Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » CDO Resources
CDO Resources [message #45286] |
Fri, 18 August 2006 04:17  |
Hi eike,
now I'am playing really a while with cdo and it is still cool.
But I have one problem:
I build a CDOHelper:
It can load a Resource from xmi file and save it to CDO.
But the otherway around is a bit tricky:
It always creates only something like the following:
<?xml version="1.0" encoding="ASCII"?>
<organisation:Organisation xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:organisation="organisation"
name="test">
<roles href="cdo://2#2"/>
<roles href="cdo://2#3"/>
<roles href="cdo://2#4"/>
<roles href="cdo://2#5"/>
<roles href="cdo://2#6"/>
<users href="cdo://2#7"/>
<users href="cdo://2#8"/>
<users href="cdo://2#9"/>
<processes href="cdo://2#10"/>
<processes href="cdo://2#11"/>
<processes href="cdo://2#12"/>
</organisation:Organisation>
Thats the code?
public void saveToFile(Organisation org, String string) {
try {
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap()
.put("organisation", new XMIResourceFactoryImpl());
resourceSet.getPackageRegistry().put("organisation",
OrganisationPackage.eINSTANCE);
URI fileURI = URI.createFileURI(new File(string)
.getAbsolutePath());
Resource poResource = resourceSet.createResource(fileURI);
poResource.getContents().add(org);
poResource.save(new HashMap());
} catch (Exception e) {
// TODO Auto-generated catch block
e.printStackTrace();
Re: CDO Resources [message #45573 is a reply to message #45542] |
Mon, 21 August 2006 08:44   |
Originally posted by: stepper.sympedia.de
Chris,
I've opened Bugzilla
https://bugs.eclipse.org/bugs/show_bug.cgi?id=154522 for it.
The main outcome is that you have to use something like
protected void preLoadResource(CDOResource cdoResource)
for (Iterator it = EcoreUtil.getAllContents(cdoResource, true);
it.hasNext();)
CDOPersistable persistable = (CDOPersistable) it.next();
persistable.cdoLoad();
before you try to copy the resource with EcoreUtil.
I have to admit that I'm not completely sure about the influence of
resolveProxies during the copy process.
It seems that it does not automatically lead to loading CDOPersistables
that are proxies.
Ed: Could you explain a bit?
Maybe CDO could override an EObject method so that resolving a proxy
would also load it.
At the moment cdoLoad is only called on explicit access to persistent
features.
Cheers
/Eike
Chris Lenz schrieb:
> I tried this:
> Organisation org =
> help.loadFromRepository("cdo:///squam/test/sampleorg");
> Organisation obj = (Organisation)EcoreUtil.copy(org);
> help.saveToFile(obj,"c:\\test.organisation");
> That does not work??
> Chris
> Eike Stepper schrieb:
>> Chris,
>> I think I know what happened to your exported objects. CDO generally
>> loads objects on demand (even contained ones). Only the root objects are
>> loaded together with the resource. That's why your root object is
>> properly serialized to XMI. The contained objects (roles, users,
>> processes) had not been loaded when you attached the root object to a
>> different resource. The proxy URIs still apply to the CDO resource but
>> that is no longer the container of the root. So they're not loaded
>> anymore and don't get resolved.
>> I really suggest that you EcoreUtil.copy() the CDO resource and attach
>> the copy to the XMI resource.
>> Cheers
>> /Eike
>> Chris Lenz schrieb:
>>> Hi eike,
>>> name="test">
>>> Thats the code?
>>> try {
Re: CDO Resources [message #45604 is a reply to message #45573] |
Mon, 21 August 2006 08:45   |
Ed,
I forgot to add you to the cc in the previous posting.
There's a question for you ;-)
Cheers
/Eike
> Chris,
> it.hasNext();)
> CDOPersistables that are proxies.
> would also load it.
> features.
> Cheers
> /Eike
> Chris Lenz schrieb:
>> I tried this:
>> Organisation org =
>> Chris
>>> Chris,
>>> are
>>> Cheers
>>> /Eike
>>> Chris Lenz schrieb:
>>>> Hi eike,
>>>> name="test">
>>>> Thats the code?
>>>> try {
Re: CDO Resources [message #45631 is a reply to message #45604] |
Mon, 21 August 2006 08:59   |
Eike,
By default, EcoreUtil.Copier should resolve proxies as it copies and
that should cause referenced resources to be loaded as necessary.
Eike Stepper wrote:
> Ed,
> Cheers
> /Eike
>> Chris,
>> it.hasNext();)
>> would also load it.
>> features.
>> Cheers
>> /Eike
>> Chris Lenz schrieb:
>>> I tried this:
>>> Organisation org =
>>> Chris
>>>> Chris,
>>>> objects are
>>>> Cheers
>>>> /Eike
>>>> Chris Lenz schrieb:
>>>>> Hi eike,
>>>>> name="test">
>>>>> Thats the code?
>>>>> try {
Re: CDO Resources [message #45661 is a reply to message #45631] |
Mon, 21 August 2006 09:12   |
Ed Merks schrieb:
> Eike,
In this case it is only one resource.
CDO uses proxy URIs for contained objects, too.
I assume that resolving such proxies doesn't do anything, because the
resource is already loaded from a ResourceSet perspective.
