Home » Language IDEs » AspectJ » Lastest AJDT with older versions of AspectJ?
Lastest AJDT with older versions of AspectJ? [message #45638] Fri, 07 January 2005 10:10 Go to next message
Is it possible to use the lastest versions of AJDT with older versions of
AspectJ? I'm on a project that uses an older version of AspectJ with a few
modifications added in. However, I'd like to use Eclipse 3.1M4 as my IDE.
This would require the latest version of AJDT.
Scott
Re: Lastest AJDT with older versions of AspectJ? [message #45668 is a reply to message #45638] Fri, 07 January 2005 10:34 Go to previous messageGo to next message
Originally posted by: clemas.uk.ibm.com
> of AspectJ? I'm on a project that uses an older version of AspectJ with
> a few modifications added in. However, I'd like to use Eclipse 3.1M4 as
> my IDE. This would require the latest version of AJDT.
> Scott
Unfortunately, I don't think it will be possible. We have been making
changes in the interfaces between AspectJ and AJDT to give better
integration and your older AspectJ won't have those changes in.
It is *possible*, depending on where your changes are, that you could
patch up the aspectj (with a jar -uvf) in AJDT to include them but I'd
need more details on what your modifications are to confirm whether it
is worth trying that.
AJDT for 3.1M4 uses the recent AspectJ 1.5.0M1 build. How old is the
AspectJ you are using? Is it a modified 1.2.1?
cheers,
Andy.
Andy Clement
AspectJ Committer
Re: Lastest AJDT with older versions of AspectJ? [message #45696 is a reply to message #45668] Fri, 07 January 2005 10:39 Go to previous message
That is what I figured but it was worth a shot. Our version is based off
of 1.2.0 and was built back in October. We are going to upgrade it at some
point but I was hoping I could find an alternative until then.
>> versions of AspectJ? I'm on a project that uses an older version of
>> AspectJ with a few modifications added in. However, I'd like to use
>> Eclipse 3.1M4 as my IDE. This would require the latest version of
>> AJDT.
>> Scott
> cheers,
> Andy.
> Andy Clement
> AspectJ Committer
Re: Lastest AJDT with older versions of AspectJ? [message #585616 is a reply to message #45638] Fri, 07 January 2005 10:34 Go to previous message
> Scott
cheers,
Andy.
Andy Clement
AspectJ Committer
Re: Lastest AJDT with older versions of AspectJ? [message #585621 is a reply to message #45668] Fri, 07 January 2005 10:39 Go to previous message
>> AJDT.
>> Scott
> cheers,
> Andy.
> Andy Clement
> AspectJ Committer
Previous Topic:Lastest AJDT with older versions of AspectJ?
Next Topic:Visualizer
Current Time: Sun Jul 27 12:39:20 EDT 2025
Powered by FUDForum. Page generated in 0.04158 seconds
