Re: Bug debug in N20070822 night buid [message #45537 is a reply to message #45377] |
Thu, 23 August 2007 06:55  |
Originally posted by: mep_eisen.web.de
I talked about it in another thread. Because of xdebug integration PDT
changed properties format. It does not understand older workspaces
properties. Maybe You can alter it by editing your workspaces directly
(somewhere at directory .metadata). I decided to debug eclipse via eclipse
and overwrote some local variables.
But You should be able to setup a complete new and clean workspace. You
should create two executables, one as zend default and one as xdebug
default Even if You are using only one debugger. It's because of some
other exceptions that will be thrown if there are is only one default.
FUDForum. Page generated in 0.03858 seconds
