Home » Modeling » Epsilon » [Epsilon] Make a reference from HUTN to an element of a pre-builded model
| [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #376] |
Tue, 07 October 2008 10:12  |
Two months ago I defined UML models using HUTN, now I need to define
models whose elements reference the elements of the UML model.
For example, If I have an UML model with two classes and an association,
in my new model I must have an element that has a property of type EObject
that contains the first class, another element has the second, and
another, the association.
The question would be: Is there a way to do this without redefining the
UML model inside the new model?
In terms of the example of your web, the Family and the pets:
I have a model of a pet called "Sam". I want to define a model of a family
and specify that its pet is "Sam", without repeating all the code of the
pet.
Many thanks,
Héctor
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #381 is a reply to message #376] |
Tue, 07 October 2008 11:00   |
Hi Héctor,
Thanks again for your interest in our HUTN implementation.
We have not yet implemented the feature that you describe (external
object references).
However, the HUTN specification does describe how external objects
should be referenced. I'll look at the feasibility of an implementation
tomorrow. I'll reply here with some more information.
Louis.
Héctor Iturria wrote:
> Hello,
> EObject that contains the first class, another element has the second,
> and another, the association.
> family and specify that its pet is "Sam", without repeating all the code
> of the pet.
> Many thanks,
> Héctor
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #386 is a reply to message #381] |
Fri, 10 October 2008 11:34   |
Hi Héctor,
Apologies for the delay in replying; it's been a busy week!
Firstly, we've added support for external object references to HUTN. The
syntax is as follows:
feature: Person "John", // Internal
Person "/ProjectName/FileName.model#//@children.0", //
External, fragment
Person "/ProjectName/FileName.model#//_abcdefghijklm" //
External, id
Other URI schemas can be used too, for example:
"file:/usr/home/FileName.model#//@children.0"
An explanation of how EMF interprets URI fragments can be found here:
http://books.google.co.uk/books?id=ff-9ZYhvPwwC&pg=PA303 &lpg=PA303&dq=uri+fragment+emf&source=web&ot s=yyUmE-sQxC&sig=gLEPEPJV5vbTgY5oS0LUmpJ2ZMw&hl=en&a mp;sa=X&oi=book_result&resnum=3&ct=result#PPA303 ,M1
Secondly, we won't be releasing a new version of Epsilon just yet.
Instead, if you'd like to use external object references with HUTN,
you'll need to run Epsilon and HUTN from source. Please follow the
instructions here:
http://www.eclipse.org/gmt/epsilon/doc/EpsilonSVN.pdf
An advantage of running from source is that you can easily receive any
patches to Epsilon and HUTN, ahead of the next release.
Hope this helps.
Louis.
Louis Rose wrote:
> Hi Héctor,
> object references).
> Cheers,
> Louis.
>> Hello,
>> association, in my new model I must have an element that has a
>> property of type EObject that contains the first class, another
>> element has the second, and another, the association.
>> the UML model inside the new model?
>> code of the pet.
>> Many thanks,
>> Héctor
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #1233 is a reply to message #1207] |
Mon, 20 October 2008 04:56   |
Hi Hector,
I don't seem to be able to reproduce this :( Attached is the project
I've put together using the files you've provided me with and I'm not
getting any reference-related errors (I've registered rulesCatalog.ecore
and transformationConfiguration.ecore). Could you please confirm that
the attached project works for you?
Dimitrios
> No no, the model that owns this fragment is not UML based. I send you
> the ecore file and the example I was writing. This model needs to link
> elements from both the UML2DB.rulescatalog and the UML it complements
> (each of this models are made for one UML model, the UML2DB.rulescatalog
> is common for all).
> As you will see, the example is in a very initial phase of development.
> Many thanks for the help!
> Héctor
> Dimitrios Kolovos escribió:
>> Hi Hector,
>> I have placed the rulesCatalog.ecore and UML2DB.rulescatalog files in
>> a project called Hector (;)), registered rulesCatalog.ecore
>> (right-click->Register EPackages) and created a new sample.hutn file
>> with the following contents:
>> @Spec {
>> metamodel "UML" {
>> nsUri: "http://www.eclipse.org/uml2/2.1.0/UML"
>> uml {
>> Model "UML"{
>> metamodel: Metamodel "/Hector/UML2DB.rulescatalog#//@source.0"
>> The error I'm getting is "Unrecognised feature: metamodel" which seems
>> reasonable as I haven't found a feature called "metamodel" in the UML2
>> metamodel. Where does this feature come from (a profile?)?
