Home » Eclipse Projects » GEF » [ANN] Render WYSIWYG documents with Draw2D
Re: [ANN] Render WYSIWYG documents with Draw2D [message #45658 is a reply to message #45628] |
Mon, 25 November 2002 15:14   |
Originally posted by: hudsonr.us.eye-bee-em.com
Until a new build is made, you will also need to checkout the draw2d project
from the CVS server too.
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:aru0bu$89c$1@rogue.oti.com...
> A set of example "snippets", including the one pictured here, can be
> obtained by checking out the project:
> -org.eclipse.draw2d.examples
> From the CVS repository.
> Use anonymous login, via "pserver", to the /home/tools CVS root.
> news:artlbm$1e7$1@rogue.oti.com...
> > Draw2D, which is the painting and layout portion of GEF, has added a new
> > package for rendering WYSIWYG documents. Currently, the support is for
> > paragraphs of text which can contain multiple nested styles, such as
> > different fonts and font sizes.
Re: [ANN] Render WYSIWYG documents with Draw2D [message #45893 is a reply to message #45861] |
Tue, 26 November 2002 10:57   |
"Ed Burnette" <ed.burnette@no.spam.sas.com> wrote in message
news:as050p$c2k$1@rogue.oti.com...
> What's the relationship between this new package and the StyledText
widget?
No relationship. StyledText widget is very limited in what "styles" you can
render. For example, you cannot change the font, or add borders around
regions of text, or render Tables. Of course, you can't do those yet with
draw2d, but someone *has* already done so in their extensions to these
classes, which were available internally at IBM.
> Is this native or emulated on Windows? If emulated, is there a native rich
> text widget anywhere that you know about? Thanks.
Source editing used to be using a RichText control. But, Windows RichText
was a piece of crap, so Eclipse includes a StyledText widget, which was
suitable for their needs. If you need RichText support, this is as close as
you will get. It would be great if you wanted to help out with these new
classes.
Re: [ANN] Render WYSIWYG documents with Draw2D [message #45941 is a reply to message #45911] |
Tue, 26 November 2002 22:19   |
news:as0ola$okv$1@rogue.oti.com...
> That sounds interesting; are the internal extensions going to be part of
> this or will they remain internal? Sounds like you could almost make an
HTML
> viewer with that - is that the application it was designed for? Also I'm
Not viewer, editor. IBM's Page Designer is an HTML/JSP editor built on top
of GEF. But the released package is only concerned with viewing. Any
editing support would go into the GEF plugin perhaps.
> curious as to the technical/architectural reasons why the package is part
of
> GEF/Draw2D and not SWT/JFace. Finally, I don't think you mentioned the
name
SWT/JFace is part of the base Platform. The Platform's focus is source-code
Editors like the java editor. The Platform is mostly developed by OTI.
GEF/draw2d was developed at IBM initially for internal use with Eclipse.
Draw2d is used as a platform for rendering text because it allows you to
compose lightweight figures that layout in an efficient way and paint using
double-buffering. Several complex issues have already been implemented in
Figure (such as coordinate systems, hit-detection, various notifiers), and
it makes sense to take advantage of this.
> of the new package itself (a Javadoc url would be appreciated too).
Thanks.
The package is org.eclipse.draw2d.text. For JavaDoc, you must go to the GEF
build page, download and install the SDK onto Eclipse 2.X, and open the
integrated help system. Our generated JavaDoc is not released onto our
website (which is just a CVS folder) because it would consume a lot of
space, and the builds aren't setup for this.
> news:as05lp$cir$1@rogue.oti.com...
with
Re: [ANN] Render WYSIWYG documents with Draw2D [message #46757 is a reply to message #45941] |
Tue, 03 December 2002 09:04   |
Originally posted by: Bram.Stieperaere.REMOVEskynet.be
Randy,
This is great, I could really use a replacement of StyledText with
richer markup possibilities (doc or rtf style) .
IMHO, What is missing in the examples right now is edit capability .
