Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE Builder and project registered builders
PDE Builder and project registered builders [message #45410] Thu, 05 February 2009 10:37 Go to next message
I have a plugin project that uses jibx.
jibx does bytecode enhancement to existing classes. It also creates new classes based on information it finds in classes it enhances.
I installed jibx eclipse plugin that adds a jibx nature and a jibx builder to the project.
So everything works well in the modify/save/auto-build/launch development cycle.
But when I try to use the "export" functionality, either directly, or indirectly via the build of a feature via the build of the eclipse update sites, it does not work.
It's as if the export functionality does not leverage the project registered builders.
Is there a solution to this ? Is it a problem in jibx eclipse plugin not correctly doing something to be used via the export functionality ?
Is this a current problem with the eclipse PDE builder ?
I came up with 2 solutions currently, each of which has some cons :
- custom builder. I tell plugin.xml that I will use a custom builder. Ask PDE to create the build.xml file. Tweak the build.xml file. It's not very interesting, because it seems that a lot of things
are hardwired. The generated build.xml file seems to not have been thought to be usable in the long term (lack of factorization, ...).
- play with plugin.xml options : the idea here is to not make PDE compile the classes at all, and prefer instructing him to use the same classes than those compiled via the
modify/save/auto-build/launch/test cycle :
- "runtime" tab : add to the classpath the folder(s) where classes are compiled in the classic development cycle (generally speaking : 'bin' folder)
- "build" tab : "runtime information section" : delete the library named '.' (since we already get all by directly adding 'bin' in the classpath)
- "build" tab : "binary build section" : add folder 'bin' if not already added
I can just see one drawback to this : if the developer's worskpace is not in auto-build, or if the developer has not triggered a build before trying to export, then the 'bin' directory of the
generated plugin jar/folder will be empty.
Do you see other drawbacks to the second solution I may encounter in the long run ?
Re: PDE Builder and project registered builders [message #45505 is a reply to message #45410] Thu, 05 February 2009 14:29 Go to previous messageGo to next message
Yes, this is exactly true.
You have 2 options:
1) Starting in 3.5 (I think M4) there is an option in the export wizard
to reuse .class files from the workspace. This should just pick up the
files after jibx has done its thing.
2) Use custom build callbacks to run custom ant code on your .class
files after they are compiled during export (See
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.pde.doc.user/tasks/pde_custom_callbacks.htm)
From your eclipse install, copy
org.eclipse.pde.build_<version>\templates\plugins\customBuildCallbacks.xml
into your project. In your project's build.properties add
"customBuildCallbacks=true).
In this file edit the post.compile.@dot task to call jibx. I don't know
anything about jibx, so I don't know what this would look like.
${source.folder1}, ${source.folder2}, etc will be properties pointing to
the source files (generally there is only one source folder)
${target.folder} is where the .class files will be
${@dot.classpath} is a reference to the classpath structure that was
used to compile everything.
If you have other libraries, the target will be post.compile.<library>
-Andrew
> Hello,
> development cycle.
> very interesting, because it seems that a lot of things are hardwired.
> classes than those compiled via the modify/save/auto-build/launch/test
> cycle :
> 'bin' folder)
> classpath)
> already added
> trying to export, then the 'bin' directory of the generated plugin
> long run ?
Re: PDE Builder and project registered builders [message #45534 is a reply to message #45505] Fri, 06 February 2009 03:57 Go to previous message
Many thanks !
I'll try this ASAP,
Laurent
> You have 2 options:
> -Andrew
>> Hello,
>> development cycle.
>> not very interesting, because it seems that a lot of things are
>> cycle :
>> 'bin' folder)
>> classpath)
>> already added
>> before trying to export, then the 'bin' directory of the generated
>> the long run ?
Re: PDE Builder and project registered builders [message #591535 is a reply to message #45410] Thu, 05 February 2009 14:29 Go to previous message
You have 2 options:
-Andrew
> Hello,
> development cycle.
> cycle :
> 'bin' folder)
> classpath)
> already added
> long run ?
Re: PDE Builder and project registered builders [message #591546 is a reply to message #45505] Fri, 06 February 2009 03:57 Go to previous message
Many thanks !
I'll try this ASAP,
Laurent
> You have 2 options:
> -Andrew
>> Hello,
>> development cycle.
>> cycle :
>> 'bin' folder)
>> classpath)
>> already added
>> the long run ?
Previous Topic:How to create config.ini file to accept any eclipse plugins in my rcp
Next Topic:headless compilation: equinox launcher version
Current Time: Sun Aug 31 00:37:29 EDT 2025
Powered by FUDForum. Page generated in 0.22623 seconds