>> Could you please confirm that you can open UML2DB.rulescatalog using
>> the tree editor with no problems and also that your paths are correct?
>> If so, could you please send me your zipped Eclipse project to make
>> sure that we are working on the same things?
>> Cheers,
>> Dimitrios
>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #1257 is a reply to message #1233] |
Mon, 20 October 2008 06:39   |
Hi Dimitrios,
I think you have forgotten to attach the files ;-)
> Hi Hector,
> Cheers,
> Dimitrios
>> UML2DB.rulescatalog is common for all).
>> Héctor
>>> Hi Hector,
>>> @Spec {
>>> metamodel "UML" {
>>> uml {
>>> Model "UML"{
>>> seems reasonable as I haven't found a feature called "metamodel" in
>>> the UML2 metamodel. Where does this feature come from (a profile?)?
>>> correct? If so, could you please send me your zipped Eclipse project
>>> to make sure that we are working on the same things?
>>> Cheers,
>>> Dimitrios
>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #1302 is a reply to message #1257] |
Mon, 20 October 2008 07:07   |
Many thanks, Dimitrios, but now the file is corrupted and I can't open
it. One more time, please :)
Héctor Iturria escribió:
> Hi Dimitrios,
>> Hi Hector,
>> rulesCatalog.ecore and transformationConfiguration.ecore). Could you
>> please confirm that the attached project works for you?
>> Cheers,
>> Dimitrios
>>> link elements from both the UML2DB.rulescatalog and the UML it
>>> complements (each of this models are made for one UML model, the
>>> Héctor
>>>> Hi Hector,
>>>> in a project called Hector (;)), registered rulesCatalog.ecore
>>>> @Spec {
>>>> metamodel "UML" {
>>>> uml {
>>>> Model "UML"{
>>>> Cheers,
>>>> Dimitrios
>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #1321 is a reply to message #1302] |
Mon, 20 October 2008 07:12   |
What program are you using to unzip it? Winrar as well as the built-in
WinXP compressed folder utility seem to be opening it fine...
Dimitrios
>> Hi Dimitrios,
>>> Hi Hector,
>>> Cheers,
>>> Dimitrios
>>>> you the ecore file and the example I was writing. This model needs
>>>> to link elements from both the UML2DB.rulescatalog and the UML it
>>>> Héctor
>>>>> Hi Hector,
>>>>> file with the following contents:
>>>>> @Spec {
>>>>> metamodel "UML" {
>>>>> uml {
>>>>> Model "UML"{
>>>>> using the tree editor with no problems and also that your paths are
>>>>> project to make sure that we are working on the same things?
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #1843 is a reply to message #1321] |
Mon, 20 October 2008 07:38   |
Ok, it works if I download it from Thunderbird instead of the web.
I have imported the project you have just sent me, and still generates
the same error:
org.eclipse.epsilon.hutn.exceptions.HutnValidationException: Method
'resourceExists' not found (168:19)
I have checked out the projects from the svn repository, exported them
as deployable plugins and added to eclipse as extension locations. Then
I will try to generate the models in a second instance using the
projects of the workspace.
Many thanks,
Héctor
> Cheers,
> Dimitrios
>>> Hi Dimitrios,
>>>> Hi Hector,
>>>> not getting any reference-related errors (I've registered
>>>> Cheers,
>>>> Dimitrios
>>>>> development.
>>>>> Héctor
>>>>>> Hi Hector,
>>>>>> @Spec {
>>>>>> metamodel "UML" {
>>>>>> uml {
>>>>>> Model "UML"{
>>>>>> in the UML2 metamodel. Where does this feature come from (a
>>>>>> profile?)?
>>>>>> are correct? If so, could you please send me your zipped Eclipse
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #1855 is a reply to message #1843] |
Mon, 20 October 2008 07:45   |
I think I got it! To support external references, the EmfTool class in
the org.eclipse.epsilon.emc.emf plugin has been updated (a method called
resourceExists has been added). Could you please also use Epsilon from
the SVN (or if you are doing this already, update your local copy)?
Dimitrios
> the same error:
> Many thanks,
> Héctor
>> Cheers,
>> Dimitrios
>>> open it. One more time, please :)
>>>> Hi Dimitrios,
>>>>> Hi Hector,
>>>>> project I've put together using the files you've provided me with
>>>>> and I'm not getting any reference-related errors (I've registered
>>>>> you please confirm that the attached project works for you?
