Home » Archived » OHF » If OHF validation the document form?
If OHF validation the document form? [message #45413] |
Thu, 07 August 2008 23:55  |
Originally posted by: 322zx.163.com
I puzzuled that If OHF validation the document form before submitting?
This means is :if the docement that submits to the Repository is wrong or
not exact XML file, the OHF validates it and repeat the error?
In other words,for this code Document clinicalDocument = new
Document("./resources/sample_files/test1/input.xml",DocumentDescriptor.CDA_R2),I
change the input.xml to a document that is not a CDA_R2 docment,OHF is
able to check the document that is not CDA_R2?
I do this,but it also is successful to submit to the services.
I would like to know OHF able to check document,for example ,using CDA
Schema check CDA document etc.
Re: If OHF validation the document form? [message #45473 is a reply to message #45413] |
Fri, 08 August 2008 13:39   |
Yep, this is kind of correct. If you tell the XDS Source component that
you are providing a CDA document, it attempts to do an XDS metadata
extraction from elements of the CDA before submitting the document.
This allows a user to create an XDS document submission without doing
(much) additional work in setting values for the XDS metadata -
something that can be quite tedious.
I actually think you have encountered a bug in OHF. Is it possible for
you to send me (attached to this post or through a bug report at
http://www.eclipse.org/ohf/bugs.php) the document you're trying to
submit? I will drop it into the test and see what the debug results are
and whether there's something wrong in OHF. If the document is not a
CDA, then the XDS metadata probably isn't being formed properly. But --
this doesn't appear to be a result of that. It will help me a lot in
trying to determine what's wrong.
Thanks!
-Matt
> or not exact XML file, the OHF validates it and repeat the error?
Re: If OHF validation the document form? [message #45507 is a reply to message #45473] |
Fri, 08 August 2008 17:09  |
Hi Robert,
Is it correct that you are just running the XDS Source JUNITs?
Mesa12049_Option1.java and Mesa11746_Option1.java? I'd verify the
endpoint you are sending to ... the 117* tests are for XDS.a and the
120* tests are for XDS.b. Also from your log of test 12049 it seems that
the metadata loaded successfully from the separate file that it was
supposed to and made it through the conversion to ebXML 3.0, but dies
when we try to encase it in SOAP. To help with this, try to re-run the
test, but switch all the log4j parameters to 'debug' (incase they are
not) and then submit this bug and your sample files to our bugzilla.
This way we have the most information possible.
thanks,
Sarah
Matthew Davis wrote:
> extraction from elements of the CDA before submitting the document. This
> allows a user to create an XDS document submission without doing (much)
> additional work in setting values for the XDS metadata - something that
> Thanks!
> -Matt
Re: If OHF validation the document form? [message #586642 is a reply to message #45413] |
Thanks!
-Matt
Re: If OHF validation the document form? [message #586654 is a reply to message #45473] |
Hi Robert,
thanks,
Sarah
> Thanks!
> -Matt
Current Time: Sat Aug 30 22:19:23 EDT 2025
Powered by FUDForum. Page generated in 0.27433 seconds
