second question:
What is the result of
a.b
and
a.b.c
if "a" already results in oclUndefined?
Best Regards, Philipp
Re: null as value in OCL? [message #45783 is a reply to message #45753] |
Tue, 04 December 2007 09:50   |
Hi, Philipp,
OCL has a keyword for the literal null value (the "instance" of OclVoid):
null
So, null can be returned as a value for expressions of any type except a
Collection type, in which case an empty collection is more appropriate.
e.g.,
context Person
def: employerName : String =
if
self.employers->notEmpty()
then
self.employers->any(true).name
else
null
endif
Doing simply "self.employers->any(true).name" would result in OclInvalid
(see below) instead of null if there were no employers.
In your second question, if the value of a is null, then
a.b
results in OclInvalid (the singleton valud of the Invalid type, indicating
failed evaluation) and
a.b.c
also results in OclInvalid, as accessing features of OclInvalid is not
allowed, except to ask for .oclIsUndefined() or .oclIsInvalid().
HTH,
Christian
> a.b
> and
> a.b.c
Re: null as value in OCL? [message #46209 is a reply to message #45783] |
Mon, 10 December 2007 04:35   |
Hi, Christian.
This was very useful.
Thus I assume it is better to write
a = null
instead of
a.oclIsUndefined()
since the second would as well be true, if a is invalid.
Christian W. Damus wrote:
> Hi, Philipp,
> null
> e.g.,
> context Person
> if
> then
> else
> null
> endif
> a.b
> a.b.c
> HTH,
> Christian
>> a.b
>> and
>> a.b.c
Re: null as value in OCL? [message #46269 is a reply to message #46209] |
Mon, 10 December 2007 08:13  |
Hi, Philipp,
Yes, you raise a very good point. I can imagine that there might be cases
where this is an important distinction to make. Although, I'm not sure how
often that would arise. It's a bit like trying to account in your Java API
design for possible programming errors in client code (as signalled by
run-time exceptions); not usually worth the trouble.
Testing specifically for null might result in an attempt to use an
OclInvalid, unless you also test for a.oclIsInvalid().
cW
> Hi, Christian.
> a = null
> instead of
> a.oclIsUndefined()
-----8<-----
FUDForum. Page generated in 0.13240 seconds
