Home » Language IDEs » Java Development Tools (JDT) » Assert with Java 1.4
Assert with Java 1.4 [message #45418] Fri, 30 May 2003 16:40 Go to next message
Originally posted by: newsgroup.salas.com
I can't seem to get the new assert statement to work. It compiles fine, but
assert false;
does not do anything. (neither does assert true;)
I did set up the project properties to be 1.4 compliant and to treat
identifiers named assert as errors.
What am I missing?
Pito
Re: Assert with Java 1.4 [message #45508 is a reply to message #45418] Fri, 30 May 2003 16:57 Go to previous messageGo to next message
> assert false;
> What am I missing?
You need to enable assertions in the JVM. They are not enabled by
default for some reason. Add "-ea" to the VM arguments in your launch
configuration.
Jeff
Re: Assert with Java 1.4 [message #45865 is a reply to message #45508] Sat, 31 May 2003 14:01 Go to previous message
Thanks. It worked.
"Jeff Hunter" <jxh106@po.cwru.edu> wrote in message
news:bb8gka$f3a$1@rogue.oti.com...
but
> > assert false;
> > What am I missing?
> configuration.
> Jeff
Previous Topic:plugin development demo for a new view with treeview dont work
Next Topic:which eclipse.?.? for product ideas/discussions
Current Time: Mon Jul 21 21:27:24 EDT 2025
Powered by FUDForum. Page generated in 0.03006 seconds