Thx
/Eike
> Eike Stepper wrote:
>> Ed,
>> Cheers
>> /Eike
>>> Chris,
>>> it.hasNext();)
>>> would also load it.
>>> persistent features.
>>> Cheers
>>> /Eike
>>> Chris Lenz schrieb:
>>>> I tried this:
>>>> Organisation org =
>>>> Chris
>>>>> Chris,
>>>>> objects are
>>>>> but
>>>>> attach
>>>>> Cheers
>>>>> /Eike
>>>>> Chris Lenz schrieb:
>>>>>> Hi eike,
>>>>>> name="test">
>>>>>> Thats the code?
>>>>>> try {
Re: CDO Resources [message #45691 is a reply to message #45573] |
Mon, 21 August 2006 09:15   |
Chris,
The solution I outlined below will work, but is unefficient for large
resources.
It loads the resource object by object, each causing a signal to and
from the server.
If you want you can open an enhancement request asking for optimized
"Preloading Support".
Cheers
/Eike
> Chris,
> it.hasNext();)
> would also load it.
> features.
> Cheers
> /Eike
> Chris Lenz schrieb:
>> I tried this:
>> Organisation org =
>> Chris
>>> Chris,
>>> are
>>> Cheers
>>> /Eike
>>> Chris Lenz schrieb:
>>>> Hi eike,
>>>> name="test">
>>>> Thats the code?
>>>> try {
Re: CDO Resources [message #45724 is a reply to message #45661] |
Mon, 21 August 2006 12:58   |
--------------080402090308060800080703
Eike,
Whenever a proxy is resolved, if the result is different from the
original object, it will replace the original, as in this EcoreEList method:
protected EObject resolve(int index, EObject eObject)
EObject resolved = resolveProxy(eObject);
if (resolved != eObject)
Object oldObject = data[index];
assign(index, validate(index, resolved));
didSet(index, resolved, oldObject);
So the code doesn't care whether it's in the same resource or not...
Eike Stepper wrote:
> Ed Merks schrieb:
>> Eike,
> Thx
> /Eike
>> Eike Stepper wrote:
>>> Ed,
>>> Cheers
>>> /Eike
>>>> Chris,
>>>> it.hasNext();)
>>>> proxy would also load it.
>>>> Cheers
>>>> /Eike
>>>> Chris Lenz schrieb:
>>>>> I tried this:
>>>>> Organisation org =
>>>>> Chris
>>>>>> Chris,
>>>>>> objects are
>>>>>> to a
>>>>>> resource but
>>>>>> attach
>>>>>> Cheers
>>>>>> /Eike
>>>>>> Chris Lenz schrieb:
>>>>>>> Hi eike,
>>>>>>> name="test">
>>>>>>> Thats the code?
>>>>>>> try {
<html>
<head>
http-equiv="Content-Type">
</head>
Eike,<br>
<br>
method:<br>
<blockquote><small>
Re: CDO Resources [message #45996 is a reply to message #45691] |
Tue, 22 August 2006 05:21   |
We should use getAllProperContents instead of getAllContents
Now I am implementing the load and save action into the CDOExplorer.
Can I add this to repository, and how can I do this?
Chris
> Chris,
> resources.
> from the server.
> Cheers
> /Eike
>> Chris,
>> it.hasNext();)
>> would also load it.
>> features.
>> Cheers
>> /Eike
>> Chris Lenz schrieb:
>>> I tried this:
>>> Organisation org =
>>> Chris
>>>> Chris,
>>>> are
>>>> Cheers
>>>> /Eike
>>>> Chris Lenz schrieb:
>>>>> Hi eike,
>>>>> name="test">
>>>>> Thats the code?
>>>>> try {
Re: CDO Resources [message #46087 is a reply to message #45996] |
Tue, 22 August 2006 07:06   |
Chris,
If you send me a patch, I can review and apply it.
Cheers
/Eike
> Chris
>> Chris,
>> resources.
>> from the server.
>> Cheers
>> /Eike
>>> Chris,
>>> it.hasNext();)
>>> would also load it.
>>> features.
>>> Cheers
>>> /Eike
>>> Chris Lenz schrieb:
>>>> I tried this:
>>>> Organisation org =
>>>> Chris
>>>>> Chris,
>>>>> are
>>>>> Cheers
>>>>> /Eike
>>>>> Chris Lenz schrieb:
>>>>>> Hi eike,
>>>>>> name="test">
>>>>>> Thats the code?
>>>>>> try {
Re: CDO Resources [message #48451 is a reply to message #45455] |
Mon, 04 September 2006 12:48   |
--------------020300090008000205060502
Import Export Button patch:
Would it be possible to implement the delete function for the cdo
resources? Can I do it myself, where have I to look for??
Thanx Chris
> Chris,
> If you think that import and export buttons in the CDO Explorer are a
> good idea, please feel free to open an enhancement request.
> Cheers
> /Eike
> Chris Lenz schrieb:
>> Hi eike,
>> name="test">
>> Thats the code?
