Home » Eclipse Projects » Nebula » GridViewer and multicolumn text
GridViewer and multicolumn text [message #45219] Thu, 03 January 2008 14:42 Go to next message
does the GridViewer support text spanning multiple columns. i understand
that i can achieve it using the Grid.
thanks.
Re: GridViewer and multicolumn text [message #45313 is a reply to message #45219] Fri, 04 January 2008 16:02 Go to previous messageGo to next message
See GridItem#setColumnSpan.
> thanks.
Re: GridViewer and multicolumn text [message #46046 is a reply to message #45313] Wed, 09 January 2008 13:59 Go to previous messageGo to next message
GridItem is part of Grid widget. i am trying to use GridViewer, is there a
way to achieve the similar effect using just the jface viewer classes?
thanks.
Re: GridViewer and multicolumn text [message #46075 is a reply to message #46046] Wed, 09 January 2008 14:02 Go to previous messageGo to next message
Hm you can get access to the GridItem in JFace when you overload
CellLabelProvider#updateCell(ViewerCell) you can access the item using
ViewerCell#getItem().
We could think about a dedicated GridViewerColumnLabelProvider to make
this more easy?
Tom
> a way to achieve the similar effect using just the jface viewer classes?
> thanks.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: GridViewer and multicolumn text [message #46104 is a reply to message #46075] Wed, 09 January 2008 14:16 Go to previous message
Sorry the method is named CellLabelProvider#update(ViewerCell).
Tom
Re: GridViewer and multicolumn text [message #587143 is a reply to message #45219] Fri, 04 January 2008 16:02 Go to previous message
> thanks.
Re: GridViewer and multicolumn text [message #587462 is a reply to message #45313] Wed, 09 January 2008 13:59 Go to previous message
thanks.
Re: GridViewer and multicolumn text [message #587475 is a reply to message #46046] Wed, 09 January 2008 14:02 Go to previous message
this more easy?
Tom
> thanks.
Re: GridViewer and multicolumn text [message #587486 is a reply to message #46075] Wed, 09 January 2008 14:16 Go to previous message
Tom
Previous Topic:[Grid] How to set RowHeaderWidth ?
Next Topic:Does setSelection(index) on a grid invoke the selectionListener attached to it?
Current Time: Thu Jul 17 01:41:37 EDT 2025
Powered by FUDForum. Page generated in 0.32259 seconds
