problems with jet editor and some emf/jet1 include files [message #45527] |
Thu, 15 May 2008 02:49  |
Dear All
I am using the jet editor to edit some jet files. However, in some cases
specifically incude files I am getting an error on load
here is an example file
<%for (GenFeature genFeature : genClass.getDeclaredGenFeatures()) {
String xxxx_featureType = "unknown";
Object xxxx_ecoreFeature = genFeature.getEcoreFeature();
xxxx_featureType = xxxx_ecoreFeature instanceof
org.eclipse.emf.ecore.EAttribute ? "attribute" : xxxx_featureType;
org.eclipse.emf.ecore.EReference ? "role" : xxxx_featureType;
* String constant for <%=xxxx_featureType%> <%=genFeature.getName()%>
* @generated
public static final String <%=genFeature.getUpperName()%> =
"<%=genFeature.getName()%>";
<%for (org.eclipse.emf.ecore.EAnnotation xxxx_annotation:
genClass.getEcoreModelElement().getEAnnotations()) {
if
(xxxx_annotation.getSource().equals("http://www.leeds.ac.uk/xxxx-ecore-1.0/xxxx_genmodel"))
org.eclipse.emf.ecore.EAnnotation xxxx_staticAnnotation =
xxxx_annotation.getEAnnotation("static");
if (xxxx_staticAnnotation != null) {
String xxxx_staticModifiers = (String)
xxxx_staticAnnotation.getDetails().get("modifiers");
String xxxx_staticName = (String)
xxxx_staticAnnotation.getDetails().get("name");
String xxxx_staticType = (String)
xxxx_staticAnnotation.getDetails().get("type");
String xxxx_staticDefault = (String)
xxxx_staticAnnotation.getDetails().get("default");
// todo improve type handling...
if (! xxxx_staticType.equals("ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EString")) {
throw new RuntimeException("unexpected non string
type for xxxx static: " + xxxx_staticType);
// todo add alternative for object
// todo add documentation handler
* todo add documentation code
* @generated
<%=xxxx_staticModifiers%> String <%=xxxx_staticName%> =
"<%=xxxx_staticDefault%>";
and the stack trace
org.eclipse.core.runtime.AssertionFailedException: assertion failed:
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:111)
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:97)
at org.eclipse.jface.text.Position.<init>(Position.java:62)
org.eclipse.jet.internal.editor.JETTextEditor$PositionsColle ctor.matchOffset(JETTextEditor.java:439)
org.eclipse.jet.internal.editor.JETTextEditor$PositionsColle ctor.visit(JETTextEditor.java:416)
org.eclipse.jet.core.parser.ast.JavaScriptlet.accept0(JavaSc riptlet.java:54)
org.eclipse.jet.core.parser.ast.JETASTElement.accept(JETASTE lement.java:105)
org.eclipse.jet.core.parser.ast.JETCompilationUnit.accept0(J ETCompilationUnit.java:128)
org.eclipse.jet.internal.editor.JETTextEditor.requestCompila tionUnit(JETTextEditor.java:301)
org.eclipse.jet.internal.editor.JETTextEditor.getASTElement( JETTextEditor.java:309)
org.eclipse.jet.internal.editor.rules.ASTElementScannerRule. evaluate(ASTElementScannerRule.java:39)
org.eclipse.jet.internal.editor.rules.ASTElementScannerRule. evaluate(ASTElementScannerRule.java:33)
org.eclipse.jface.text.rules.RuleBasedScanner.nextToken(Rule BasedScanner.java:174)
org.eclipse.jface.text.rules.RuleBasedPartitionScanner.nextT oken(RuleBasedPartitionScanner.java:79)
org.eclipse.jface.text.rules.FastPartitioner.initialize(Fast Partitioner.java:166)
org.eclipse.jface.text.rules.FastPartitioner.checkInitializa tion(FastPartitioner.java:151)
org.eclipse.jface.text.rules.FastPartitioner.connect(FastPar titioner.java:143)
org.eclipse.jface.text.rules.FastPartitioner.connect(FastPar titioner.java:125)
org.eclipse.jet.internal.editor.configuration.JETDocumentPro vider.createDocument(JETDocumentProvider.java:45)
org.eclipse.ui.editors.text.FileDocumentProvider.createEleme ntInfo(FileDocumentProvider.java:734)
org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(A bstractDocumentProvider.java:398)
org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:3989)
org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:190)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1325)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor .java:165)
org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3024)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:444)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:352)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2476)
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3042)
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3069)
org.eclipse.jet.internal.editor.JETTextEditor.init(JETTextEd itor.java:134)
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:799)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1410)
org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:944)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:132)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3375)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3033)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1365)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2305)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 10)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:494)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:489)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:112)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
regards
gary
nb if anyone has any thoughts on my previous post 'jet editor java syntax
coloring' (forwarded to the correct place by Ed Merks, thanks!) I would
still love to solve it ;-)
FUDForum. Page generated in 0.05123 seconds
