Home » Archived » Visual Editor (VE) » Problems with VE 1.0M1 when opening existing panel
Problems with VE 1.0M1 when opening existing panel [message #45738] Fri, 02 July 2004 07:44 Go to next message
When I try to open an existing Panel created with VE 0.5 and Eclipse 2.1
the following error happens:
An internal error occurred during: "Setup Java Visual Editor".
java.lang.IllegalAccessError: tried to access method
org.eclipse.pde.internal.core.WorkspaceModelManager.getWorks paceModel(Lorg/eclipse/core/resources/IProject;)Lorg/eclipse /pde/core/IModel;
from class org.eclipse.jem.internal.proxy.core.ProxyPlugin
org.eclipse.jem.internal.proxy.core.ProxyPlugin.processPlugi n(ProxyPlugin.java:767)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.expandProjec t(ProxyPlugin.java:762)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.getIDsFound( ProxyPlugin.java:716)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:321)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:259)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createProxyFactoryRegistry(JavaVisualEditorPart.jav a:942)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initializeForProject(JavaVisualEditorPart.jav a:1460)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initialize(JavaVisualEditorPart.java:1341)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1255)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
I'm using GEF 3.0, emf-runtime-I200403250631, VE-runtime-1.0M1
This stops me to migrate to Eclipse 3.0 from Eclipse 2.1.
Any help will be greatly appreciated.
Re: Problems with VE 1.0M1 when opening existing panel [message #45768 is a reply to message #45738] Fri, 02 July 2004 08:36 Go to previous message
VE-runtime-1.0M1 will NOT run on Eclipse 3.0. Use the latest stable
build of VE instead -
http://downloads.eclipse.org/tools/ve/downloads/index.php
Currently the latest stable build is S20040628.
- Jeff
Re: Problems with VE 1.0M1 when opening existing panel [message #593569 is a reply to message #45738] Fri, 02 July 2004 08:36 Go to previous message
- Jeff
Previous Topic:Problems with VE 1.0M1 when opening existing panel
Next Topic:Stable Build: S20040628 doesn't work
Current Time: Fri May 09 01:38:40 EDT 2025
Powered by FUDForum. Page generated in 0.02970 seconds
