Home » Eclipse Projects » Eclipse Platform » some problem in getting a file from Project or some Folder
some problem in getting a file from Project or some Folder [message #45453] Fri, 23 May 2003 09:04 Go to next message
I have some simple problem.Hope I am doing something wrong.
I can not get a resource( file ) from a Project.
Here is what I am doing:
-I have project "test".in that I have a folder "test" in whihc I have
test.txt.
-I opened the project
-And want to open the file in that. But i can not do it. Always I am getting
exception."file does not exists"..Please help me.
here is the sample code that I am doing.//ofcourse its just a test
Please see my comments as java comments in the sample code.
IWorkspace workspace = ResourcesPlugin.getWorkspace();
IWorkspaceRoot root = workspace.getRoot(); //
IProject[] ps = root.getProjects();
String str = ps[0].getName();//Just for test.
IProject myWebProject = root.getProject(str);//My test does not work. Here I
get always only one project Desktop.//so using this Desktop project only for
doing test
// I copied my text.txt in Desktop project(For doing test.)
boolean pExists =myWebProject.exists();boolean isOpen =
myWebProject.isOpen();
if ( pExists && !isOpen)
myWebProject.open(null);
IFolder folder = myWebProject.getFolder("test");
IFile file= folder.getFile("tst.txt");
boolean fileExists = file.exists();//always returns false..
I tried somany cases but none is working.Please help me.I am doing something
wrong.But I couldn't figure it out.
Ramana
Re: some problem in getting a file from Project or some Folder [message #46192 is a reply to message #45453] Fri, 23 May 2003 11:46 Go to previous messageGo to next message
1. Have u copied the folder and file under ur desktop project.
2. The file name specified is tst.txt.. .Do u have test.txt / tst.txt.
IProject project = workspace.getRoot().getProject("Test");
IFolder folder = project.getFolder("test");
IFile file = folder.getFile("test.txt");
HTH
~B
"jelda" <j_jvr@yahoo.com> wrote in message
news:bal69e$il4$1@rogue.oti.com...
> test.txt.
getting
I
for
> doing test
something
> Ramana
Re: some problem in getting a file from Project or some Folder [message #47797 is a reply to message #46192] Mon, 26 May 2003 04:37 Go to previous message
It is tst.txt.
While typing it to forum. I did small mistake.
So its not question of file names. Its the question of how to program it.
I checked the file name and path. its no dobut that I wrote correctly in my
program.
I did tests with so many other files also..
I personally writing a plugin for eclipse. I wrote this code in plugin
implementaion. is this could be wrong?
Thanks in advance,
Ramana
"Balaji" <balajik@us.ibm.com> schrieb im Newsbeitrag
news:balfre$s2h$1@rogue.oti.com...
> HTH
> ~B
> > Hi,
> > test.txt.
> getting
Here
> I
> for
> > doing test
> something
> > Ramana
Previous Topic:[ANN] Eclipse key bindings (pdf,doc) emacs/standard
Next Topic:[CVS] modify multiple branches
Current Time: Sun Aug 31 00:58:18 EDT 2025
Powered by FUDForum. Page generated in 0.03757 seconds