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> development.
>>>>>> Héctor
>>>>>>> Hi Hector,
>>>>>>> files in a project called Hector (;)), registered
>>>>>>> rulesCatalog.ecore (right-click->Register EPackages) and created
>>>>>>> a new sample.hutn file with the following contents:
>>>>>>> @Spec {
>>>>>>> metamodel "UML" {
>>>>>>> uml {
>>>>>>> Model "UML"{
>>>>>>> profile?)?
>>>>>>> Cheers,
>>>>>>> Dimitrios
>>>>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #1865 is a reply to message #1855] |
Tue, 21 October 2008 04:14   |
Hi Dimitrios,
Finally I managed to reference the external elements, the issues I had
were because of the installation of Epsilon in my Eclipse. I uninstalled
it, but the jar files were still in the plugins folder of Ecplise and
the application was loading them. I have deleted them manually and add
the latest from your repository as an external location, now it seems to
work fine :)
Many thanks,
Héctor
> Cheers,
> Dimitrios
>> the same error:
>> Then I will try to generate the models in a second instance using the
>> Many thanks,
>> Héctor
>>> built-in WinXP compressed folder utility seem to be opening it fine...
>>> Cheers,
>>> Dimitrios
>>>>> Hi Dimitrios,
>>>>>> Hi Hector,
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> needs to link elements from both the UML2DB.rulescatalog and the
>>>>>>> UML it complements (each of this models are made for one UML
>>>>>>> model, the UML2DB.rulescatalog is common for all).
>>>>>>> development.
>>>>>>> Héctor
>>>>>>>> Hi Hector,
>>>>>>>> @Spec {
>>>>>>>> metamodel "UML" {
>>>>>>>> uml {
>>>>>>>> Model "UML"{
>>>>>>>> profile?)?
>>>>>>>> Cheers,
>>>>>>>> Dimitrios
>>>>>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #1877 is a reply to message #1865] |
Tue, 21 October 2008 07:25   |
Hi Hector,
Glad it worked and thanks for your feedback! The changes will appear in
the next binary version of Epsilon (0.8.2).
Dimitrios
> Hi Dimitrios,
> work fine :)
> Many thanks,
> Héctor
>> called resourceExists has been added). Could you please also use
>> Epsilon from the SVN (or if you are doing this already, update your
>> local copy)?
>> Cheers,
>> Dimitrios
>>> generates the same error:
>>> them as deployable plugins and added to eclipse as extension
>>> locations. Then I will try to generate the models in a second
>>> instance using the projects of the workspace.
>>> Many thanks,
>>> Héctor
>>>> Cheers,
>>>> Dimitrios
>>>>>> Hi Dimitrios,
>>>>>>> Hi Hector,
>>>>>>> Cheers,
>>>>>>> Dimitrios
>>>>>>>> send you the ecore file and the example I was writing. This
>>>>>>>> model needs to link elements from both the UML2DB.rulescatalog
>>>>>>>> and the UML it complements (each of this models are made for one
>>>>>>>> UML model, the UML2DB.rulescatalog is common for all).
>>>>>>>> development.
>>>>>>>> Héctor
>>>>>>>>> Hi Hector,
>>>>>>>>> created a new sample.hutn file with the following contents:
>>>>>>>>> @Spec {
>>>>>>>>> metamodel "UML" {
>>>>>>>>> uml {
>>>>>>>>> Model "UML"{
>>>>>>>>> which seems reasonable as I haven't found a feature called
>>>>>>>>> "metamodel" in the UML2 metamodel. Where does this feature come
>>>>>>>>> from (a profile?)?
>>>>>>>>> Eclipse project to make sure that we are working on the same
>>>>>>>>> things?
>>>>>>>>> Cheers,
>>>>>>>>> Dimitrios
>>>>>>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #1891 is a reply to message #1877] |
Tue, 28 October 2008 07:05   |
Hi Héctor,
Dimitrios has just released Epsilon 0.8.2 and HUTN 0.7.2, which include
fixes to the problems you've encountered.
Feel free to switch back to a binary version of Epsilon and HUTN if
that's more convenient for you. You're also welcome to continue using
the tools from source. That way you'll have early access to all new
features (and all new bugs!)
The update manager will advertise the new versions in a couple of hours.
Many thanks,
Louis.
