Home » Language IDEs » PHP Development Tools (PDT) » Bug debug in N20070822 night buid
Bug debug in N20070822 night buid [message #45377] Thu, 23 August 2007 05:07 Go to next message
I tryied to launch debug as PHP exe script using XDebug with the release in
the subject but it does not works.
If I try to add a new configuration in Run -> Open Debug Dialog -> PHP
Script, it gives this error:
http://img340.imageshack.us/img340/8172/pdteg0.jpg
All works with the last stable I20070816 release.
Re: Bug debug in N20070822 night buid [message #45412 is a reply to message #45377] Thu, 23 August 2007 05:11 Go to previous messageGo to next message
But sometime launching the debug it blocks itself with
http://img340.imageshack.us/img340/5391/pdtic0.jpg
I need to kill eclipse to let it works at the next debug time.
What is this???
Re: Bug debug in N20070822 night buid [message #45441 is a reply to message #45412] Thu, 23 August 2007 05:29 Go to previous messageGo to next message
> What is this???
I don't think I can help, but you'd better save your pictures to flickr
or so. Imageshack is about popups and spyware, so I and more people on
the internet never open such images.
Re: Bug debug in N20070822 night buid [message #45471 is a reply to message #45377] Thu, 23 August 2007 05:35 Go to previous messageGo to next message
Re: Bug debug in N20070822 night buid [message #45500 is a reply to message #45471] Thu, 23 August 2007 05:56 Go to previous messageGo to next message
> flickr or so. Imageshack is about popups and spyware, so I and more
> people on the internet never open such images.
I didn't know flickr, but the link I sent has no popups, it's you that have
problems with it. :)
Re: Bug debug in N20070822 night buid [message #45537 is a reply to message #45377] Thu, 23 August 2007 06:55 Go to previous message
Originally posted by: mep_eisen.web.de
I talked about it in another thread. Because of xdebug integration PDT
changed properties format. It does not understand older workspaces
properties. Maybe You can alter it by editing your workspaces directly
(somewhere at directory .metadata). I decided to debug eclipse via eclipse
and overwrote some local variables.
But You should be able to setup a complete new and clean workspace. You
should create two executables, one as zend default and one as xdebug
default Even if You are using only one debugger. It's because of some
other exceptions that will be thrown if there are is only one default.
Previous Topic:underline unitialized variables in Editor?
Next Topic:simple example for running a php web page
Current Time: Sat Aug 30 22:11:29 EDT 2025
Powered by FUDForum. Page generated in 0.04240 seconds
