Strange compile Error [message #4008] |
Mon, 17 January 2005 17:03  |
Originally posted by: zsolt.mailblocks.com
Eclipse gives me the following syntax error:
Syntax error, insert ";" to complete Statement
This is followed by
Syntax error, insert "AssignmentOperator ArrayInitializer" to complete
Expression
The problem is, my java compiler compiles this just fine.
Has anyone run into this before?
Maybe I need the new version of eclipse because this version does not
recognize the "assert" keyword? The only problem is I just downloaded
this version not too long ago.
___________________
Eclipse Platform
Version: 3.0.1
Build id: 200409161125
External java compiler
java version "1.4.1_07"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.1_07-b02)
Java HotSpot(TM) Client VM (build 1.4.1_07-b02, mixed mode)
Re: Strange compile Error [message #4016 is a reply to message #4008] |
Mon, 17 January 2005 17:08  |
Please disregard this request. It turns out "Build Automatically" was
accidentally turned off and this was a lingering error as a result.
Zsolt Szabo wrote:
> Cheers,
> This is followed by
> Expression
> ___________________
> Eclipse Platform
> Version: 3.0.1
FUDForum. Page generated in 0.14023 seconds
