Problems with VE 1.0M1 when opening existing panel [message #45738] |
Fri, 02 July 2004 07:44  |
When I try to open an existing Panel created with VE 0.5 and Eclipse 2.1
the following error happens:
An internal error occurred during: "Setup Java Visual Editor".
java.lang.IllegalAccessError: tried to access method
org.eclipse.pde.internal.core.WorkspaceModelManager.getWorks paceModel(Lorg/eclipse/core/resources/IProject;)Lorg/eclipse /pde/core/IModel;
from class org.eclipse.jem.internal.proxy.core.ProxyPlugin
org.eclipse.jem.internal.proxy.core.ProxyPlugin.processPlugi n(ProxyPlugin.java:767)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.expandProjec t(ProxyPlugin.java:762)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.getIDsFound( ProxyPlugin.java:716)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:321)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:259)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createProxyFactoryRegistry(JavaVisualEditorPart.jav a:942)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initializeForProject(JavaVisualEditorPart.jav a:1460)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initialize(JavaVisualEditorPart.java:1341)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1255)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
I'm using GEF 3.0, emf-runtime-I200403250631, VE-runtime-1.0M1
This stops me to migrate to Eclipse 3.0 from Eclipse 2.1.
Any help will be greatly appreciated.
FUDForum. Page generated in 0.03799 seconds
