Home » Archived » EPF » Missing activity diagrams
Missing activity diagrams [message #45385] Mon, 05 November 2007 14:58 Go to next message
I have just noticed the process published via command line interface
doesn't include any activity diagram (the same configuration published via
MC contains them).
I would really appreciate if you check my code (see parseArgs method) - what
is missing there?
I use following parameters:
<exec executable="C:/builder/epf-composer/epf.exe">
<arg line="-application org.eclipse.epf.publishing.cmdline.Publish" />
<arg line="-data ${dir.data}" />
<arg line="-nosplash" />
<arg line="-libraryPath ${dir.checkout}/OpenUP" />
<arg line="-publishPath ${dir.epf.publish}" />
<arg line="-config TE-RUP_Agile" />
<arg line="-feedback mailto:te.rup@tietoenator.com" />
<arg line="-glossary" />
<arg line="-index" />
<arg line="-publishUnverifiedDiagrams" />
<arg line="-vmargs -Xms64m -Xmx512m" />
<arg line="-title TE-RUP/Agile" />
</exec>
I have also check out your org.eclipse.epf.cmd.ui plugin to find out correct
PublishOptions setup - no success.
Thanks a lot,
Roman
  • Attachment: Publish.java
    (Size: 8.24KB, Downloaded 335 times)
Re: Missing activity diagrams [message #45446 is a reply to message #45385] Tue, 06 November 2007 13:04 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
Looks like you don't have publishing options set for diagrams. Take a look
at PublishHTMLOptions -> setPublishBaseAD and setPublishUnopenADD methods.
Shilpa
Re: Missing activity diagrams [message #45533 is a reply to message #45446] Wed, 07 November 2007 08:26 Go to previous messageGo to next message
Hi Shilpa,
Yes, I have tried this - same result. Even when I publish configuration
using standard dialog I don't need to select them eighter. Any other idea?
Roman
"Shilpa Toraskar" <storaskar@xx.xxx.xxx> wrote in message
news:ee1cae2fdffabec40409d8b5aab6a05c$1@www.eclipse.org...
> Shilpa
Re: Missing activity diagrams [message #45561 is a reply to message #45533] Wed, 07 November 2007 09:26 Go to previous messageGo to next message
I have checked the properties, when I debug EPF and standard way of
publishing I get exactly same properties:
options PublishHTMLOptions (id=160)
aboutHTML ""
bannerImage ""
bannerImageHeight 67
checkExternalLinks false
convertBrokenLinks false
defaultActivityTab "WBS"
dynamicWebAppName null
feedbackURL "http://www.published_website.com/feedback"
includeServletSearch false
processes null
publishBaseAD false
publishConfiguration true
publishDir "C:\\Documents and Settings\\smirarom\\EPF\\Publish1.0-int"
publishDynamicWebApp false
publishEmptyCategories false
publishGlossary false
publishIndex false
publishJavaScriptTree true
publishLightWeightTree true
publishProcess false
publishUnopenADD false
showDescriptorsInNavigationTree false
showMethodContentInDescriptors false
showRelatedDescriptors false
title ""
as when I run my command line publishing; the result: standard includes
diagrams, command line doesn't. Any ideas?
Roman
"Roman Smirak" <roman.smirak@tietoenator.com> wrote in message
news:fgseeo$5qu$1@build.eclipse.org...
> Hi Shilpa,
> Roman
>> look at PublishHTMLOptions -> setPublishBaseAD and setPublishUnopenADD
>> methods.
>> Shilpa
Re: Missing activity diagrams [message #45590 is a reply to message #45561] Thu, 08 November 2007 13:22 Go to previous messageGo to next message
I'm debugging both - std publishing via dialog as well as the command
line version - still no progress.
Can you please let me know what sort of conditions/parameters are in charge
of the decision whether or not to generate a diagram? Or class, or ...
Roman
news:fgshud$i9s$1@build.eclipse.org...
