Re: Example for Provide and Register for parent doc relationship RPLC [message #45693 is a reply to message #45663] |
Thu, 14 August 2008 15:08  |
Mesa 11940
org.eclipse.ohf.ihe.xds.consumer\src_tests\org\eclipse\ohf\i he\xds\consumer\test\mesa
part 1 = XDS.a and part 2 = xds.b (in terms of code execution .. though
the resultant on-the-wire-message is identical)
hope this helps,
- Sarah
Frank wrote:
> Thanks, that helped. Is there a Consumer example that uses a query
> based on the UUID for the document?
> Frank
> Sarah Knoop wrote:
>> Check out the MESA JUNIT test in the xds.source - 11748 (this is the
>> replace example). Switching all debug loggin on, should print the
>> ebXML to the screen (if this is what you are after).
>> This test is for XDS.a -- but XDS.b api is virtually identical.
>> - Sarah
>> Frank wrote:
>>> Is there a example in the OHF test code for provide and register a
>>> document for the parent document relationship RPLC?
>>> Thanks,
>>> Frank
Re: Example for Provide and Register for parent doc relationship RPLC [message #586717 is a reply to message #45563] |
Tue, 12 August 2008 12:29  |
replace example). Switching all debug loggin on, should print the ebXML
- Sarah
> Frank
Re: Example for Provide and Register for parent doc relationship RPLC [message #586731 is a reply to message #45633] |
Wed, 13 August 2008 18:33  |
Frank
> - Sarah
>> Thanks,
>> Frank
Re: Example for Provide and Register for parent doc relationship RPLC [message #586743 is a reply to message #45663] |
Mesa 11940
hope this helps,
- Sarah
> Frank
>> - Sarah
>>> Thanks,
>>> Frank
FUDForum. Page generated in 0.27454 seconds