>> try {
name="patch.txt"
Content-Disposition: inline;
filename="patch.txt"
### Eclipse Workspace Patch 1.0
#P org.eclipse.emf.cdo.examples.ui
Index: src/org/eclipse/emf/cdo/examples/ui/internal/UIUtils.java
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=
RCS file: /cvsroot/technology/org.eclipse.emft/cdo/examples/org.eclips e.e=
mf.cdo.examples.ui/src/org/eclipse/emf/cdo/examples/ui/inter nal/UIUtils.j=
ava,v
retrieving revision 1.7
diff -u -r1.7 UIUtils.java
--- src/org/eclipse/emf/cdo/examples/ui/internal/UIUtils.java 1 Sep 2006 =
10:00:09 -0000 1.7
+++ src/org/eclipse/emf/cdo/examples/ui/internal/UIUtils.java 4 Sep 2006 =
16:45:42 -0000
@@ -10,19 +10,36 @@
package org.eclipse.emf.cdo.examples.ui.internal;
=20
+import java.io.File;
+import java.util.HashMap;
+import java.util.Iterator;
=20
+import org.eclipse.emf.cdo.client.CDOPersistable;
+import org.eclipse.emf.cdo.client.CDOResource;
import org.eclipse.emf.cdo.client.ResourceInfo;
import org.eclipse.emf.cdo.client.ResourceManager;
+import org.eclipse.emf.cdo.examples.client.internal.ExampleClientPl ugin;=
import org.eclipse.emf.cdo.examples.ui.internal.editors.CDOEditor;
import org.eclipse.emf.cdo.examples.ui.internal.editors.CDOEditorIn put;
import org.eclipse.emf.cdo.examples.ui.internal.wizards.CDONewWizar d;
+import org.eclipse.emf.common.util.URI;
+import org.eclipse.emf.ecore.EObject;
+import org.eclipse.emf.ecore.resource.Resource;
+import org.eclipse.emf.ecore.resource.ResourceSet;
+import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
+import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.emf.edit.ui.provider.ExtendedImageRegistry;
+import org.eclipse.jface.dialogs.IInputValidator;
+import org.eclipse.jface.dialogs.InputDialog;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.jface.resource.ImageDescriptor;
import org.eclipse.jface.viewers.Viewer;
+import org.eclipse.jface.window.Window;
import org.eclipse.jface.wizard.WizardDialog;
+import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Image;
+import org.eclipse.swt.widgets.FileDialog;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.ui.IEditorPart;
import org.eclipse.ui.IWorkbench;
@@ -30,102 +47,201 @@
import org.eclipse.ui.IWorkbenchWindow;
import org.eclipse.ui.PartInitException;
import org.eclipse.ui.PlatformUI;
+import org.eclipse.ui.internal.Workbench;
import org.eclipse.ui.views.properties.IPropertySheetPage;
import org.eclipse.ui.views.properties.PropertySheetPage;
=20
-public class UIUtils
- public static void openCDONewWizard(ResourceManager resourceManager, b=
oolean commit)
- CDONewWizard wizard =3D new CDONewWizard(resourceManager, commit);
- wizard.init(PlatformUI.getWorkbench(), null);
- wizard.setNeedsProgressMonitor(true);
- WizardDialog dialog =3D new WizardDialog(new Shell(), wizard);
- dialog.create();
- dialog.open();
- public static void openCDONewWizard()
- openCDONewWizard(null, true);
- public static IEditorPart openCDOEditor(ResourceInfo resourceInfo)
- IWorkbench workbench =3D PlatformUI.getWorkbench();
- IWorkbenchWindow activeWorkbenchWindow =3D workbench.getActiveWorkbe=
nchWindow();
- IWorkbenchPage activePage =3D activeWorkbenchWindow.getActivePage();=
- try
- return activePage.openEditor(new CDOEditorInput(resourceInfo), CDO=
Editor.EDITOR_ID);
- catch (PartInitException ex)
- MessageDialog.openError(new Shell(), "CDO Explorer", "Can't open C=
DO Editor for "
- + resourceInfo);
- return null;
- public static ImageDescriptor getImageDescriptor(String key)
- return ExtendedImageRegistry.getInstance().getImageDescriptor(
- ExampleUIActivator.INSTANCE.getImage(key));
- public static Image getImage(String key)
- return ExtendedImageRegistry.getInstance().getImage(ExampleUIActiva t=
- public static void refreshViewer(final Viewer viewer)
- Display display =3D viewer.getControl().getDisplay();
- display.asyncExec(new Runnable()
- public void run()
- if (viewer !=3D null && !viewer.getControl().isDisposed())
- try
- viewer.refresh();
- catch (Exception ex)
- ex.printStackTrace();
- public static void refreshPropertySheetPage(final IPropertySheetPage p=
ropertySheetPage)
- if (propertySheetPage instanceof PropertySheetPage)
- final PropertySheetPage page =3D (PropertySheetPage)propertySheetP=
age;
- Display display =3D page.getControl().getDisplay();
- public void run()
- if (page !=3D null && !page.getControl().isDisposed())
- try
- page.refresh();
+public class UIUtils {
+ public static void openCDONewWizard(ResourceManager resourceManager,
+ boolean commit) {
