Home » Eclipse Projects » Technology Project and PMC » cvs and Windows nt, 2000,XP,...
cvs and Windows nt, 2000,XP,... [message #45272] Mon, 10 February 2003 03:38 Go to next message
Originally posted by: mgareil.hotmail.com
one of the thread states that eclipse does not support cvsnt but only cvs on
linux / unix for <serious> users. Is it still true ? Do we have to setup a
linux / unix machine to gain cvs running properly with eclipse ?
Thanks in advance for your answer(s)
Re: cvs and Windows nt, 2000,XP,... [message #45345 is a reply to message #45272] Mon, 10 February 2003 11:33 Go to previous messageGo to next message
Originally posted by: dwhitema.us.ibm.com
ask on eclipse.tools
"Michel GAREIL" <mgareil@hotmail.com> wrote in message
news:b27mvj$i28$1@rogue.oti.com...
on
Re: cvs and Windows nt, 2000,XP,... [message #45429 is a reply to message #45272] Mon, 10 February 2003 14:12 Go to previous messageGo to next message
I've been working with cvsnt just fine.
Re: cvs and Windows nt, 2000,XP,... [message #45456 is a reply to message #45272] Mon, 10 February 2003 17:02 Go to previous messageGo to next message
Originally posted by: reachmike.hotpop.com
Michel GAREIL wrote:
I've been using cvsnt on W2K Server at my company for some time now and it
works very well. Haven't had a glitch. Eclipse also shows you how to
connect to it in its wonderful help file, complete with screen shots, so
you'll want to check that out too.
Re: cvs and Windows nt, 2000,XP,... [message #45642 is a reply to message #45345] Tue, 11 February 2003 07:28 Go to previous messageGo to next message
Thanks I retry on tools thread
"David Whiteman" <dwhitema@us.ibm.com> a
Re: cvs and Windows nt, 2000,XP,... [message #45674 is a reply to message #45429] Tue, 11 February 2003 07:29 Go to previous messageGo to next message
May I ask you wich version of cvsnt you are using ?
I tried the 1.11.3-66, 69 and 70 w/o any success.
many thanks
"Graham Perks" <graham_perks@bmc.com> a
Re: cvs and Windows nt, 2000,XP,... [message #45701 is a reply to message #45456] Tue, 11 February 2003 07:31 Go to previous messageGo to next message
Thanks for your advice.
I tried cvs on linux and it seems to work just fine. I only catched an error
when I tried on windows XP. May be I missed som point...
thanks again for your help
"Mike McKee" <reachmike@hotpop.com> a
Re: cvs and Windows nt, 2000,XP,... [message #53642 is a reply to message #45272] Wed, 07 May 2003 15:10 Go to previous messageGo to next message
Originally posted by: jens.ludwig.gmx.de
Hi Michel,
I've tried some versions. On my Eclipse 2.1 & Windows/XP System
the CVS-Version
1.11.1.1 (Build 27)
works just fine :-)
"Michel GAREIL" <mgareil@hotmail.com> schrieb im Newsbeitrag
on
Re: cvs and Windows nt, 2000,XP,... [message #57338 is a reply to message #53642] Sat, 30 August 2003 13:55 Go to previous messageGo to next message
Originally posted by: guann.bellsouth.net
Hi, Jens and all,
I am pretty new at the CVS stuff. : )
I've installed CVS NT (2.0.8), Eclipse 2.1 and WinCVS 1.3.13.2 Beta 13
(Build 2) on a XP Pro system.
WinCVS works fine.
I was able to use WinCVS to access the repostories created using CVSNT.
However, I can't make Eclipse to access those repostories when add a new
Repostory Location.
I've tried different parameters including different host name, repostory
path and connection type.
I've looked at different CVS and Eclipse documentations but was unable to
figure out the right combinations...
Could you please point me to the right direction?
Thank you in advance for your assistance.
Jeff
"Jens Ludwig" <jens.ludwig@gmx.de> wrote in message
news:b9bljr$lec$1@rogue.oti.com...
> Hi Michel,
> the CVS-Version
> 1.11.1.1 (Build 27)
> works just fine :-)
> > Hi,
cvs
> on
a
Re: cvs and Windows nt, 2000,XP,... [message #57364 is a reply to message #57338] Sat, 30 August 2003 13:59 Go to previous messageGo to next message
I am sorry, I missed the error messages:
"I/O" exception occurred: Connection refused: E:/myCVS/: no such
repository"
I checked E:/myCVS and it is there with CVSROOT folder in it...
