Home » Modeling » M2T (model-to-text transformation) » run ant task passing variables
run ant task passing variables [message #45325] Mon, 12 May 2008 06:07 Go to next message
Hi, is it possible to invoke a Jet transformation using ant task
"jet.transform" passing variables to the transformation code (as it is if
you use wrapped method JET2Platform.runTransformationOnResource())?
thanks,
Stefano
Re: run ant task passing variables [message #45357 is a reply to message #45325] Mon, 12 May 2008 09:31 Go to previous message
Stefano:
No, it is not. There is an open bugzilla for this
(http://bugs.eclipse.org/175690), but I have not had time to do anything
with it. Technically, it would not be hard to do, though.
Paul
Previous Topic:Java class as source
Next Topic:Reverse engineer JET to model
Current Time: Sat Aug 30 22:09:20 EDT 2025
Powered by FUDForum. Page generated in 0.14525 seconds
