Need help in Profiling project Remotely [message #45683] |
Fri, 09 December 2005 07:30  |
Originally posted by: vinaykumarkv.gmail.com
Hi group,
I have one query. Can i profile my project Remotely using TPTP.
My project consits of JSPs,Servlets and EJBs it will run using Jboss App
server (jboss-3.2.1_tomcat-4.1.24).
I just want to profile my project. In search i found eclipse profiler from
sourceforge will do something.
Can TPTP also profile Remotely?
If so Pls provide me related suff. so that it will be useful for me.
Thanks in advance.
regards,
Vinay
Re: Need help in Profiling project Remotely [message #45713 is a reply to message #45683] |
Fri, 09 December 2005 09:42  |
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 0050C4D9852570D2_=
Content-Type: text/plain; charset="US-ASCII"
Yes, TPTP supports remote profiling on nine different platforms. All you
have to do is start the Agent Controller on the target machine. After
that, you can connect to the machine and start profiling using your
workbench. Please see the Getting started with Agent Controller document
posted under the Installation and Getting Started Guides category of
http://www.eclipse.org/tptp/home/documents/index.html
For an introductory document on the profiler, you can either check out
Eclipse's help file or the following document:
http://www.eclipse.org/tptp/home/documents/tutorials/profili ngtool/profilingexample_32.html
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Yes, TPTP supports remote profiling
on nine different platforms. All you have to do is start the Agent
Controller on the target machine. After that, you can connect to
the machine and start profiling using your workbench. Please see
the Getting started with Agent Controller document posted under the Installation
and Getting Started Guides category of http://www.eclipse.org/tptp/home/documents/index.html</font>
<br>
<br><font size=2 face="sans-serif">For an introductory document on the
profiler, you can either check out Eclipse's help file or the following
document: http://www.eclipse.org/tptp/home/documents/tutorials/profili ngtool/profilingexample_32.html</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 0050C4D9852570D2_=--
FUDForum. Page generated in 0.30973 seconds