Dimitrios Kolovos wrote:
> Hi Hector,
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> uninstalled it, but the jar files were still in the plugins folder of
>> Ecplise and the application was loading them. I have deleted them
>> manually and add the latest from your repository as an external
>> location, now it seems to work fine :)
>> Many thanks,
>> Héctor
>>> in the org.eclipse.epsilon.emc.emf plugin has been updated (a method
>>> local copy)?
>>> Cheers,
>>> Dimitrios
>>>> Many thanks,
>>>> Héctor
>>>>> Cheers,
>>>>> Dimitrios
>>>>>>> Hi Dimitrios,
>>>>>>>> Hi Hector,
>>>>>>>> with and I'm not getting any reference-related errors (I've
>>>>>>>> registered rulesCatalog.ecore and
>>>>>>>> Cheers,
>>>>>>>> Dimitrios
>>>>>>>>> one UML model, the UML2DB.rulescatalog is common for all).
>>>>>>>>> development.
>>>>>>>>> Héctor
>>>>>>>>>> Hi Hector,
>>>>>>>>>> @Spec {
>>>>>>>>>> metamodel "UML" {
>>>>>>>>>> uml {
>>>>>>>>>> Model "UML"{
>>>>>>>>>> paths are correct? If so, could you please send me your zipped
>>>>>>>>>> things?
>>>>>>>>>> Cheers,
>>>>>>>>>> Dimitrios
>>>>>>>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #1905 is a reply to message #1891] |
Wed, 29 October 2008 05:24  |
Hi!
Now I am focused in building the models, I have a working framework and
will continue using the files from the SVN repository.
Many thanks for the news,
Héctor
Louis Rose escribió:
> Hi Héctor,
> Many thanks,
> Louis.
>> Hi Hector,
>> in the next binary version of Epsilon (0.8.2).
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> had were because of the installation of Epsilon in my Eclipse. I
>>> Many thanks,
>>> Héctor
>>>> local copy)?
>>>> Cheers,
>>>> Dimitrios
>>>>> Many thanks,
>>>>> Héctor
>>>>>> fine...
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>>> Hi Dimitrios,
>>>>>>>>> Hi Hector,
>>>>>>>>> Cheers,
>>>>>>>>> Dimitrios
>>>>>>>>>> development.
>>>>>>>>>> Héctor
>>>>>>>>>>> Hi Hector,
>>>>>>>>>>> @Spec {
>>>>>>>>>>> metamodel "UML" {
>>>>>>>>>>> uml {
>>>>>>>>>>> Model "UML"{
>>>>>>>>>>> UML2DB.rulescatalog using the tree editor with no problems
>>>>>>>>>>> and also that your paths are correct? If so, could you please
>>>>>>>>>>> send me your zipped Eclipse project to make sure that we are
>>>>>>>>>>> Cheers,
>>>>>>>>>>> Dimitrios
>>>>>>>>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #560874 is a reply to message #376] |
Hi Héctor,
object references).
Louis.
> Hello,
> of the pet.
> Many thanks,
> Héctor
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #560886 is a reply to message #381] |
Hi Héctor,
External, fragment
External, id
instructions here:
Hope this helps.
Louis.
Louis Rose wrote:
> Hi Héctor,
> object references).
> Cheers,
> Louis.
>> Hello,
>> code of the pet.
>> Many thanks,
>> Héctor
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561078 is a reply to message #390] |
Fri, 17 October 2008 05:49  |
Once I have updated my HUTN specifications and regenerated the models, I
am going again with this. I am writing the first model which references
extern elements, here is a little fragment:
Model "UML"{
" /es.cv.gvcase.linkers.uml2db.transf/models/UML2DB.rulescatal og#//@source.0 "
The only output I get is:
If I comment the metamodel line it gives another errors (like property
xxx must be specificated..) so I think something is wrong with the
external linking.
Many thanks,
Héctor Iturria
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561093 is a reply to message #1018] |
Fri, 17 October 2008 06:25  |
Hi Hector,
Could you please attach the UML2DB.rulescatalog model so that I can try
to reproduce this?
Dimitrios
> Model "UML"{
> external linking.
> Many thanks,
> Héctor Iturria
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561123 is a reply to message #1045] |
Fri, 17 October 2008 07:33  |
I seem to also be needing the .ecore metamodel
http:///es.cv.gvcase.rulesCatalog.ecore
Dimitrios
> Hi Hector,
> to reproduce this?
> Cheers,
> Dimitrios
>> I am going again with this. I am writing the first model which
>> references extern elements, here is a little fragment:
>> Model "UML"{
>> external linking.