Thanks for all your assistance.
Jeff
"Jeff" <guann@bellsouth.net> wrote in message
news:biqocp$8r8$1@eclipse.org...
> Hi, Jens and all,
> WinCVS works fine.
> Repostory Location.
> Jeff
> > Hi Michel,
> > the CVS-Version
> > 1.11.1.1 (Build 27)
> > works just fine :-)
> > > Hi,
> cvs
> > on
setup
> a
Re: cvs and Windows nt, 2000,XP,... [message #57443 is a reply to message #57364] Wed, 03 September 2003 23:11 Go to previous message
Hi, All,
After reading a few articles and help from the newsgroup, I realized that my
CVSNT setting was incorrect.
Eclipse 2.1 and 2.1.1 does not support "Repository Prefix."
Removing that option from the configurations, Eclipse works like a champ!
Thanks for everyone's help.
Jeff
news:biqokj$90i$1@eclipse.org...
> repository"
> Jeff
> > Hi, Jens and all,
> > WinCVS works fine.
> > Repostory Location.
to
> > Jeff
> > > Hi Michel,
> > > the CVS-Version
> > > 1.11.1.1 (Build 27)
> > > works just fine :-)
> > > > Hi,
only
> > cvs
> > > on
> setup
> > a
Re: cvs and Windows nt, 2000,XP,... [message #590040 is a reply to message #45272] Mon, 10 February 2003 11:33 Go to previous message
on
Re: cvs and Windows nt, 2000,XP,... [message #590069 is a reply to message #45272] Mon, 10 February 2003 14:12 Go to previous message
Re: cvs and Windows nt, 2000,XP,... [message #590076 is a reply to message #45272] Mon, 10 February 2003 17:02 Go to previous message
Re: cvs and Windows nt, 2000,XP,... [message #590138 is a reply to message #45345] Tue, 11 February 2003 07:28 Go to previous message
Re: cvs and Windows nt, 2000,XP,... [message #590152 is a reply to message #45429] Tue, 11 February 2003 07:29 Go to previous message
many thanks
Re: cvs and Windows nt, 2000,XP,... [message #590157 is a reply to message #45456] Tue, 11 February 2003 07:31 Go to previous message
Re: cvs and Windows nt, 2000,XP,... [message #593479 is a reply to message #45272] Wed, 07 May 2003 15:10 Go to previous message
Hi Michel,
the CVS-Version
1.11.1.1 (Build 27)
works just fine :-)
on
Re: cvs and Windows nt, 2000,XP,... [message #595028 is a reply to message #53642] Sat, 30 August 2003 13:55 Go to previous message
Hi, Jens and all,
WinCVS works fine.
Repostory Location.
Jeff
> Hi Michel,
> the CVS-Version
> 1.11.1.1 (Build 27)
> works just fine :-)
> > Hi,
cvs
> on
a
Re: cvs and Windows nt, 2000,XP,... [message #595036 is a reply to message #57338] Sat, 30 August 2003 13:59 Go to previous message
repository"
Jeff
> Hi, Jens and all,
> WinCVS works fine.
> Repostory Location.
> Jeff
> > Hi Michel,
> > the CVS-Version
> > 1.11.1.1 (Build 27)
> > works just fine :-)
> > > Hi,
> cvs
> > on
setup
> a
Re: cvs and Windows nt, 2000,XP,... [message #595075 is a reply to message #57364] Wed, 03 September 2003 23:11 Go to previous message
Hi, All,
Jeff
> repository"
> Jeff
> > Hi, Jens and all,
> > WinCVS works fine.
> > Repostory Location.
to
> > Jeff
> > > Hi Michel,
> > > the CVS-Version
> > > 1.11.1.1 (Build 27)
> > > works just fine :-)
> > > > Hi,
only
> > cvs
> > > on
> setup
> > a
Previous Topic:JBuilder to Eclipse Migration
Next Topic:compiling with jikes support?
Current Time: Thu Jul 17 09:35:49 EDT 2025
Powered by FUDForum. Page generated in 0.33935 seconds
