Survey on Understanding Code [message #451926] |
Fri, 11 March 2005 04:13 |
We are running a set of small surveys, in an attempt to understand
developers problems when attempting to understand code. Results from
this survey will be used in refining (open-source) tools that we are
building.
If you have looked at the code of any of the projects below, we would
appreciate you taking a few minutes to fill out as many of the
respective surveys: SWT/JFace/Workbench, GEF, EMF, RCP, JDT-Core, (Text)
Editor Framework, and Platform.
The survey can be found at:
http://people.csail.mit.edu/people/vineet/pc_eclipse.html
Please contact me if you have any questions, concerns, or comments!
Thanks!!
Vineet Sinha
vineet@csail.mit.edu
PS: If this is not an appropriate place for posting this message, I will
appreciate a pointer to the appropriate locations - Thanks!
FUDForum. Page generated in 0.03976 seconds
