Home » Modeling » TMF (Xtext) » from BNF to metamodel
from BNF to metamodel [message #45428] Tue, 26 May 2009 13:25 Go to next message
would u help me find the steps to get the appropriate metamodel from a
given BNF grammar and its OCL constraints of the Eclipse's xtext;
otherwise, is there another tool to get the same result?
Then, once i find the first metamodel i want to apply the QVT to have the
next metamodel ,so how can i do so?
PS:The main problem is that i have already down loaded the Eclipse and the
xtext program but i couldn't use it
here is the BNF grammar which i want to use
BNF grammar:
http://cui.unige.ch/db-research/Enseignement/analyseinfo/Ada 95/BNFindex.html
Thank u for helping me out :)
Re: from BNF to metamodel [message #45613 is a reply to message #45428] Wed, 27 May 2009 04:20 Go to previous messageGo to next message
Hi Farah,
I don't understand your question. What do you mean by "I downloaded
Xtext but couldn't use it"?
You have to port your existing EBNF to Xtext (most likely by hand) and
generate a metamodel for it. That's the way to go to get the appropriate
metamodel.
Sebastian
Am 26.05.2009 19:25 Uhr, schrieb farah:
> the next metamodel ,so how can i do so?
> the xtext program but i couldn't use it
> BNF grammar:
Re: from BNF to metamodel [message #45643 is a reply to message #45613] Wed, 27 May 2009 11:01 Go to previous messageGo to next message
Hello;
i wanna know is there a particular way in order to present the BNF grammar
to translate without facing any errors or warnings when typing it
Thank u
Farah
Re: from BNF to metamodel [message #46027 is a reply to message #45643] Fri, 29 May 2009 01:48 Go to previous message
Hi Farah,
sorry, I didn't get your point. What do you mean, when you want to
translate your BNF without facing any errors or warnings?
As I already mentioned, you'll have to do it the hard way and translate
your ADA BNF to Xtext yourself.
Actually warnings and errors are quite helpful when you are using the
grammar editor, as the indicate problems with your grammar.
- Sebastian
Am 27.05.2009 17:01 Uhr, schrieb farah:
> Hello;
> grammar to translate without facing any errors or warnings when typing it
> Thank u
> Farah
Previous Topic:[XText] Outline is slow on scrolling
Next Topic:How to add checks to a grammar?
Current Time: Mon Sep 01 01:20:02 EDT 2025
Powered by FUDForum. Page generated in 0.05570 seconds
