Home » Archived » BIRT » Running Stand alone
Running Stand alone [message #45290] Mon, 13 June 2005 16:38 Go to next message
I'm trying to invoke the birt report engine in stand alone mode and I'm
getting an invalid report file error (see below)
It's complaining about the data source extension point.. the problem is i'm
not sure what this is supposed to be. Any help would be greatly
appreciated...The report runs fine within the plugin. Here's the snippet of
xml it's complaining about:
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc"
name="Data Source">
<property name="odaDriverClass">org.postgresql.Driver</property>
<property name="odaURL">jdbc:postgresql:wintox</property>
<property name="odaUser">wintox</property>
<encrypted-property
name="odaPassword">d2ludG94</encrypted-property>
</oda-data-source>
</data-sources>
org.eclipse.birt.report.engine.api.EngineException: The design file
reports/finalReport.rptdesign has error and can not be run.
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:92)
org.eclipse.birt.report.engine.api.ReportEngine.openReportDe sign(ReportEngine.java:212)
at RunReport.run(RunReport.java:110)
at RunReport.main(RunReport.java:75)
Caused by: Error.DesignFileException.INVALID_XML - 1 errors found!
1.) ( line = 17) org.xml.sax.SAXParseException (message :
org.eclipse.birt.report.data.oda.jdbc)
org.eclipse.birt.report.model.parser.DesignReader.read(Desig nReader.java:99)
org.eclipse.birt.report.model.parser.DesignReader.read(Desig nReader.java:146)
org.eclipse.birt.report.model.core.DesignSession.openDesign( DesignSession.java:174)
org.eclipse.birt.report.model.api.SessionHandle.openDesign(S essionHandle.java:94)
org.eclipse.birt.report.engine.parser.ReportParser.parse(Rep ortParser.java:83)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:87)
Re: Running Stand alone [message #45376 is a reply to message #45290] Mon, 13 June 2005 17:42 Go to previous messageGo to next message
For some reason the oda.jdbc plugin isn't registering with the
ServerPlatform for stand alone running
the flatfile and sampledb are though...I'm going to keep digging any ideas?
"Joe Rybacki" <Joe.Rybacki@dynetics.com> wrote in message
news:d8kqrf$mv3$1@news.eclipse.org...
> i'm not sure what this is supposed to be. Any help would be greatly
> of xml it's complaining about:
> <data-sources>
> <oda-data-source
> extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source">
> <property
> <encrypted-property
> </oda-data-source>
> </data-sources>
> at
> at
> at
> at
> at
> at
> at
> at
Re: Running Stand alone [message #45407 is a reply to message #45376] Mon, 13 June 2005 17:58 Go to previous messageGo to next message
Figured out what the problem was... When i was putting the postgres driver
into the jdbc plugin.xml I used < and > instead of &lt; and %gt; That
killed the sax parser on the plugin and made no extension point available to
the report. Quite a lot of digging to find that one...On to the next one :)
news:d8kujg$ra1$1@news.eclipse.org...
> ideas?
>> <data-sources>
>> <oda-data-source
>> <property
>> <encrypted-property
>> </oda-data-source>
>> </data-sources>
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: Running Stand alone [message #45437 is a reply to message #45407] Mon, 13 June 2005 18:20 Go to previous message
In figuring this out I should point out that to get it to run regardless of
the problem in the xml the following has to be invoked
Platform.getExtensionRegistry();
along with the two system properties being set:
-DRUN_UNDER_ECLIPSE=false
-DBIRT_HOME=birthome
news:d8kvha$s7n$1@news.eclipse.org...
> to the report. Quite a lot of digging to find that one...On to the next
> one :)
>> ideas?
>>> <data-sources>
>>> <oda-data-source
>>> <property
>>> <encrypted-property
>>> </oda-data-source>
>>> </data-sources>
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Previous Topic:report generation, and serialization
Next Topic:JAR Hell with BIRT
Current Time: Wed Jul 16 09:41:40 EDT 2025
Powered by FUDForum. Page generated in 0.03931 seconds
