Home » Archived » XML Schema Definition (XSD) » NPE during schema validation
NPE during schema validation [message #45440] Tue, 25 May 2004 10:41 Go to next message
I'm putting together some testcases for an XSD based project I'm working
on when I hit a NullPointerException validating a somewhat contrived
schema. I'm not even certain that the schema is valid, but if it isn't I
would have thought that there would be a more meaningful diagnostic than
an NPE so I figured I'd raise it with you guys to see what you think.
Here's my schema:
<schema targetNamespace="http://com/schemas/ACTDIInterface"
xmlns="http://www.w3.org/2001/XMLSchema"
xmlns:xsd1="http://com/schemas/ACTDIInterface">
<complexType name="CAType">
<sequence>
<element name="el1" type="xsd1:typeRef"/>
</sequence>
</complexType>
<simpleType name="typeRef">
<restriction base="string"/>
</simpleType>
<element name="CA" substitutionGroup="xsd1:CA2" abstract="false"
final="#all"/>
<element name="CA2" ref="xsd1:CA3" abstract="false" />
<element name="CA3" type="xsd1:CAType" abstract="false" />
</schema>
The problem seems to be related to element CA which has a
substitutionGroup of CA2 which in turn references CA3. This may be an
illegal scenario for all I know.
Here is the exception stack trace:
org.eclipse.xsd.impl.XSDElementDeclarationImpl.validate(XSDE lementDeclarationImpl.java:1016)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.validate(XSDCo ncreteComponentImpl.java:541)
at org.eclipse.xsd.impl.XSDSchemaImpl.validate(XSDSchemaImpl.ja va:1493)
at ...
Paul.
Re: NPE during schema validation [message #45501 is a reply to message #45440] Tue, 25 May 2004 11:27 Go to previous messageGo to next message
you have not declared a type in <element name="CA"
final="#all"/> so anyType is assumed. however, the type must be
the type or a subtype of the head of the substitution group and that
type is type="xsd1:CAType" by reference to CA3. anyType is a supertype,
not a subtype, of xsd1:CAType so the schema is not valid.
norwood sisson
> Here's my schema:
> <sequence>
> </sequence>
> </complexType>
> </simpleType>
> final="#all"/>
> </schema>
> java.lang.NullPointerException
> at
> at
> at ...
> Paul.
Re: NPE during schema validation [message #45530 is a reply to message #45501] Tue, 25 May 2004 11:41 Go to previous messageGo to next message
Originally posted by: NOpcooperSPAM.uk.ibm.com
Ok, that sounds convincing. Thanks for the fast response.
I do think if it would be better for this error scenario to be reported
either as a diagnostic or as a more meaningful exception rather than as
a NullPointerException. I've managed to code a whole load of erroneous
schemas so far but this is the first time I've had an NPE out of the XSD
validation code.
If the schema is at fault then, as a general rule, I like to be able to
return some kind of vaguely meaningful message to the user. In this
scenario all I can really do is report that schema validation failed.
Thanks.
Paul.
Re: NPE during schema validation [message #45560 is a reply to message #45530] Tue, 25 May 2004 12:13 Go to previous messageGo to next message
Paul,
It should't produce an NPE. Please open a bugzilla for your sample schema.
> validation code.
> Thanks.
> Paul.
Re: NPE during schema validation [message #45648 is a reply to message #45560] Tue, 25 May 2004 13:04 Go to previous message
I've opened Bug Report 63916.
Thanks.
Ed Merks wrote:
> Paul,
>>validation code.
>>Thanks.
>>Paul.
Re: NPE during schema validation [message #587514 is a reply to message #45440] Tue, 25 May 2004 11:27 Go to previous message
norwood sisson
> Here's my schema:
> <sequence>
> </sequence>
> </complexType>
> </simpleType>
> final="#all"/>
> </schema>
> at
> at
> at ...
> Paul.
Re: NPE during schema validation [message #587534 is a reply to message #45501] Tue, 25 May 2004 11:41 Go to previous message
validation code.
Thanks.
Paul.
Re: NPE during schema validation [message #587547 is a reply to message #45530] Tue, 25 May 2004 12:13 Go to previous message
Paul,
> validation code.
> Thanks.
> Paul.
Re: NPE during schema validation [message #587583 is a reply to message #45560] Tue, 25 May 2004 13:04 Go to previous message
Thanks.
Ed Merks wrote:
> Paul,
>>validation code.
>>Thanks.
>>Paul.
Previous Topic:NPE during schema validation
Next Topic:binding during multiple loads
Current Time: Sun Aug 31 17:32:55 EDT 2025
Powered by FUDForum. Page generated in 0.04164 seconds
