Home » Eclipse Projects » Technology Project and PMC » Can't get Eclipse 2.0.2 to run on RH 7.3
Can't get Eclipse 2.0.2 to run on RH 7.3 [message #45210] Sat, 08 February 2003 18:28 Go to next message
Originally posted by: rtanner.cheshire.cheshiresgrin.net
I have tried installing the binary dist and also downloading and building
from source, and I always get the same error at startup when I try to
invoke eclipse. From .metadata/.log:
java.lang.ExceptionInInitializerError:
java.lang.ClassCastException:
org.apache.xerces.parsers.StandardParserConfiguration
Is this a problem with the xerces.jar file in lib/ext in the JSDK, or is
this a problem with a file in the eclipse distribution? Also, I tried
with both the 1.3 and 1.4 versions of the Sun Java distro.
Any ideas what I need to fix?
Rob Tanner
Re: Can't get Eclipse 2.0.2 to run on RH 7.3 [message #45399 is a reply to message #45210] Mon, 10 February 2003 11:33 Go to previous message
Originally posted by: dwhitema.us.ibm.com
ask on eclipse.tools
"Rob Tanner" <rtanner@cheshire.cheshiresgrin.net> wrote in message
news:pan.2003.02.08.15.28.47.938911.11269@cheshire.cheshiresgrin.net...
> Rob Tanner
Re: Can't get Eclipse 2.0.2 to run on RH 7.3 [message #590062 is a reply to message #45210] Mon, 10 February 2003 11:33 Go to previous message
> Rob Tanner
Previous Topic:Navigator View not recognising file type
Next Topic:how to set up Eclipse & JBoss to hotswap
Current Time: Thu Jul 17 18:03:46 EDT 2025
Powered by FUDForum. Page generated in 0.06049 seconds