+ CDONewWizard wizard =3D new CDONewWizard(resourceManager, commit);
+ wizard.init(PlatformUI.getWorkbench(), null);
+ wizard.setNeedsProgressMonitor(true);
+ WizardDialog dialog =3D new WizardDialog(new Shell(), wizard);
+ dialog.create();
+ dialog.open();
+ public static void openCDONewWizard() {
+ openCDONewWizard(null, true);
+ public static IEditorPart openCDOEditor(ResourceInfo resourceInfo) {
+ IWorkbench workbench =3D PlatformUI.getWorkbench();
+ IWorkbenchWindow activeWorkbenchWindow =3D workbench
+ .getActiveWorkbenchWindow();
+ IWorkbenchPage activePage =3D activeWorkbenchWindow.getActivePage();
+ try {
+ return activePage.openEditor(new CDOEditorInput(resourceInfo),
+ CDOEditor.EDITOR_ID);
+ } catch (PartInitException ex) {
+ MessageDialog.openError(new Shell(), "CDO Explorer",
+ "Can't open CDO Editor for " + resourceInfo);
+ return null;
+ public static ImageDescriptor getImageDescriptor(String key) {
+ return ExtendedImageRegistry.getInstance().getImageDescriptor(
+ ExampleUIActivator.INSTANCE.getImage(key));
+ public static Image getImage(String key) {
+ return ExtendedImageRegistry.getInstance().getImage(
+ public static void importCDOResource() {
+ try {
+ ResourceSet resourceSet =3D new ResourceSetImpl();
+ Shell shell =3D Workbench.getInstance().getActiveWorkbenchWindow()
+ .getActivePage().getActivePart().getSite().getShell();
+ FileDialog fileChooser =3D new FileDialog(shell, SWT.SAVE);
+ String fileName =3D fileChooser.open();
+ if (fileName =3D=3D null) {
+ return;
+ URI fileURI =3D URI.createFileURI(new File(fileName)
+ .getAbsolutePath());
+ Resource poResource =3D resourceSet.getResource(fileURI, true);
+ EObject org =3D (EObject) poResource.getContents().get(0);
+ createSampleResource(org);
+ } catch (Exception e) {
+ e.printStackTrace();
+ private static void createSampleResource(EObject org) {
+ InputDialog d =3D new InputDialog(shell, "Resource Name",
+ "Geben sie den Resource Name ein", "cdo:///",
+ new CDOValidator());
+ if (d.open() =3D=3D Window.OK) {
+ ResourceManager resourceManager =3D ExampleClientPlugin
+ .createResourceManager(resourceSet);
+ CDOResource resource =3D (CDOResource) resourceSet.createResource(URI=
+ .createURI(d.getValue()));
+ resource.getContents().add(org);
+ resourceManager.commit();
+ public static void saveCDOResource(ResourceInfo info) {
+ try {
+ EObject obj =3D loadFromRepository(info);
+ * resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap=
+ * .put("xmi", new XMIResourceFactoryImpl());
+ * resourceSet.getPackageRegistry().put(
+ * obj.eClass().getEPackage().getNsURI(),
+ * obj.eClass().getEPackage());
+ return;
+ Resource poResource =3D resourceSet.createResource(fileURI);
+ poResource.getContents().add(obj);
+ poResource.save(new HashMap());
+ // TODO Auto-generated catch block
+ private static EObject loadFromRepository(ResourceInfo info) {
+ CDOResource resource =3D (CDOResource) resourceSet.getResource(URI
+ .createURI(getResourceURI(info)), true);
+ EObject org =3D (EObject) resource.getContents().get(0);
+ preLoadResource(resource);
+ return org;
+ private static String getResourceURI(ResourceInfo resourceInfo) {
+ return "cdo://" + resourceInfo.getPath();
+ private static void preLoadResource(CDOResource cdoResource) {
+ int i =3D 1;
+ int old =3D 0;
+ while (old < i) {
+ old =3D i;
+ i =3D 0;
+ for (Iterator it =3D EcoreUtil
+ .getAllProperContents(cdoResource, true); it.hasNext();) {
+ CDOPersistable persistable =3D (CDOPersistable) it.next();
+ persistable.cdoLoad();
+ i++;
+ static class CDOValidator implements IInputValidator {
+ * Validates the String. Returns null for no error, or an error messag=
e
+ *=20
+ * @param newText
+ * the String to validate
+ * @return String
+ public String isValid(String newText) {
+ if (newText.startsWith("cdo:///")) {
+ return null;
+ } else
+ return "must start with cdo:///";
+ public static void refreshViewer(final Viewer viewer) {
+ Display display =3D viewer.getControl().getDisplay();
+ display.asyncExec(new Runnable() {
+ public void run() {
+ if (viewer !=3D null && !viewer.getControl().isDisposed()) {
+ try {
+ viewer.refresh();
+ } catch (Exception ex) {
+ ex.printStackTrace();
+ public static void refreshPropertySheetPage(
+ final IPropertySheetPage propertySheetPage) {
+ if (propertySheetPage instanceof PropertySheetPage) {
+ final PropertySheetPage page =3D (PropertySheetPage) propertySheetPag=
e;
+ Display display =3D page.getControl().getDisplay();
+ if (page !=3D null && !page.getControl().isDisposed()) {
