Lastest AJDT with older versions of AspectJ? [message #45638] |
Fri, 07 January 2005 10:10  |
Is it possible to use the lastest versions of AJDT with older versions of
AspectJ? I'm on a project that uses an older version of AspectJ with a few
modifications added in. However, I'd like to use Eclipse 3.1M4 as my IDE.
This would require the latest version of AJDT.
Scott
Re: Lastest AJDT with older versions of AspectJ? [message #45696 is a reply to message #45668] |
Fri, 07 January 2005 10:39  |
That is what I figured but it was worth a shot. Our version is based off
of 1.2.0 and was built back in October. We are going to upgrade it at some
point but I was hoping I could find an alternative until then.
>> versions of AspectJ? I'm on a project that uses an older version of
>> AspectJ with a few modifications added in. However, I'd like to use
>> Eclipse 3.1M4 as my IDE. This would require the latest version of
>> AJDT.
>> Scott
> Unfortunately, I don't think it will be possible. We have been making
> changes in the interfaces between AspectJ and AJDT to give better
> integration and your older AspectJ won't have those changes in.
> It is *possible*, depending on where your changes are, that you could
> patch up the aspectj (with a jar -uvf) in AJDT to include them but I'd
> need more details on what your modifications are to confirm whether it
> is worth trying that.
> AJDT for 3.1M4 uses the recent AspectJ 1.5.0M1 build. How old is the
> AspectJ you are using? Is it a modified 1.2.1?
> cheers,
> Andy.
> Andy Clement
> AspectJ Committer
Re: Lastest AJDT with older versions of AspectJ? [message #585616 is a reply to message #45638] |
Fri, 07 January 2005 10:34  |
> of AspectJ? I'm on a project that uses an older version of AspectJ with
> a few modifications added in. However, I'd like to use Eclipse 3.1M4 as
> my IDE. This would require the latest version of AJDT.
> Scott
cheers,
Andy.
Andy Clement
AspectJ Committer
Re: Lastest AJDT with older versions of AspectJ? [message #585621 is a reply to message #45668] |
>> AJDT.
>> Scott
> cheers,
> Andy.
> Andy Clement
> AspectJ Committer
FUDForum. Page generated in 0.03384 seconds
