Home » Eclipse Projects » Remote Application Platform (RAP) » LCA class for custom widgets - JSON?
LCA class for custom widgets - JSON? [message #45273] Tue, 04 September 2007 16:29 Go to next message
Originally posted by: giuliapo.gmail.com
Hi there.
As I have said here, I'm developing a custom widget. I have some doubts
regarding the LCA class and it's set method.
Well, it is something like this: I can pass a simple int from Java to
Javascript, strings, Integer objects, array of integer and even an array
of Object. My question is: why can't I pass some more complex object to
javascript? Example: if I try to pass an array of objects that has a
Point object in each position, nothing happens.
In other words: is RAP using JSON (for instance) to pass objects to
javascript? Or is RAP only wrapping simple objects like String, Integer,
Double...?
Because I think that I will have to do use the LCA class to pass a
string to javascript, but I will encapsulate my objects in a JSON
object, serializing them. On the javascript side, I will receive the
String and eval it.
What do you think? Is my approach correct or am Im repeating something
that RAP is already doing?
Hope you understood what I'm traying to explain.
Bruno.
Re: LCA class for custom widgets - JSON? [message #45559 is a reply to message #45273] Thu, 06 September 2007 15:38 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Hi Bruno,
it is a bit difficult to answer this without knowing much about your
use-case. Maybe you could provide some more concrete details about what
you would like to achieve.
The general idea behind RAP is to keep the JavaScript layer as thin and
'dumb' as possible. Following this rule, we haven't yet had the need to
exchange complex data structures. That said, it doesn't mean your
approach must be wrong - I just don't know much about it.
Please also see my comments blow.
Rüdiger
Bruno Vieira wrote:
> Hi there.
You are right, with the JSWriter you can only pass simple types from
Java to JavaScript. As we could also 'serialize' well-known types like
Point, there simple was no need to do so yet. With arbitrary Objects
there would the problem arise which fields or properties should be
'serialized' and then *how* should they be 'serialized'.
> Double...?
We decided against JSON as this approach wasn't flexible enough for our
needs.
RAP sends JavaScript 'static' function or 'method' calls to the client.
All these calls have simple types as their parameters or are
parameterless.
If you are using Firefox and have FireBug installed, take a look at the
'Response' in the console tab to get an idea how this looks like.
The whole response gets executed in a single windows.eval() call.
> String and eval it.
The LCA is the right place to mediate between client and server. The way
from server to client is handled in the renderXXX methods.
rednerInitialization() is called once in the life cycle of a widget
within the same request it was created. renderChanges is called with
every request. Finally, renderDipose is called with the request that
destroyed the widget by calling its dispose() method.
To read request parameters that carry the changes made on the client
side, the readData method comes into play.
> Best regards,
> Bruno.
Re: LCA class for custom widgets - JSON? [message #47795 is a reply to message #45559] Tue, 18 September 2007 21:42 Go to previous message
Originally posted by: just4lists.nospammail.net
Hi Rüdiger.
The use case is a custom widget for charts using the EJSChart
(http://www.ejschart.com/) javascript lib. Our idea would be to bind some
"simple" data structure (mainly chart properties and series data) to the
component.
> needs.
It would be possible to keep the actual approach. I believe (but could be
wrong) that using the JSON-lib (http://json-lib.sourceforge.net/) in the
"else" clause of the JSWriter would do the trick whithout breaking the
actual code and providing extended support (for free) for other data
structures (beans, maps, collections, java arrays and XML).
As RAP newbies, we loosed some time trying to understand where our data was
beeing "discarded" (not "translated" into the client side). I think this
could be a nice "feature" helping also future newbies and keeping expert
developers also away from the JSWriter.
Joel Oliveira
"Rüdiger Herrmann" <rherrmann@innoopract.com> escreveu na mensagem
news:fbpkvr$k77$1@build.eclipse.org...
> Hi Bruno,
> exchange complex data structures. That said, it doesn't mean your approach
> Cheers,
> Rüdiger
> Bruno Vieira wrote:
>> Hi there.
> You are right, with the JSWriter you can only pass simple types from Java
> to JavaScript. As we could also 'serialize' well-known types like Point,
> there simple was no need to do so yet. With arbitrary Objects there would
> the problem arise which fields or properties should be 'serialized' and
>> Double...?
> needs.
> parameterless.
>> Because I think that I will have to do use the LCA class to pass a string
>> to javascript, but I will encapsulate my objects in a JSON object,
>> serializing them. On the javascript side, I will receive the String and
>> eval it.
> rednerInitialization() is called once in the life cycle of a widget within
> the same request it was created. renderChanges is called with every
> request. Finally, renderDipose is called with the request that destroyed
> To read request parameters that carry the changes made on the client side,
>> Best regards,
>> Bruno.
Previous Topic:custom widget with external JS
Next Topic:cell editor
Current Time: Thu Jul 17 20:22:33 EDT 2025
Powered by FUDForum. Page generated in 0.07372 seconds