+ try {
+ page.refresh();
Index: src/org/eclipse/emf/cdo/examples/ui/internal/views/CDOExplor er.jav=
a
mf.cdo.examples.ui/src/org/eclipse/emf/cdo/examples/ui/inter nal/views/CDO=
Explorer.java,v
retrieving revision 1.6
diff -u -r1.6 CDOExplorer.java
--- src/org/eclipse/emf/cdo/examples/ui/internal/views/CDOExplor er.java 1=
Sep 2006 10:00:09 -0000 1.6
+++ src/org/eclipse/emf/cdo/examples/ui/internal/views/CDOExplor er.java 4=
Sep 2006 16:45:42 -0000
@@ -17,6 +17,7 @@
import org.eclipse.emf.cdo.examples.ui.internal.ResourceLabelProvid er;
import org.eclipse.emf.cdo.examples.ui.internal.UIUtils;
import org.eclipse.emf.cdo.examples.ui.internal.actions.CDOCreateRe sourc=
eAction;
import org.eclipse.jface.action.Action;
import org.eclipse.jface.action.IMenuListener;
import org.eclipse.jface.action.IMenuManager;
@@ -51,6 +52,10 @@
private Action deleteResourceAction;
=20
private Action openResourceAction;
+ =20
+ private Action importResourceAction;
+ =20
+ private Action exportResourceAction;
=20
// private Channel cdoResChannel;
=20
@@ -115,6 +120,8 @@
manager.add(newResourceAction);
manager.add(deleteResourceAction);
+ manager.add(exportResourceAction);
+ manager.add(importResourceAction);
manager.add(new Separator());
// Other plug-ins can contribute there actions here
manager.add(new Separator(IWorkbenchActionConstants.MB_ADDITIONS));
@@ -123,7 +130,7 @@
private void fillLocalToolBar(IToolBarManager manager)
- manager.add(deleteResourceAction);
+ manager.add(deleteResourceAction); =20
=20
private void makeActions()
@@ -154,9 +161,44 @@
+ importResourceAction =3D new Action()
+ public void run()
+ ISelection selection =3D viewer.getSelection();
+ Object obj =3D ((IStructuredSelection)selection).getFirstElement=
+ UIUtils.importCDOResource();
+ };=20
+ importResourceAction.setText("Import CDO Resource");
+ importResourceAction.setToolTipText("Import CDO Resource");
+ importResourceAction.setImageDescriptor(UIUtils
+ .getImageDescriptor("full/ctool16/ImportCDOResource"));
+ exportResourceAction =3D new Action()
+ public void run()
+ if (obj instanceof ResourceInfo)
+ UIUtils.saveCDOResource((ResourceInfo)obj);
+ };=20
+ exportResourceAction.setText("Export CDO Resource");
+ exportResourceAction.setToolTipText("Export CDO Resource");
+ exportResourceAction.setImageDescriptor(UIUtils
+ .getImageDescriptor("full/ctool16/SaveCDOResource"));
=20
- private void hookDoubleClickAction()
+ // TODO Auto-generated method stub
+ return null;
+private void hookDoubleClickAction()
viewer.addDoubleClickListener(new IDoubleClickListener()
@@ -176,4 +218,4 @@
viewer.getControl().setFocus();
\ No newline at end of file
Index: icons/full/ctool16/ImportCDOResource.gif
RCS file: icons/full/ctool16/ImportCDOResource.gif
diff -N icons/full/ctool16/ImportCDOResource.gif
--- /dev/null 1 Jan 1970 00:00:00 -0000
+++ icons/full/ctool16/ImportCDOResource.gif 1 Jan 1970 00:00:00 -0000
@@ -0,0 +1,4 @@
+GIF89a=10=00=10=00=C6N=00,u=BA+|=AFyn>zn>zn?zo>zo?&=84=BA}o > =88=C4?q=3D=
=1D=8C=CB=85u<^v=A3=17=94=D5=8Bw;=14=98=DCcz=A7?z9<=89=D08=8C=D4f~=A8;?=D3=
=96|8j=82=ACm=84=AD=A0=825=A5=844q=88=B1s=89=B2=AA=863=AE=88 1=BF=7F?=B2=8A=
0|=92=B8~=93=BAE=A9=E9?=97=BC=84=9A=BFi=A4=DB=8C=A0=C3r=A9=D Cw=AA=D1r=AB=DC=
=BF=9F_v=AD=DC=91=A5=C7=85=B2=E1=83=B4=E1=FF=9F?=94=BC=E4=9C =C7=F0=FF=BF?=
=AF=D8=F7=FF=DF?=DC=E7=F7=DD=E7=F7=DE=E8=F7=DE=E8=F8=DF=E8=F 7=E1=EA=F8=E4=
=EC=F9=E6=EE=F9=E7=EE=F9=FF=FF_=EA=F0=F9=FF=FF=7F=ED=F2=FA=F 0=F5=FB=F2=F5=
=FB=F3=F5=FB=F2=F6=FB=F3=F6=FB=F5=F8=FB=F7=F9=FB=F8=F9=FB=F8 =F9=FC=F9=FA=FC=
=FF=FF=FF=FF=FF=FF=FF=FF=FF=FF=FF=FF=FF=FF=FF=FF=FF=FF=FF=FF =FF=FF=FF=FF=FF=
!=F9=04=01=00=00=7F=00,=00=00=00=00=10=00=10=00=00=07=A9=80= 7F=82=83=84=85=
=84!=88=89=88,, =85!M=91=924,B 4=84=1FJLK=9B=8C1@ =A2=83=1EI.%=19
+=95@@66=8E=82=1BEHGHF=A2 =AF=A3=82=1AD.(&"=1D4=B9=97=82$'53+$C=CEC=B8=83=
=10=142/=13=10=C1=1D=18=11A=17=83=0E)=CA+=0E?=E5?>?=12=83=0B=E1=CB=0B=D9=DB=
=3D=0F=83 =ED+ <=F9=FA=0C=83=07=F6=07#8T=D8=91C=87=82A=01,=C0ha!=C0
+=1C=0F!"=18=A4=02=C0B=0B*=0C=14( =A0=00?=01=86B=16
+=04=00;
Index: icons/full/ctool16/SaveCDOResource.gif
RCS file: icons/full/ctool16/SaveCDOResource.gif
diff -N icons/full/ctool16/SaveCDOResource.gif
+++ icons/full/ctool16/SaveCDOResource.gif 1 Jan 1970 00:00:00 -0000
@@ -0,0 +1,4 @@
+=04=00;
--------------020300090008000205060502--
Re: CDO Resources [message #48867 is a reply to message #48451] |
Wed, 06 September 2006 15:20   |
Chris,
The CVS HEAD version addresses both enhancements, import/export and delete.
