Home » Archived » XML Schema Definition (XSD) » How to parse a schema from an InputStream
How to parse a schema from an InputStream [message #45354] Tue, 25 May 2004 08:14 Go to next message
Originally posted by: hoe.zurich.ibm.com
How do I parse an XSDSchema from an InputStream instead of a URI? I've
tried to register a special URIConverter that returns the desired
stream, but that itself does not seem to be enough: e.g. somehow the
ability to access the cached XSD schema was lost.
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
new XSDResourceFactoryImpl());
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.setURIConverter(new SingletonURIConverter(in,
resourceSet.getURIConverter());
Resource resource =
resourceSet.getResource(SingletonURIConverter.SINGLETON_URI, true);
Christian
Re: How to parse a schema from an InputStream [message #45383 is a reply to message #45354] Tue, 25 May 2004 08:23 Go to previous message
Christian,
You can use ResourceSet.createResource followed by Resource.load(inputStream, options), and you can
use ResourceSet.getResource(..., false) to test for the need to create one.
> Resource resource =
> Christian
Re: How to parse a schema from an InputStream [message #587465 is a reply to message #45354] Tue, 25 May 2004 08:23 Go to previous message
Christian,
> Resource resource =
> Christian
Previous Topic:How to parse a schema from an InputStream
Next Topic:Retrieving user information
Current Time: Mon Jul 21 21:34:21 EDT 2025
Powered by FUDForum. Page generated in 0.04411 seconds
