Home » Modeling » M2T (model-to-text transformation) » Re: jet editor java syntax coloring
Re: jet editor java syntax coloring [message #45295] Sat, 10 May 2008 15:17 Go to next message
Gary,
It's best to ask about it on the M2T newsgroup, which I've added to the
"to" list of the reply...
I think the containing project needs to have codegen.ecore on the classpath.
gary thompson wrote:
> Dear All
> I have just installed the jet editor from the emft in M7 and am
> pleasantly delighted with the highlighting of the code it gives me.
> However, it only syntax colors the jet code and not the embedded java.
> However,there seems to be a menu item 'set non-jet text content
> colorer...' but this brings up an empty list.... does anyone have
> further suggestion (information on using and configuring the editor
> seems to be sparse on the ground'
> Also, as an aside, I am trying to edit the ecore Class.javajet file
> and various included files with the jet editor and it is complaining
> that it can't identify the ecore genModel classes. How can I add these
> to the list of classes it understands (note I am still building the
> java source files with the emf jet installation)
> regards
> gary
Re: jet editor java syntax coloring [message #45384 is a reply to message #45295] Mon, 12 May 2008 16:17 Go to previous messageGo to next message
Ed Merks wrote:
> Gary,
Dear Ed
Many thanks for (re)directing me to the right place. Just as an aside and
as a newbie trying to work out what goes with what and how the whole m2t,
emft, emf, m2t etc acronym soup holds together is quite confusing. For
example just one question (there are more) there seems to be jet and jet2
but will jet2 replace jet in the emf framework?
regards
gary
Re: jet editor java syntax coloring [message #45411 is a reply to message #45384] Mon, 12 May 2008 16:36 Go to previous messageGo to next message
Gary,
Comments below.
> Ed Merks wrote:
>> Gary,
>> the "to" list of the reply...
> Dear Ed
> and as a newbie trying to work out what goes with what and how the
> whole m2t, emft, emf, m2t etc acronym soup holds together is quite
> confusing.
It's wholesome and nourishing soup! :-P Don't worry, if you go to the
wrong place, I'll notice and send you to the right one, so it's not a
problem.
> For example just one question (there are more) there seems to be jet
> and jet2 but will jet2 replace jet in the emf framework?
That's the idea, yes, but we've not had time to do that work since to a
large extent it should be a big no-op.
> regards
> gary
Re: jet editor java syntax coloring [message #45857 is a reply to message #45384] Sat, 17 May 2008 21:42 Go to previous messageGo to next message
Hello Gary,
I just checked into this.
This is indeed a silly bug, please can you open a bugzilla ? the list
should'nt have been empty.
I can provide a fix for this one as soon as you'll open the bugzilla.
Thank you very much.
Joel.
"gary thompson" <garyt.and.sarahb@gmail.com> wrote in message
news:5cf49300a5729a55434d5004b4657e8c$1@www.eclipse.org...
> Ed Merks wrote:
>> Gary,
> Dear Ed
> regards
> gary
Re: jet editor java syntax coloring [message #45890 is a reply to message #45857] Mon, 19 May 2008 04:19 Go to previous message
Joel Cheuoua wrote:
> Hello Gary,
Hi Joel
I have opened it https://bugs.eclipse.org/bugs/show_bug.cgi?id=232709
regards and thanks
gary
Previous Topic:JET Editor Preview
Next Topic:<java:class> in non source-folder
Current Time: Wed Jul 16 14:57:50 EDT 2025
Powered by FUDForum. Page generated in 0.30358 seconds