You can alternatively download zips from
http://emft.eclipse.org/technology/emft/downloads/downloads- viewer.php?proj=cdo&s=1.0.0/N200609061442/
I'd appreciate if you could verify that the new features satisfy your needs.
There is a remaining issue with CDOEditors that still have resources already
deleted by other sessions, but I will fix that in another Bugzilla.
Btw. resource deletions have been rather complicated to implement because
objects in other resources can be affected by this operation. The current
approach automatically removes such references and finally transmits
invalidation notifications for changed objects.
Resource deletion occurs in a transaction. Currently it can leave orphaned
objects in the database. I will implement a persistent garbage collection
in the scope of another Bugzilla.
Cheers
/Eike
> Thanx Chris
>> Chris,
>> Cheers
>> /Eike
>> Chris Lenz schrieb:
>>> Hi eike,
>>> name="test">
>>> Thats the code?
>>> try {
Re: CDO Resources [message #49385 is a reply to message #48867] |
Fri, 08 September 2006 05:22  |
Hi Eike,
Thanx for that great work ;-)
Chris
> Chris,
> needs.
> already
> Cheers
> /Eike
>> Thanx Chris
>>> Chris,
>>> Cheers
>>> /Eike
>>> Chris Lenz schrieb:
>>>> Hi eike,
>>>> name="test">
>>>> Thats the code?
>>>> try {
Re: CDO Resources [message #585518 is a reply to message #45286] |
Fri, 18 August 2006 09:49  |
Chris,
What is the exact URI you want to save to (does it end in ".organisation")?
Is this executed against the latest CVS sources?
There is a recent change in how eResource() works for CDOPersistable
objects.
With your info below I recognize that there might be issues with
re-attached objects.
Currently an object always returns the CDOResource it was initially
attached to.
Please open a Bugzilla for this.
The latest CVS sources contain a number of bug fixes (we have
integration tests now).
Please try if the problem persists with that version.
Did you try to copy the objects from a CDOResource to the XMIResource?
There are newsgroup threads discussing that.
If all does not help, could you send me a zip with the projects so that
I can play around with them?
Cheers
/Eike
Chris Lenz schrieb:
> Hi eike,
> name="test">
> Thats the code?
> try {
Re: CDO Resources [message #585597 is a reply to message #45286] |
Fri, 18 August 2006 15:02  |
Chris,
Cheers
/Eike
Chris Lenz schrieb:
> Hi eike,
> name="test">
> Thats the code?
> try {
Re: CDO Resources [message #585604 is a reply to message #45286] |
Fri, 18 August 2006 15:11  |
Chris,
Cheers
/Eike
Chris Lenz schrieb:
> Hi eike,
> name="test">
> Thats the code?
> try {
Re: CDO Resources [message #585637 is a reply to message #45483] |
Mon, 21 August 2006 06:05  |
I tried this:
Organisation org =
Chris
> Chris,
> Cheers
> /Eike
> Chris Lenz schrieb:
>> Hi eike,
>> name="test">
>> Thats the code?
>> try {
Re: CDO Resources [message #585654 is a reply to message #45542] |
Chris,
it.hasNext();)
that are proxies.
would also load it.
features.
Cheers
/Eike
Chris Lenz schrieb:
> I tried this:
> Organisation org =
> Chris
>> Chris,
>> Cheers
>> /Eike
>> Chris Lenz schrieb:
>>> Hi eike,
>>> name="test">
>>> Thats the code?
>>> try {
Re: CDO Resources [message #585669 is a reply to message #45573] |
Ed,
Cheers
/Eike
> Chris,
> it.hasNext();)
> would also load it.
> features.
> Cheers
> /Eike
> Chris Lenz schrieb:
>> I tried this:
>> Organisation org =
>> Chris
>>> Chris,
>>> are
>>> Cheers
>>> /Eike
>>> Chris Lenz schrieb:
>>>> Hi eike,
>>>> name="test">
>>>> Thats the code?
>>>> try {
Re: CDO Resources [message #585682 is a reply to message #45604] |
Eike,
Eike Stepper wrote:
> Ed,
> Cheers
> /Eike
>> Chris,
>> it.hasNext();)
>> would also load it.
