Home » Eclipse Projects » Rich Client Platform (RCP) » Using Splash Screen progress bar in 3.2 RC4
Using Splash Screen progress bar in 3.2 RC4 [message #450251] Wed, 31 May 2006 13:46 Go to next message
Hi All,
I am trying to use the nifty new progress bar with my splash screen on
launch by adding progress bar to my .product file on the branding page.
This is described in The Plug-in Development Environment under "Whats New".
I found that even though my splash screen (splash.bmp) is in the products
defining plug-in, I still have to specify that that is where it is (although
the text says I don't have to). Also, I set up the progress bar with
exactly the same coordinates I saw in the documentation, and I still don't
have the progress bar showing up - not when I use the launch, and not when I
export. Is this a bug, or am I missing something?
Thanks for the help.
Susan.
Re: Using Splash Screen progress bar in 3.2 RC4 [message #450254 is a reply to message #450251] Wed, 31 May 2006 15:45 Go to previous messageGo to next message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=138138
"Susan Foster" <susan.b.foster@intel.com> wrote in message
news:e5kkot$oe6$1@utils.eclipse.org...
> Hi All,
New".
(although
I
> Susan.
Re: Using Splash Screen progress bar in 3.2 RC4 [message #450255 is a reply to message #450254] Wed, 31 May 2006 16:00 Go to previous messageGo to next message
Boris,
I tried putting the line:
org.eclipse.ui/SHOW_PROGRESS_ON_STARTUP = true
into the ini file that matches my launcher name
So - myRCP.exe is my launcher and myRCP.ini is the ini file. This didn't
make the progress bar appear. I also tried putting it in the config.ini and
the eclipseproduct.ini - on the off chance that is what you meant by
"Enable startup progress reporting by putting the following line into your
preference customization file (often called plugin_customization.ini):
org.eclipse.ui/SHOW_PROGRESS_ON_STARTUP = true"
Still no go.
Susan.
"Boris Bokowski" <bokowski@ca.ibm.com> wrote in message
news:e5kro4$b52$1@utils.eclipse.org...
>> Hi All,
> New".
> (although
>> don't
>> when
> I
>> Susan.
Re: Using Splash Screen progress bar in 3.2 RC4 [message #450270 is a reply to message #450255] Thu, 01 June 2006 07:32 Go to previous messageGo to next message
by default, this is in the plugin_customization.ini. ex, in
plugins/org.eclipse.sdk_3.2.0.N20060531-0010/plugin_customiz ation.ini or
plugins/org.eclipse.platform_3.2.0.N20060531-0010/plugin_cus tomization.ini
it's:
org.eclipse.ui/SHOW_PROGRESS_ON_STARTUP=true
What happens when you do it without the spaces?
Later,
PW
Re: Using Splash Screen progress bar in 3.2 RC4 - Has anyone gotten this to work? [message #450314 is a reply to message #450270] Thu, 01 June 2006 11:57 Go to previous messageGo to next message
I tried the line without spaces:
in myPlugin.ini, which matches myPlugin.exe launcher, and in a
plugin_customization.ini file in my defining plugin. No joy. I also tried
it without org.eclipse.ui at the beginning.
I don't distribute org.eclipse.sdk OR org.eclipse.platform in my RCP, and I
certainly don't want to add them for a status bar on startup.
Has anyone gotten this to work, and if so, how did you do it?
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:e5mjap$pgp$1@utils.eclipse.org...
> it's:
> Later,
> PW
Re: Using Splash Screen progress bar in 3.2 RC4 - Has anyone gotten this to work? [message #450316 is a reply to message #450314] Thu, 01 June 2006 12:37 Go to previous messageGo to next message
In order for your plugin_customization.ini file to work, you need to tie
it to your product:
http://wiki.eclipse.org/index.php/RCP_FAQ#How_can_I_change_t he_default_UI_settings_for_the_perspective_bar_location.2C_f ast_view_bar_location.2C_etc.3F
Later,
PW
Re: Splashs Screen progress bar won't work on Headless build for 3.2RC7 [message #450657 is a reply to message #450251] Tue, 06 June 2006 11:53 Go to previous messageGo to next message
I have done the following:
1) In 3.2 set the myPlugin.properties file to use the progress bar
<splash
location="com.intel.iegd"
startupProgressRect="0,315,500,15"
startupMessageRect="7,0,441,20"
startupForegroundColor="FFFFFF" />
2) Added a plugin_customization.ini entry
3) Included an entry in my plugin.xml to use the plugin_customization.ini
<product
application="com.myPlugin"
name="My Plugin with Splasch Screen Progress Bar">
<property
name="preferenceCustomization"
value="plugin_customization.ini"/>
I now get a progress bar in my launch configuration (hooray), and when I
export using the export wizard but NOT when I do a headless build. I
suppose I am missing a plugin this depends on? If so, which one?
Everything else in my RCP works just fine with 3.2RC7.
Susan.
> Hi All,
> New". I found that even though my splash screen (splash.bmp) is in the
> products defining plug-in, I still have to specify that that is where it
> is (although the text says I don't have to). Also, I set up the progress
> bar with exactly the same coordinates I saw in the documentation, and I
> still don't have the progress bar showing up - not when I use the launch,
> and not when I export. Is this a bug, or am I missing something?
> Susan.
Re: Splashs Screen progress bar won't work on Headless build for 3.2RC7 [message #450714 is a reply to message #450657] Thu, 08 June 2006 12:11 Go to previous messageGo to next message
These values need to be put into the product extension:
so your plugin.xml should look something like this:
<product application="com.myPlugin" name="My Plugin with Splasch Screen
Progress Bar">
<property name="preferenceCustomization"
<property name="startupProgressRect" value="0,315,500,15"/>
<property name="startupMessageRect" value="7,0,441,20"/>
<property name="startupForegroundColor" value="FFFFFF"/>
</product>
Boris
news:e648dk$vc$1@utils.eclipse.org...
> <splash
> <product
> <property
> Susan.
> > Hi All,
progress
launch,
> > Susan.
Re: Splashs Screen progress bar won't work on Headless build for 3.2RC7 [message #455996 is a reply to message #450714] Tue, 10 October 2006 14:34 Go to previous messageGo to next message
It still only works in the development environment, not when I export it.
Any other ideas?
Susan.
news:e69i5r$16e$1@utils.eclipse.org...
> Progress Bar">
> </product>
> Boris
>> <splash
>> <product
>> <property
>> Susan.
>> > Hi All,
>> > it
> progress
> launch,
>> > Susan.
Re: Splashs Screen progress bar won't work on Headless build for 3.2RC7 [message #461647 is a reply to message #455996] Mon, 15 January 2007 07:24 Go to previous message
Originally posted by: julias.frb.br
susan, it looks like you didnt included the plugin_customization.ini in
the Build tab into the plugin.xml.
i did the same, and now it worked.
Julia
> Any other ideas?
> Susan.
>> Progress Bar">
>> </product>
>> Boris
>>> <splash
>>> <product
>>> <property
>>> Susan.
>>>> Hi All,
>>>> it
>> progress
>> launch,
>>>> Susan.
Previous Topic:How to set a view non-moveable programmatically
Next Topic:Maven build for a RCP plugin
Current Time: Fri Mar 21 04:30:05 EDT 2025
Powered by FUDForum. Page generated in 0.04981 seconds
