Home » Archived » OHF » Example for Provide and Register for parent doc relationship RPLC
Example for Provide and Register for parent doc relationship RPLC [message #45563] Mon, 11 August 2008 17:10 Go to next message
Originally posted by: frank.frederick.mckesson.com
Is there a example in the OHF test code for provide and register a
document for the parent document relationship RPLC?
Frank
Re: Example for Provide and Register for parent doc relationship RPLC [message #45633 is a reply to message #45563] Tue, 12 August 2008 12:29 Go to previous messageGo to next message
Check out the MESA JUNIT test in the xds.source - 11748 (this is the
replace example). Switching all debug loggin on, should print the ebXML
to the screen (if this is what you are after).
This test is for XDS.a -- but XDS.b api is virtually identical.
- Sarah
> Frank
Re: Example for Provide and Register for parent doc relationship RPLC [message #45663 is a reply to message #45633] Wed, 13 August 2008 18:33 Go to previous messageGo to next message
Thanks, that helped. Is there a Consumer example that uses a query
based on the UUID for the document?
Frank
> - Sarah
>> Thanks,
>> Frank
Re: Example for Provide and Register for parent doc relationship RPLC [message #45693 is a reply to message #45663] Thu, 14 August 2008 15:08 Go to previous message
Mesa 11940
org.eclipse.ohf.ihe.xds.consumer\src_tests\org\eclipse\ohf\i he\xds\consumer\test\mesa
part 1 = XDS.a and part 2 = xds.b (in terms of code execution .. though
the resultant on-the-wire-message is identical)
hope this helps,
- Sarah
> Frank
>> ebXML to the screen (if this is what you are after).
>> - Sarah
>>> Thanks,
>>> Frank
Re: Example for Provide and Register for parent doc relationship RPLC [message #586717 is a reply to message #45563] Tue, 12 August 2008 12:29 Go to previous message
- Sarah
> Frank
Re: Example for Provide and Register for parent doc relationship RPLC [message #586731 is a reply to message #45633] Wed, 13 August 2008 18:33 Go to previous message
Frank
> - Sarah
>> Thanks,
>> Frank
Re: Example for Provide and Register for parent doc relationship RPLC [message #586743 is a reply to message #45663] Thu, 14 August 2008 15:08 Go to previous message
Mesa 11940
hope this helps,
- Sarah
> Frank
>> - Sarah
>>> Thanks,
>>> Frank
Previous Topic:Test11710 XDS.A soap sender Errors
Next Topic:XDS XDR Help
Current Time: Thu Jul 17 22:26:13 EDT 2025
Powered by FUDForum. Page generated in 0.30450 seconds
