Home » Eclipse Projects » Technology Project and PMC » how to set up Eclipse & JBoss to hotswap
how to set up Eclipse & JBoss to hotswap [message #45485] Tue, 11 February 2003 03:18 Go to next message
Originally posted by: please_do_not_reply.hotmail.com
I'm using Eclipse with Tomcat (using the Tomcat plugin) and I'm curious how
to set it up to use JBoss so I can add a Session Bean to my project. With
tomcat I have tomcat use the WEB-INF directory under my project. But with
JBoss it needs to be under the JBoss directory. If I could tell JBoss that
my server directory was my project directory it'd be a piece of cake but
JBoss can't do this.
Re: how to set up Eclipse & JBoss to hotswap [message #45582 is a reply to message #45485] Tue, 11 February 2003 08:01 Go to previous messageGo to next message
I found the JBoss-IDE "plugin" for Eclipse and installed that. It starts
and stops the server, other than that it doesn't do much that the EASIE
plugin from Genuitec does. Now the only "problem" is that every time I
recompile an object that I deploy to JBoss, I have to run an ANT target to
copy the files to the jboss server/deploy directory. It'd be great if this
last step could be eliminated. Some ideas:
1) Make the eclipse project within the JBoss folder and set the output path
to be inside the server/deploy dir
2) Modify JBoss so that a server directory can reside outside the JBoss
hierarchy (and inside the eclipse project)
I'm curious if anyone has any ideas on this.
Michael
Re: how to set up Eclipse & JBoss to hotswap [message #45612 is a reply to message #45582] Tue, 11 February 2003 08:22 Go to previous messageGo to next message
Originally posted by: sten.mindware.se
I believe you can set the project output folder to be a link to the JBoss
server/deploy folder in Eclipse 2.1 (M4).
Sten
"Michael" <please_do_not_reply@hotmail.com> skrev i meddelandet
news:b2aqng$pf5$1@rogue.oti.com...
this
path
> Michael
Re: how to set up Eclipse & JBoss to hotswap [message #45729 is a reply to message #45612] Tue, 11 February 2003 10:21 Go to previous messageGo to next message
You're correct, this is a new feature since Eclipse 2.0 (I believe, never
noticed it before).
I actually took the opposite approach, I downloaded a win32 app called
"junction" to make a symbolic link from the jboss/server/deploy directory to
my project/deploy directory. That way I can better manage the
configurations and stuff. So far it's working great.
"Sten Rosendahl" <sten@mindware.se> wrote in message
news:b2arvk$qdu$1@rogue.oti.com...
> Sten
starts
to
> this
> path
> > Michael
Re: how to set up Eclipse & JBoss to hotswap [message #45759 is a reply to message #45582] Tue, 11 February 2003 10:58 Go to previous messageGo to next message
The JBoss-IDE mods to Eclipse broke the refactoring so I had to uninstall it
and go back to EASIE which works just fine. I heard that soon the JBoss-IDE
will integrate nicely with Eclipse (now it's a hack) so hopefully this
problem will go away.
"Michael" <please_do_not_reply@hotmail.com> wrote in message
this
path
> Michael
Re: how to set up Eclipse & JBoss to hotswap [message #46752 is a reply to message #45729] Fri, 21 February 2003 07:26 Go to previous messageGo to next message
Originally posted by: vedsr.hotmail.com
we were using jboss and easie plug-in. it does hot deploy automatically. we
did not need to configure anything. Hot deploy work with jdk 1.4.1. Right?
It is a feature of the JVM.
news:b2b2v4$rr$1@rogue.oti.com...
> noticed it before).
to
JBoss
> > Sten
> starts
EASIE
I
target
> to
> > this
> > path
JBoss
> > > Michael
Re: how to set up Eclipse & JBoss to hotswap [message #46841 is a reply to message #45582] Sun, 23 February 2003 14:48 Go to previous message
Previously I have configured JBoss to look into my Eclipse project's output
directory for an exploded EAR structure. As I recall it worked fairly well.
Wayne
this
path
> Michael
Re: how to set up Eclipse & JBoss to hotswap [message #590113 is a reply to message #45485] Tue, 11 February 2003 08:01 Go to previous message
Michael
Re: how to set up Eclipse & JBoss to hotswap [message #590124 is a reply to message #45582] Tue, 11 February 2003 08:22 Go to previous message
Sten
this
path
> Michael
Re: how to set up Eclipse & JBoss to hotswap [message #590169 is a reply to message #45612] Tue, 11 February 2003 10:21 Go to previous message
noticed it before).
> Sten
starts
to
> this
> path
> > Michael
Re: how to set up Eclipse & JBoss to hotswap [message #590181 is a reply to message #45582] Tue, 11 February 2003 10:58 Go to previous message
this
path
> Michael
Re: how to set up Eclipse & JBoss to hotswap [message #590693 is a reply to message #45729] Fri, 21 February 2003 07:26 Go to previous message
> noticed it before).
to
JBoss
> > Sten
> starts
EASIE
I
target
> to
> > this
> > path
JBoss
> > > Michael
Re: how to set up Eclipse & JBoss to hotswap [message #590720 is a reply to message #45582] Sun, 23 February 2003 14:48 Go to previous message
Wayne
this
path
> Michael
Previous Topic:weblogic can't stat up correctly
Next Topic:"unexpected end of file" build error
Current Time: Mon Jul 21 21:25:36 EDT 2025
Powered by FUDForum. Page generated in 0.50250 seconds