>> Many thanks,
>> Héctor Iturria
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561136 is a reply to message #1045] |
Fri, 17 October 2008 07:40  |
--------------040104020602050004010600
Ok, here it is.
Content-Type: text/xml;
name="rulesCatalog.ecore"
Content-Disposition: inline;
filename="rulesCatalog.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="rulesCatalog"
nsURI="http:///es.cv.gvcase.rulesCatalog.ecore" nsPrefix="rulesCatalog">
<eClassifiers xsi:type="ecore:EClass" name="Catalog">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="transformation" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="configurations" upperBound="-1"
eType="#//ConfigurationPattern" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="source" upperBound="-1"
eType="#//Metamodel" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Metamodel">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ConfigurationPattern">
<eStructuralFeatures xsi:type="ecore:EReference" name="rules" lowerBound="1" upperBound="-1"
eType="#//Rule" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="pattern" lowerBound="1"
eType="#//Pattern" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="defaultRule" lowerBound="1"
eType="#//Rule"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="parameter" upperBound="-1"
eType="#//Parameter" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Rule">
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Pattern">
<eStructuralFeatures xsi:type="ecore:EReference" name="elements" lowerBound="1"
upperBound="-1" eType="#//Instance" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="firstElement" lowerBound="1"
eType="#//Instance"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Instance">
<eStructuralFeatures xsi:type="ecore:EReference" name="type" eType="ecore:EClass http://www.eclipse.org/emf/2002/Ecore#//EObject"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="instanceParameters" upperBound="-1"
eType="#//InstanceParameter" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="InstanceParameter"/>
<eClassifiers xsi:type="ecore:EClass" name="ReferenceInstanceParameter" eSuperTypes="#//InstanceParameter">
<eStructuralFeatures xsi:type="ecore:EReference" name="reference" eType="ecore:EClass http://www.eclipse.org/emf/2002/Ecore#//EObject"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="value" eType="#//Instance"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="AttributeInstanceParameter" eSuperTypes="#//InstanceParameter">
<eStructuralFeatures xsi:type="ecore:EReference" name="attribute" eType="ecore:EClass http://www.eclipse.org/emf/2002/Ecore#//EObject"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Parameter">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="type" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
</ecore:EPackage>
--------------040104020602050004010600--
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561165 is a reply to message #1127] |
Fri, 17 October 2008 07:50  |
Hi Hector,
I have placed the rulesCatalog.ecore and UML2DB.rulescatalog files in a
@Spec {
metamodel "UML" {
uml {
Model "UML"{
Could you please confirm that you can open UML2DB.rulescatalog using the
tree editor with no problems and also that your paths are correct? If
so, could you please send me your zipped Eclipse project to make sure
Dimitrios
> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561179 is a reply to message #1180] |
Fri, 17 October 2008 08:05  |
--------------060109040606050002050502
is common for all).
H
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561188 is a reply to message #1207] |
Hi Hector,
Dimitrios
> is common for all).
> Héctor
>> Hi Hector,
>> @Spec {
>> metamodel "UML" {
>> uml {
>> Model "UML"{
>> Cheers,
>> Dimitrios
>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561206 is a reply to message #1233] |
Hi Dimitrios,
> Hi Hector,
> Cheers,
> Dimitrios
>> Héctor
>>> Hi Hector,
>>> @Spec {
>>> metamodel "UML" {
>>> uml {
>>> Model "UML"{
>>> Cheers,
>>> Dimitrios
>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561239 is a reply to message #1257] |
> Hi Dimitrios,
>> Hi Hector,
>> Cheers,
>> Dimitrios
>>> Héctor
>>>> Hi Hector,
>>>> @Spec {
>>>> metamodel "UML" {
>>>> uml {
>>>> Model "UML"{
>>>> Cheers,
>>>> Dimitrios
>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561250 is a reply to message #1302] |
Dimitrios
>> Hi Dimitrios,
>>> Hi Hector,
>>> Cheers,
>>> Dimitrios
>>>> Héctor
>>>>> Hi Hector,
>>>>> @Spec {
>>>>> metamodel "UML" {
>>>>> uml {
>>>>> Model "UML"{
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561266 is a reply to message #1321] |
the same error:
Many thanks,
Héctor
> Cheers,
> Dimitrios
>>> Hi Dimitrios,
>>>> Hi Hector,
>>>> Cheers,
>>>> Dimitrios
>>>>> development.