Also, tables and indentation/interlinea support would be nice to have.
Bram
"Randy Hudson" <none@us.ibm.com> wrote in message
news:as1dhe$2bv$1@rogue.oti.com...
> HTML
top
part
> of
> name
source-code
using
> Thanks.
GEF
around
> with
Re: [ANN] Render WYSIWYG documents with Draw2D [message #46778 is a reply to message #46757] |
Tue, 03 December 2002 10:23   |
"Bram Stieperaere" <Bram.Stieperaere@REMOVEskynet.be> wrote in message
news:asicl1$omd$1@rogue.oti.com...
> Randy,
I think that stuff is missing in everybody's opinion :-). We have to start
somewhere. I can tell you how IBM implements page designer (since this is
public knowledge). There is a special SelectionTool that manages keyboard
entry and the Caret location. There is a Model that is a DOM. There are
EditParts which synchronize the DOM to the draw2d Figures. This is how GEF
works, and it is the logical extension of GEF into text documents.
Are you familiar with EditParts?
> Bram
of
an
> > HTML
I'm
> top
> part
> > of
> > name
> source-code
> using
in
and
> > Thanks.
> GEF
> around
yet
> > with
these
Re: [ANN] Render WYSIWYG documents with Draw2D [message #46868 is a reply to message #46778] |
Tue, 03 December 2002 12:01   |
We also think about tree control with rich text support (something like used
in MS OE). How do you think is it worth for community? Anyway we will need
something like this in our application.
One thing we are dreaming about is an ability to drag'n'drop from editor to
palette. I mean, if you define some complex object in editor space, select
needed things and then DND to palette to extend some reusable templates
category... Is it possible to implement?
Last but not least - antialiasing. Any rumors about this? I think that that
is the only thing that one need to produce first class applications using
GEF.
news:asii6n$soc$1@rogue.oti.com...
> > Randy,
GEF
> > Bram
part
> of
> an
> > > HTML
> I'm
on
> > top
> > part
> > > of
the
> > > name
> > source-code
Eclipse.
to
> > using
> in
> and
> > > Thanks.
the
> > GEF
the
our
> > around
> yet
> > > with
> these
Re: [ANN] Render WYSIWYG documents with Draw2D [message #46897 is a reply to message #46868] |
Tue, 03 December 2002 13:25   |
"Alex Selkov" <as@empproject.com> wrote in message
news:asinra$15b$1@rogue.oti.com...
used
I didn't understand this. What do mean by tree control? Are you talking
about "owner draw"?
to
There are some SWT peculiarities with native Drag. You can do this. See
TransferDragSourceListener, TransferDropTargetListener. But, once you
decide to drag a part using native Drag, you will be forced to use native
drag simply to move the part within the graphical viewer. This can be done
as well, but you will no longer be using Tools, just a DropTarget.
that
> GEF.
Nothing from the SWT team. Please see my previous post requesting that
people CC themselves to the bugzilla to give it more "votes".
> > > Randy,
start
is
keyboard
> GEF
> > > Bram
> part
> > of
make
> > an
> > > > HTML
Also
> > I'm
> on
> > > top
Any
is
> > > part
> > > > of
> the
> > > > name
> > > source-code
OTI.
> Eclipse.
you
> to
paint
> > > using
implemented
> > in
notifiers),
> > and
too).
> > > > Thanks.
> the
> > > GEF
> the
> our
of
> > > around
those
> > yet
> > > > with
> > these
Re: [ANN] Render WYSIWYG documents with Draw2D [message #157506 is a reply to message #45805] |
Wed, 10 November 2004 03:22   |
Originally posted by: mazloumi.uni-mannheim.de
I took a look at the examples in draw2d and have some questions:
1. How do I switch to an editor mode?
2. I would like to add a toolbar for italic, bold, font size, font type.
What would you suggest as a starting point? Do I use the
WorkbenchAdvisor? Is there a support for selection Listeners?
