NPE during schema validation [message #45440] |
Tue, 25 May 2004 10:41  |
I'm putting together some testcases for an XSD based project I'm working
on when I hit a NullPointerException validating a somewhat contrived
schema. I'm not even certain that the schema is valid, but if it isn't I
would have thought that there would be a more meaningful diagnostic than
an NPE so I figured I'd raise it with you guys to see what you think.
Here's my schema:
<schema targetNamespace="http://com/schemas/ACTDIInterface"
xmlns="http://www.w3.org/2001/XMLSchema"
xmlns:xsd1="http://com/schemas/ACTDIInterface">
<complexType name="CAType">
<sequence>
<element name="el1" type="xsd1:typeRef"/>
</sequence>
</complexType>
<simpleType name="typeRef">
<restriction base="string"/>
</simpleType>
<element name="CA" substitutionGroup="xsd1:CA2" abstract="false"
final="#all"/>
<element name="CA2" ref="xsd1:CA3" abstract="false" />
<element name="CA3" type="xsd1:CAType" abstract="false" />
</schema>
The problem seems to be related to element CA which has a
substitutionGroup of CA2 which in turn references CA3. This may be an
illegal scenario for all I know.
Here is the exception stack trace:
org.eclipse.xsd.impl.XSDElementDeclarationImpl.validate(XSDE lementDeclarationImpl.java:1016)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.validate(XSDCo ncreteComponentImpl.java:541)
at org.eclipse.xsd.impl.XSDSchemaImpl.validate(XSDSchemaImpl.ja va:1493)
at ...
Paul.
Re: NPE during schema validation [message #45648 is a reply to message #45560] |
Tue, 25 May 2004 13:04  |
Originally posted by: NOpcooperSPAM.uk.ibm.com
I've opened Bug Report 63916.
Thanks.
Ed Merks wrote:
> Paul,
> It should't produce an NPE. Please open a bugzilla for your sample schema.
> Paul Cooper wrote:
>>Ok, that sounds convincing. Thanks for the fast response.
>>I do think if it would be better for this error scenario to be reported
>>either as a diagnostic or as a more meaningful exception rather than as
>>a NullPointerException. I've managed to code a whole load of erroneous
>>schemas so far but this is the first time I've had an NPE out of the XSD
>>validation code.
>>If the schema is at fault then, as a general rule, I like to be able to
>>return some kind of vaguely meaningful message to the user. In this
>>scenario all I can really do is report that schema validation failed.
>>Thanks.
>>Paul.
Re: NPE during schema validation [message #587514 is a reply to message #45440] |
Tue, 25 May 2004 11:27  |
you have not declared a type in <element name="CA"
final="#all"/> so anyType is assumed. however, the type must be
the type or a subtype of the head of the substitution group and that
type is type="xsd1:CAType" by reference to CA3. anyType is a supertype,
not a subtype, of xsd1:CAType so the schema is not valid.
norwood sisson
> Here's my schema:
> <sequence>
> </sequence>
> </complexType>
> </simpleType>
> final="#all"/>
> </schema>
> java.lang.NullPointerException
> at
> at
> at ...
> Paul.
Re: NPE during schema validation [message #587534 is a reply to message #45501] |
Tue, 25 May 2004 11:41  |
validation code.
Thanks.
Paul.
Re: NPE during schema validation [message #587547 is a reply to message #45530] |
Tue, 25 May 2004 12:13  |
Paul,
> validation code.
> Thanks.
> Paul.
Re: NPE during schema validation [message #587583 is a reply to message #45560] |
Thanks.
Ed Merks wrote:
> Paul,
>>validation code.
>>Thanks.
>>Paul.
FUDForum. Page generated in 0.04246 seconds