>>>>> Héctor
>>>>>> Hi Hector,
>>>>>> @Spec {
>>>>>> metamodel "UML" {
>>>>>> uml {
>>>>>> Model "UML"{
>>>>>> profile?)?
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561281 is a reply to message #1843] |
Dimitrios
> the same error:
> Many thanks,
> Héctor
>> Cheers,
>> Dimitrios
>>>> Hi Dimitrios,
>>>>> Hi Hector,
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> development.
>>>>>> Héctor
>>>>>>> Hi Hector,
>>>>>>> @Spec {
>>>>>>> metamodel "UML" {
>>>>>>> uml {
>>>>>>> Model "UML"{
>>>>>>> profile?)?
>>>>>>> Cheers,
>>>>>>> Dimitrios
>>>>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561297 is a reply to message #1855] |
Hi Dimitrios,
work fine :)
Many thanks,
Héctor
> Cheers,
> Dimitrios
>> the same error:
>> Many thanks,
>> Héctor
>>> Cheers,
>>> Dimitrios
>>>>> Hi Dimitrios,
>>>>>> Hi Hector,
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> development.
>>>>>>> Héctor
>>>>>>>> Hi Hector,
>>>>>>>> @Spec {
>>>>>>>> metamodel "UML" {
>>>>>>>> uml {
>>>>>>>> Model "UML"{
>>>>>>>> profile?)?
>>>>>>>> Cheers,
>>>>>>>> Dimitrios
>>>>>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561312 is a reply to message #1865] |
Hi Hector,
Dimitrios
> Hi Dimitrios,
> work fine :)
> Many thanks,
> Héctor
>> local copy)?
>> Cheers,
>> Dimitrios
>>> Many thanks,
>>> Héctor
>>>> Cheers,
>>>> Dimitrios
>>>>>> Hi Dimitrios,
>>>>>>> Hi Hector,
>>>>>>> Cheers,
>>>>>>> Dimitrios
>>>>>>>> development.
>>>>>>>> Héctor
>>>>>>>>> Hi Hector,
>>>>>>>>> @Spec {
>>>>>>>>> metamodel "UML" {
>>>>>>>>> uml {
>>>>>>>>> Model "UML"{
>>>>>>>>> from (a profile?)?
>>>>>>>>> things?
>>>>>>>>> Cheers,
>>>>>>>>> Dimitrios
>>>>>>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561329 is a reply to message #1877] |
Hi Héctor,
Many thanks,
Louis.
> Hi Hector,
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> Many thanks,
>> Héctor
>>> local copy)?
>>> Cheers,
>>> Dimitrios
>>>> Many thanks,
>>>> Héctor
>>>>> Cheers,
>>>>> Dimitrios
>>>>>>> Hi Dimitrios,
>>>>>>>> Hi Hector,
>>>>>>>> Cheers,
>>>>>>>> Dimitrios
>>>>>>>>> development.
>>>>>>>>> Héctor
>>>>>>>>>> Hi Hector,
>>>>>>>>>> @Spec {
>>>>>>>>>> metamodel "UML" {
>>>>>>>>>> uml {
>>>>>>>>>> Model "UML"{
>>>>>>>>>> things?
>>>>>>>>>> Cheers,
>>>>>>>>>> Dimitrios
>>>>>>>>>>> Ok, here it is.
| Re: [Epsilon] Make a reference from HUTN to an element of a pre-builded model [message #561348 is a reply to message #1891] |
Hi!
Héctor
> Hi Héctor,
> Many thanks,
> Louis.
>> Hi Hector,
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> Many thanks,
>>> Héctor
>>>> local copy)?
>>>> Cheers,
>>>> Dimitrios
>>>>> Many thanks,
>>>>> Héctor
>>>>>> fine...
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>>> Hi Dimitrios,
>>>>>>>>> Hi Hector,
>>>>>>>>> Cheers,
>>>>>>>>> Dimitrios
>>>>>>>>>> development.
>>>>>>>>>> Héctor
>>>>>>>>>>> Hi Hector,
>>>>>>>>>>> @Spec {
>>>>>>>>>>> metamodel "UML" {
>>>>>>>>>>> uml {
>>>>>>>>>>> Model "UML"{
>>>>>>>>>>> Cheers,
>>>>>>>>>>> Dimitrios
>>>>>>>>>>>> Ok, here it is.
Current Time: Thu Nov 20 00:17:27 EST 2025
Powered by FUDForum. Page generated in 0.11541 seconds