3. Also what would you suggest for adding tables, lists and images?
4. What would be the appropriate way to access the model of that editor.
I would like to serialize the content to XML. Something like this for
instance:
<paragraph><bold>ILP</bold> - <italic>Integer Linear
Programming</italic>: When one or more variables in an LP problem must
assume an integer value we have an Integer Linear Programming (ILP)
problem.</paragraph>
5. Would it make sense to use EMF and model the different FlowFigures
and the genmodel generate the WYSIWYG editor?
Greetings,
Nima
Randy Hudson wrote:
> Sure, this would probably be pretty easy. I would do it like this:
> class SuperInlineFlow extends InlineFlow {
> //this is mostly a convenience class which set's the layout manager to the
> one below.
> //Also, I would override getFont() here to return a Font that is some
> percentage of the parent's Font.
> //But then you get into this big resource management nightmare, that makes
> me want
> //to get rid of SWT Font refererence all together, and use our own FontStyle
> object
> class SuperInlineFlowLayout extends InlineFlowLayout {
> //uses AdjustedLineBoxes instead of LineBox
> class AdjustedLineBox extends LineBox {
> void makeBaseline(int baseline){
> //this method would have to adjust the baseline that it passes to its
> child boxes.
> news:aru7bh$cga$1@rogue.oti.com...
>>Very impressive. Can I emulate subscripts/superscripts?
>>news:aru3jd$a9n$1@rogue.oti.com...
>>>I think I released the fix as you types this message.
>>>news:aru29n$974$1@rogue.oti.com...
>>>>Hmm. draw2d in cvs contains an error:
>>>>Error The method getStringExtents(String, Font) is undefined for the
>>>type
>>>>FlowUtilities FlowUtilities.java
>>>>org.eclipse.draw2d/src/org/eclipse/draw2d/text line 75 in
>>>>FlowUtilities.setupFragment(TextFragmentBox, Font, String)
>>>>And I can't run anything from .examples due to unresolved compilation
>>>>problems.
>>>>news:aru0df$8aa$1@rogue.oti.com...
>>>>project
Re: [ANN] Render WYSIWYG documents with Draw2D [message #157562 is a reply to message #45628] |
Wed, 10 November 2004 13:07   |
Is there a way to add a SelectionListener to a FlowFigure? I want to
allow the user to select text inside a flow figure and change it font
settings. Or maybe selection the whole figure and changing its paramters.
Greetings,
Nima
Re: [ANN] Render WYSIWYG documents with Draw2D [message #158357 is a reply to message #157506] |
Wed, 17 November 2004 13:30   |
Sorry for not seeing these posts earlier. I have bookmarked the thread so
it's at the top of my newsreader now.
I have Bold, I, Underline infrastructure in place, and will release it today
if possible.
> instance:
The difficult task is DEFINITELY writing the commands that edit the
document. EMF could not come close to generating the correct commands. For
example, given:
<B>bold text</B>some more text.
This looks like:
+ Document
+ Container(Bold)
-TextRun(bold text)
- TextRun(some more text.)
If the user selects "some more text.", and invokes bold, the text must be
re-parented to the existing nearby TextRun which is already bold, giving
you:
<B>bold textsome more text.</B>
+ Document
+ Container(Bold)
-TextRun(bold textsome more text.)
And that's a simple scenario! Here's another:
<U><B>bold text</B></U>some more text.
In this case, the <U> and <B> would have to get flipped around to simplify
the document.
Re: [ANN] Render WYSIWYG documents with Draw2D [message #158364 is a reply to message #157562] |
Wed, 17 November 2004 13:32  |
Selection lives in GEF, not draw2d. This function will be released today or
tomorrow. Please check out the example.text project.
"Nima Mazloumi" <mazloumi@uni-mannheim.de> wrote in message
news:cmtlch$eto$1@eclipse.org...
> Greetings,
> Nima
Current Time: Sun Aug 31 00:54:11 EDT 2025
Powered by FUDForum. Page generated in 0.08452 seconds