>> features.
>> Cheers
>> /Eike
>> Chris Lenz schrieb:
>>> I tried this:
>>> Organisation org =
>>> Chris
>>>> Chris,
>>>> objects are
>>>> Cheers
>>>> /Eike
>>>> Chris Lenz schrieb:
>>>>> Hi eike,
>>>>> name="test">
>>>>> Thats the code?
>>>>> try {
Re: CDO Resources [message #585701 is a reply to message #45631] |
Ed Merks schrieb:
> Eike,
Thx
/Eike
> Eike Stepper wrote:
>> Ed,
>> Cheers
>> /Eike
>>> Chris,
>>> it.hasNext();)
>>> would also load it.
>>> Cheers
>>> /Eike
>>> Chris Lenz schrieb:
>>>> I tried this:
>>>> Organisation org =
>>>> Chris
>>>>> Chris,
>>>>> objects are
>>>>> but
>>>>> attach
>>>>> Cheers
>>>>> /Eike
>>>>> Chris Lenz schrieb:
>>>>>> Hi eike,
>>>>>> name="test">
>>>>>> Thats the code?
>>>>>> try {
Re: CDO Resources [message #585716 is a reply to message #45573] |
Chris,
resources.
from the server.
Cheers
/Eike
> Chris,
> it.hasNext();)
> would also load it.
> features.
> Cheers
> /Eike
> Chris Lenz schrieb:
>> I tried this:
>> Organisation org =
>> Chris
>>> Chris,
>>> are
>>> Cheers
>>> /Eike
>>> Chris Lenz schrieb:
>>>> Hi eike,
>>>> name="test">
>>>> Thats the code?
>>>> try {
Re: CDO Resources [message #585736 is a reply to message #45661] |
Eike,
Eike Stepper wrote:
> Ed Merks schrieb:
>> Eike,
> Thx
> /Eike
>> Eike Stepper wrote:
>>> Ed,
>>> Cheers
>>> /Eike
>>>> Chris,
>>>> it.hasNext();)
>>>> Cheers
>>>> /Eike
>>>> Chris Lenz schrieb:
>>>>> I tried this:
>>>>> Organisation org =
>>>>> Chris
>>>>>> Chris,
>>>>>> objects are
>>>>>> to a
>>>>>> resource but
>>>>>> attach
>>>>>> Cheers
>>>>>> /Eike
>>>>>> Chris Lenz schrieb:
>>>>>>> Hi eike,
>>>>>>> name="test">
>>>>>>> Thats the code?
>>>>>>> try {
<html>
<head>
</head>
Eike,<br>
<br>
method:<br>
<blockquote><small>
Re: CDO Resources [message #585878 is a reply to message #45691] |
Chris
> Chris,
> resources.
> from the server.
> Cheers
> /Eike
>> Chris,
>> it.hasNext();)
>> would also load it.
>> features.
>> Cheers
>> /Eike
>> Chris Lenz schrieb:
>>> I tried this:
>>> Organisation org =
>>> Chris
>>>> Chris,
>>>> are
>>>> Cheers
>>>> /Eike
>>>> Chris Lenz schrieb:
>>>>> Hi eike,
>>>>> name="test">
>>>>> Thats the code?
>>>>> try {
Re: CDO Resources [message #585890 is a reply to message #45996] |
Tue, 22 August 2006 05:31  |
preLoadResource loads only toplevel elements
myworkaround:
protected static void preLoadResource(CDOResource cdoResource) {
int i = 1;
int old = 0;
while (old < i) {
old = i;
i = 0;
i++;
Re: CDO Resources [message #585921 is a reply to message #45996] |
Chris,
Cheers
/Eike
> Chris
>> Chris,
>> resources.
>> from the server.
>> Cheers
>> /Eike
>>> Chris,
>>> it.hasNext();)
>>> would also load it.
>>> features.
>>> Cheers
>>> /Eike
>>> Chris Lenz schrieb:
>>>> I tried this:
>>>> Organisation org =
>>>> Chris
>>>>> Chris,
>>>>> are
>>>>> Cheers
>>>>> /Eike
>>>>> Chris Lenz schrieb:
>>>>>> Hi eike,
>>>>>> name="test">
>>>>>> Thats the code?
>>>>>> try {
Re: CDO Resources [message #585938 is a reply to message #46026] |
Tue, 22 August 2006 07:14  |
My proposal for a preLoadResource loads all objects contained in that resource.
I verified this with a test case.
If your resource does not get fully loaded, please explain a bit more.
> myworkaround:
> int i = 1;
> int old = 0;
> while (old < i) {
> old = i;
> i = 0;
> i++;
This seems a bit of a brute force ;-)
The effort can be O(n*n) where n is the number of objects in the resource.
Cheers
/Eike
Re: CDO Resources [message #585950 is a reply to message #46117] |
Tue, 22 August 2006 09:22  |
Ok in my case it loads not objects contained in that resource, I try to
explain.
If the resource looks like the following:
toplevelElement
-subelement
-subsubelement
-subsubsubelement
-subelement
-subsubelement
-subsubsubelement
in the first iteration it loads the toplevelelement and all subelements.
in the next iteration it loads on level more, it loads also the
subsubelements.
and so on.
