Home » Eclipse Projects » Standard Widget Toolkit (SWT) » JUnit plug-in test question: No tests found
JUnit plug-in test question: No tests found [message #448310] Thu, 06 January 2005 15:55 Go to next message
When I try to run JUnit plugin tests in my
'application' plugin they run fine, but when I call
them under my 'core' plugin, I receive the following
error:
junit.framework.AssertionFailedError: No tests found
in com.sb.ide.core.SBProjectTest
I'm using the same method to execute both, select each
test class, then with the Run menu I select Run -> Run
As -> JUnit Plug-in Test
I definitely extended TestCase correctly, and I have
adhered to the right naming convention for tests so I
know the tests exist in the SBProjectTest class.
I'm not quite sure why this doesn't work, because when
I run tests in a different plugin they work fine. I
must be missing something obvious but I'm not sure
what it is.
thanks,
Ricardo Garcia
Re: JUnit plug-in test question: No tests found [message #448757 is a reply to message #448310] Thu, 13 January 2005 15:07 Go to previous message
Ricardo,
If you're still looking for this answer then you should ask your question in
the eclipse.tools.jdt newsgroup since that is where junit lives.
Grant
"Ricardo Garcia" <rickystreambase@yahoo.com> wrote in message
news:crk8kp$613$1@www.eclipse.org...
> error:
> what it is.
> thanks,
> Ricardo Garcia
Previous Topic:Tooltip for propertySheet entries
Next Topic:Tabs in FormEditor at top.
Current Time: Sat Jul 12 13:15:41 EDT 2025
Powered by FUDForum. Page generated in 0.04356 seconds