> aboutHTML ""
> bannerImage ""
> processes null
> publishBaseAD false
> publishIndex false
> title ""
> Roman
>> Hi Shilpa,
>> configuration using standard dialog I don't need to select them eighter.
>> Any other idea?
>> Regards,
>> Roman
>>> methods.
>>> Shilpa
Re: Missing activity diagrams [message #45620 is a reply to message #45590] Thu, 08 November 2007 15:19 Go to previous messageGo to next message
Yeah.. you would have to debug into this. It's quite possible that current
diagram publishing may need UI.
From EPF, you need to start looking into
org.eclipse.epf.diagram.ui.service.DiagramImageService and
org.eclipse.epf.diagram.ui.viewer.NewActivityDiagramviewer. Those are two
packages where diagrams get published.
DiagramImageService constructor need composite of 1x1 pixels to hold
diagram. This was needed for GEF based diagrams. In latest release we
moved to GMF, but not sure whether that's still needed. That's something
we need to check on our side to see whether we can get rid of that
composite.
If you look at standard publishing -
org.eclipse.epf.publishing.ui.wizards.PublishProgressMonitor Dialog it's
creating that composite and passing into DiagramImageService. I am
guessing you don't have that in command-line publishing code.
I am not sure whether that's causing command-line publishing not to show
diagrams but that's something you need to start looking into and debug
more into DiagramImageService and viewer class.
Hope it helps..
Shilpa Toraskar
Re: Missing activity diagrams [message #45650 is a reply to message #45620] Fri, 09 November 2007 07:00 Go to previous messageGo to next message
Hi Shilpa,
thanks a lot for you reply - it was very helpful. My current status:
1/ if I register ActivityDiagramService I get activity detail diagrams
(role - responsibility) - all works fine. However I would like to get those
nice activity diagrams
2/ if I register DiagramImageService, I get following exception:
java.lang.IllegalStateException: Workbench has not been created yet.
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:92)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalVie wer$ToggleUpdateManager.sendUpdateRequest(DiagramGraphicalVi ewer.java:92)
org.eclipse.draw2d.DeferredUpdateManager.queueWork(DeferredU pdateManager.java:229)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalVie wer$ToggleUpdateManager.queueWork(DiagramGraphicalViewer.jav a:132)
org.eclipse.draw2d.DeferredUpdateManager.addInvalidFigure(De ferredUpdateManager.java:124)
at org.eclipse.draw2d.Figure.revalidate(Figure.java:1349)
org.eclipse.draw2d.LightweightSystem.setControl(LightweightS ystem.java:237)
at org.eclipse.draw2d.FigureCanvas.<init>(FigureCanvas.java:124)
at org.eclipse.draw2d.FigureCanvas.<init>(FigureCanvas.java:108)
org.eclipse.gef.ui.parts.ScrollingGraphicalViewer.createCont rol(ScrollingGraphicalViewer.java:50)
org.eclipse.epf.diagram.ui.viewer.AbstractDiagramGraphicalVi ewerEx.createGraphicalViewer(AbstractDiagramGraphicalViewerE x.java:348)
org.eclipse.epf.diagram.ui.viewer.AbstractDiagramGraphicalVi ewer. <init>(AbstractDiagramGraphicalViewer.java:62)
org.eclipse.epf.diagram.ui.viewer.AbstractDiagramGraphicalVi ewerEx. <init>(AbstractDiagramGraphicalViewerEx.java:105)
org.eclipse.epf.diagram.ui.viewer.NewActivityDetailDiagramVi ewer. <init>(NewActivityDetailDiagramViewer.java:47)
org.eclipse.epf.diagram.ui.service.DiagramImageService.getDi agramViewer(DiagramImageService.java:175)
org.eclipse.epf.diagram.ui.service.DiagramImageService._inte rnal_generateImage(DiagramImageService.java:368)
org.eclipse.epf.diagram.ui.service.DiagramImageService.__int ernal_saveDiagram(DiagramImageService.java:305)
org.eclipse.epf.diagram.ui.service.DiagramImageService.acces s$0(DiagramImageService.java:294)
org.eclipse.epf.diagram.ui.service.DiagramImageService$1.run (DiagramImageService.java:253)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
at org.eclipse.epf.publishing.cmdline.Publish.run(Publish.java: 98)
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAppContainer.java:533)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:155)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
Unfortunately I'm not familiar with workbench instantiation - any ideas?