I hope that's understandable!
Yes it's like bruteforce, it's horrible :-)
Chris
> resource.
>> myworkaround:
>> int i = 1;
>> int old = 0;
>> while (old < i) {
>> old = i;
>> i = 0;
>> it.hasNext();) {
>> i++;
> Cheers
> /Eike
Re: CDO Resources [message #586045 is a reply to message #46147] |
Tue, 22 August 2006 11:39  |
> explain.
> toplevelElement
> -subelement
> -subsubelement
> -subsubsubelement
> -subelement
> -subsubelement
> -subsubsubelement
> subsubelements.
> and so on.
I already understood that your method works like that ;-)
But I asked you to explain, what exactly did not work with my method.
As I said, it works for me (and performs better than yours).
Can you provide a zip with the source code that you used to test my method?
Cheers
/Eike
Re: CDO Resources [message #586055 is a reply to message #46293] |
Wed, 23 August 2006 04:15  |
This your model have more than two levels.
My application is very complex, but I try to create some easier.
Chris
>> explain.
>> toplevelElement
>> -subelement
>> -subsubelement
>> -subsubsubelement
>> -subelement
>> -subsubelement
>> -subsubsubelement
>> subsubelements.
>> and so on.
> Cheers
> /Eike
Re: CDO Resources [message #586084 is a reply to message #46323] |
Wed, 23 August 2006 05:54  |
Chris,
Please don't spend any more effort for constructing an example!
I could reproduce your issue in /org.eclipse.emf.cdo.tests/src/org/eclipse/emf/cdo/tests/mod el1/SerializationTest.java
Look for testExportThreeLevels().
The issue is caused because EObject.eContents() does not call cdoLoad().
I've fixed this in CDOPersistentImpl:
* @ADDED
public EList eContents()
cdoLoad();
return super.eContents();
The changes are committed to CVS.
Can you please verify that it works for you?
Cheers
/Eike
> Chris
>>> explain.
>>> toplevelElement
>>> -subelement
>>> -subsubelement
>>> -subsubsubelement
>>> -subelement
>>> -subsubelement
>>> -subsubsubelement
>>> subsubelements.
>>> and so on.
>> Cheers
>> /Eike
Re: CDO Resources [message #590151 is a reply to message #45455] |
Thanx Chris
> Chris,
> Cheers
> /Eike
> Chris Lenz schrieb:
>> Hi eike,
>> name="test">
>> Thats the code?
>> try {
name="patch.txt"
ava,v
10:00:09 -0000 1.7
16:45:42 -0000
@@ -10,19 +10,36 @@
=20
=20
=20
oolean commit)
- dialog.create();
- dialog.open();
nchWindow();
- try
Editor.EDITOR_ID);
DO Editor for "
- + resourceInfo);
- return null;
- public void run()
- try
- viewer.refresh();
ropertySheetPage)
age;
- public void run()
- try
- page.refresh();
+ boolean commit) {
+ dialog.create();
+ dialog.open();
+ try {
+ return null;
+ try {
+ return;
+ try {
+ return;
+ return org;
+ int i =3D 1;
+ int old =3D 0;
+ while (old < i) {
+ old =3D i;
+ i =3D 0;
+ i++;
e
+ *=20
+ * @param newText
+ * @return String
+ return null;
+ } else
+ try {
+ viewer.refresh();
e;
+ try {
+ page.refresh();
a
Explorer.java,v
@@ -17,6 +17,7 @@
eAction;
@@ -51,6 +52,10 @@
=20
+ =20
+ =20
=20
=20
@@ -115,6 +120,8 @@
@@ -123,7 +130,7 @@
=20
+ public void run()
+ };=20
+ public void run()
+ };=20
=20
+ return null;
@@ -176,4 +218,4 @@
@@ -0,0 +1,4 @@
+=04=00;
@@ -0,0 +1,4 @@
+=04=00;
Re: CDO Resources [message #590278 is a reply to message #48451] |
Tue, 05 September 2006 12:23  |
Chris,
I'm currently working on this bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=156162
I can't open the import/export icons in your patch.
Can you please attach them directly to this newsgroup thread?
Cheers
/Eike
> Thanx Chris
Re: CDO Resources [message #590318 is a reply to message #48451] |
Chris,
Cheers
/Eike
> Thanx Chris
>> Chris,
>> Cheers
>> /Eike
>> Chris Lenz schrieb:
>>> Hi eike,
>>> name="test">
>>> Thats the code?
>>> try {
Re: CDO Resources [message #590363 is a reply to message #48780] |
Thu, 07 September 2006 04:32  |
> Chris,
> Cheers
> /Eike
>> Thanx Chris
i think you have solved this, was my patch useful
-> I like writing patches, currently I write a lot fo paches for ocl. :-)
Re: CDO Resources [message #590561 is a reply to message #48867] |
Hi Eike,
Chris
> Chris,
> needs.
> already
> Cheers
> /Eike
>> Thanx Chris
>>> Chris,
>>> Cheers
>>> /Eike
>>> Chris Lenz schrieb:
>>>> Hi eike,
>>>> name="test">
>>>> Thats the code?
>>>> try {
Current Time: Thu Jul 17 18:49:31 EDT 2025
Powered by FUDForum. Page generated in 0.10806 seconds
