Home » Archived » Memory Analyzer (MAT) » error report
error report [message #3992] Tue, 02 September 2008 18:06
Running 08-08-2008 distribution package.
Not sure I can reproduce, but I can try in case the stacktrace below
doesn't contain enough information to fix the problem.
eclipse.buildId=unknown
java.version=1.5.0_16
Command-line arguments: -os win32 -ws win32 -arch x86
Error
Wed Sep 03 00:02:54 CEST 2008
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
org.eclipse.mat.ui.snapshot.views.inspector.FieldsLabelProvi der.getObjectLabel(FieldsLabelProvider.java:98)
org.eclipse.mat.ui.snapshot.views.inspector.FieldsLabelProvi der.getColumnText(FieldsLabelProvider.java:86)
org.eclipse.jface.viewers.TableColumnViewerLabelProvider.upd ate(TableColumnViewerLabelProvider.java:70)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:145)
org.eclipse.jface.viewers.AbstractTableViewer.doUpdateItem(A bstractTableViewer.java:386)
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:466)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2041)
org.eclipse.jface.viewers.AbstractTableViewer.internalRefres hAll(AbstractTableViewer.java:736)
org.eclipse.jface.viewers.AbstractTableViewer.internalRefres h(AbstractTableViewer.java:633)
org.eclipse.jface.viewers.AbstractTableViewer.internalRefres h(AbstractTableViewer.java:620)
org.eclipse.jface.viewers.AbstractTableViewer$2.run(Abstract TableViewer.java:576)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1365)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1328)
org.eclipse.jface.viewers.AbstractTableViewer.inputChanged(A bstractTableViewer.java:574)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:251)
org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1603)
org.eclipse.mat.ui.snapshot.views.inspector.InspectorView$7$ 1.run(InspectorView.java:673)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at org.eclipse.mat.ui.rcp.Application.start(Application.java:26 )
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
Previous Topic:help to interpret results
Next Topic:Huge heap dump files - takes hours to parse
Current Time: Tue Jul 22 09:01:53 EDT 2025
Powered by FUDForum. Page generated in 0.03997 seconds
