Home » Archived » BIRT » Standalone without view
Standalone without view [message #45496] Mon, 13 June 2005 19:56 Go to next message
I've gotten birt to run standalone and generate pdfs, but I've had trouble
getting fop to -ps print to a network printer which fop is supposedly
capable of. It comes down to a classcast exception when rendering block
areas. So....
What other options/best practices are there for autoprinting reports to a
given printer?
Joe
Re: Standalone without view [message #47191 is a reply to message #45496] Thu, 16 June 2005 11:16 Go to previous messageGo to next message
Has anyone used birt to generate and automatically print reports?
How did you do it?
Joe
"Joe Rybacki" <Joe.Rybacki@dynetics.com> wrote in message
news:d8l6f1$34u$1@news.eclipse.org...
> areas. So....
> given printer?
> Joe
Re: Standalone without view [message #47222 is a reply to message #45496] Thu, 16 June 2005 11:29 Go to previous message
I've also been down the path of trying to use GhostScript and gsprint to
silently print, but when trying to open the file in ghostscript i get the
exception included below. So for now all I have is a "hack" to open
acrobat 5.0 and print then kill it. Are there any plans to support printing
via fop, or other means?
Scanning PDF file
**** Warning: An error occurred while reading an XREF table.
**** The file has been damaged. This may have been caused
**** by a problem while converting or transfering the file.
**** Ghostscript will attempt to recover the data.
Error: /invalidaccess in --setfileposition--
Operand stack:
post_eof_count --nostringval-- 0
Execution stack:
%interp_exit
..runexec2 --nostringval-- --nostringval-- --nostringval-- 2
%stopped_push --nostringval-- --nostringval-- false 1
%stopped_push 1 3 %oparray_pop 1 3 %oparray_pop 1 3
%stopped_push --nostringval-- --nostringval-- --nostringval-- --nostringval--
Dictionary stack:
--dict:1129/1686(ro)(G)-- --dict:0/20(G)-- --dict:79/200(L)-- --dict:105/127(ro)(G)--
--dict:251/347(ro)(G)-- --dict:18/24(L)--
Current allocation mode is local
> areas. So....
> given printer?
> Joe
Previous Topic:BIRT Integration
Next Topic:odaconsumer.CannotGetColumnCount
Current Time: Fri Jul 04 18:53:40 EDT 2025
Powered by FUDForum. Page generated in 0.04861 seconds
