CDateTime calendar visual suggestion [message #45158] |
Wed, 26 December 2007 11:15 |
Currently on the CDateTime, when one makes a selection in a manner that
does not perform a full-selection (with the arrow keys for example), and
then perform a click outside the calendar, the selection is not made. I
believe this is somewhat misleading behavior, as the selection appears to
be made.
I believe there should be a visual distinction between a full-selection
and a half-selection. This could be done, for example, with perhaps more
of a transparency on the half-selection, or an outline of the selection.
What do you think about this? Do you think the current behavior is
intuitive?
Thanks a lot for the great control otherwise! :]
David L.
FUDForum. Page generated in 0.03366 seconds
