Re: [Teneo] Undo / Redo resource save issue [message #465358 is a reply to message #460669] |
Sun, 02 August 2009 21:35 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Matt,
I saw it.
I can make the resource smarter to assume that objects added to the resource are always new. This is also how EMF looks
at it.
I am quite busy at the moment, so it will take a week or so before I can spend time on this I am afraid.
In the meantime it should not be too difficult to extend the hibernate resource with your own implementation which takes
care of nulling the ids/versions of new objects in the resources. The new objects are stored in a separate arraylist in
the resource.
gr. Martin
Matt Biggs wrote:
> Martin,
> The problem with changing the ID of the object is that its not always
> easy to get to the model object.
> I was simply calling commandstack.undo() etc to undo / redo the model.
> As such in order to find the object i now have to walk the command
> stacks redo command, looping through all child commands etc searching
> for an AddCommand and then call the IdentifierCacheHandler's setId
> method on its affected objects. I eventually managed to do this but then
> ran into the 2nd exception i was receiving. So i'm still not sure if
> that solves the problem.
> I've knocked together a rather hacky :p testcase and model to reproduce
> the issue and attached it to bug 285372.
> Cheers
> Matt
> Martin Taal wrote:
>> Hi Matt,
>> For the containment what fails is that probably ClassB still has its
>> id/version set. So when resaving the instance (step 8) Hibernate will
>> try to do an update instead of a save. Hibernate does an update with
>> select and checks the count of the updated objects. The select
>> contains the id and version values as select criteria. As the object
>> has been removed the update will return 0 updated objects and
>> hibernate will throw the stale-object exception. So to solve this you
>> should set the id/version of the object to zero (between step 6 and
>> 7). If the object does not have an excplicit id/version eattribute
>> then you should call the IdentifierCacheHandler methods (check the
>> interface to see what method to call).
>> You could say the hibernate resource should set the id/version to
>> null/zero for new objects. However, as the resource can be filled with
>> queries and does not correspond to a xml resource it is not clear if a
>> new object in the resource is really a new object in the database.
>> Can you try if the above helps?
>> Regarding when it is a reference, this exception I do not yet
>> understand. I understand what it means but I do not understand why it
>> occurs.
>> Can you make a testcase (or a testmodel with pseudo code) to reproduce
>> this and enter a bugzilla for it? Then I can check it.in more detail.
>> gr. Martin
>> Matt Biggs wrote:
>>> Hi Martin,
>>> I'm having a bit of a problem with my resource when attempting to save.
>>> Pressume my model consists of ClassA which contains a collection of
>>> ClassB.
>>> 1. Create/Load a resource with a ClassA object in it.
>>> 2. Save resource. Ok
>>> 3. Add a new instance of ClassB to ClassA.
>>> 4. Save resource. Ok
>>> 5. Undo command stack (removing ClassB).
>>> 6. Save resource. Ok
>>> 7. Redo command stack (re-adding ClassB).
>>> 8. Save resource. FAIL.
>>> Depending on if the relationship is a containment one or not, i seem
>>> to get one of two exceptions.
>>> Containment gives me:
>>> org.hibernate.StaleObjectStateException: Row was updated or deleted
>>> by another transaction (or unsaved-value mapping was incorrect):
>>> [ClassB#1]
>>> Reference gives me:
>>> org.hibernate.HibernateException: Found two representations of same
>>> collection: ClassA.classb
>>> Is this something to do with cascading?
>>> cheers
>>> Matt
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Undo / Redo resource save issue [message #468022 is a reply to message #465358] |
Mon, 03 August 2009 16:25 |
Matt Biggs Messages: 71 Registered: July 2009 |
Member |
Hi Martin,
I think that would be a good solution then if that is how EMF does it.
Thats ok taking a week or so, i think you do a fantastic job responding
and releasing new features / bug fixes as quickly as you do. Maybe you
should take a holiday!
Matt
Martin Taal wrote:
> Hi Matt,
> I saw it.
> resource are always new. This is also how EMF looks at it.
> resource with your own implementation which takes care of nulling the
> in a separate arraylist in the resource.
> gr. Martin
> Matt Biggs wrote:
>> Martin,
>> then ran into the 2nd exception i was receiving. So i'm still not sure
>> if that solves the problem.
>> reproduce the issue and attached it to bug 285372.
>> Cheers
>> Matt
>> Martin Taal wrote:
>>> Hi Matt,
>>> will try to do an update instead of a save. Hibernate does an update
>>> with select and checks the count of the updated objects. The select
>>> with queries and does not correspond to a xml resource it is not
>>> clear if a new object in the resource is really a new object in the
>>> database.
>>> occurs.
>>> reproduce this and enter a bugzilla for it? Then I can check it.in
>>> more detail.
>>> gr. Martin
>>> Matt Biggs wrote:
>>>> Hi Martin,
>>>> ClassB.
>>>> [ClassB#1]
>>>> Reference gives me:
>>>> cheers
>>>> Matt
FUDForum. Page generated in 0.04323 seconds
