Home » Archived » BIRT » PDF Output and unordered lists
PDF Output and unordered lists [message #45646] Tue, 14 June 2005 11:02
Originally posted by: itsupport.millwood.uk.com
Hi All
I have an unordered list in my text box, and when I try to generate pdf
output it gives this error in the logs:
SEVERE: fo2pdf failed
org.apache.fop.apps.FOPException: The element type "fo:list-block" must be
terminated by the matching end-tag "</fo:list-block>".
The text box that contains the unordered lists is:
<BR>
<B>Visits during working hours</B> <BR>
<BR>
<UL><LI>Always let the site manager or sales staff know you are on
site.</LI>
<LI>If you are going into a construction area please wait until someone can
accompany you.</LI>
<LI>Please use safety helmets if you are asked to do so.</LI>
</UL>
<BR>
<B>Visits outside of working hours</B><BR>
<BR>
<UL><LI>If the sales office staff do not have keys to your property, or it
is inside a fenced area, then it should only be visited during working
hours.</LI>
<LI>Do not go into any fenced off areas, even if the gates are open.</LI>
<LI>Never go into any property which has scaffolding erected around it.</LI>
</UL>
<BR>
I have reviewed it a couple of times and it appears to be correct.
Is this a bug?
James
Previous Topic:Problem with design file
Next Topic:IRunAndRenderTask
Current Time: Tue Jul 22 13:02:20 EDT 2025
Powered by FUDForum. Page generated in 0.06261 seconds