Thanks a lot,
Roman
news:3394a8abf25f2d85e6060461825bd060$1@www.eclipse.org...
> composite.
> Hope it helps..
> Regards
> Shilpa Toraskar
Re: Missing activity diagrams [message #45804 is a reply to message #45650] Mon, 12 November 2007 14:01 Go to previous messageGo to next message
ActivityDiagramService is old legacy class which we used for GEF based
diagrams. Although activity detail diagrams have the same look and feel
for both GEF & GMF, it may not be a good idea to use that class since we
might take it out.
For current (GMF) diagrams, you really need to look epf.diagram.xx..
packages.
The exception you got for DiagramImageService makes sense. It complained
about workbench UI not started which you don't have in command-line
publishing. If you look at exception trace, it goes to GMF which in turns
calls workbench UI. That could be difference between GEF and GMF. And may
be that's why ActivityDiagramService work fine for you.
Sorry..this is not much of help for you. But looks like you would have to
work your way around to get diagrams working for command-line publishing.
Shilpa
Re: Missing activity diagrams [message #46067 is a reply to message #45804] Wed, 21 November 2007 13:03 Go to previous message
finally I have succeeded - see
https://bugs.eclipse.org/bugs/attachment.cgi?id=83455
Roman
news:ce5a14da683c34564d8e2f338e7c7f0a$1@www.eclipse.org...
> might take it out.
> packages.
> Shilpa
Re: Missing activity diagrams [message #585460 is a reply to message #45385] Tue, 06 November 2007 13:04 Go to previous message
Shilpa
Re: Missing activity diagrams [message #585507 is a reply to message #45446] Wed, 07 November 2007 08:26 Go to previous message
Hi Shilpa,
Roman
> Shilpa
Re: Missing activity diagrams [message #585522 is a reply to message #45533] Wed, 07 November 2007 09:26 Go to previous message
aboutHTML ""
bannerImage ""
processes null
publishBaseAD false
publishIndex false
title ""
Roman
> Hi Shilpa,
> Roman
>> methods.
>> Shilpa
Re: Missing activity diagrams [message #585536 is a reply to message #45561] Thu, 08 November 2007 13:22 Go to previous message
Roman
> aboutHTML ""
> bannerImage ""
> processes null
> publishBaseAD false
> publishIndex false
> title ""
> Roman
>> Hi Shilpa,
>> Any other idea?
>> Regards,
>> Roman
>>> methods.
>>> Shilpa
Re: Missing activity diagrams [message #585549 is a reply to message #45590] Thu, 08 November 2007 15:19 Go to previous message
composite.
Hope it helps..
Shilpa Toraskar
Re: Missing activity diagrams [message #585561 is a reply to message #45620] Fri, 09 November 2007 07:00 Go to previous message
Hi Shilpa,
Thanks a lot,
Roman
> composite.
> Hope it helps..
> Regards
> Shilpa Toraskar
Re: Missing activity diagrams [message #585623 is a reply to message #45650] Mon, 12 November 2007 14:01 Go to previous message
might take it out.
packages.
Shilpa
Re: Missing activity diagrams [message #585734 is a reply to message #45804] Wed, 21 November 2007 13:03 Go to previous message
Roman
> might take it out.
> packages.
> Shilpa
Previous Topic:Traversal of delivery process?
Next Topic:Automated tests of published OpenUP
Current Time: Mon Jul 21 21:20:57 EDT 2025
Powered by FUDForum. Page generated in 0.31478 seconds
