Home » Eclipse Projects » Remote Application Platform (RAP) » custom widget with external JS
custom widget with external JS [message #45123] Tue, 04 September 2007 13:51 Go to next message
Originally posted by: andrew_james_macdonald.yahoo.com
I'm trying to build a custom widget which uses an external library
(mootools). I have some questions/problems and am hoping you can
provide me with some answers.
1) I notice in Firebug that my mootools.js file gets loaded after the
RAP page which contains my custom widget JS code. As my widget JS code
uses mootools classes, won't the mootools library need to be loaded
beforehand?
2) I realize this may be beyond the scope of this list, but the mootools
library seems to be interfering with the qooxdoo library, as when I
include it I get the following errors which prevent the RAP workbench
from loading:
this.$$method[$r] has no properties
qx.Class.define($[1604],{statics:{__checks:{"Boolean":$[1677], "String":$[1118],"...
rap (line 36)
this.setEnabled is not a function
qx.Class.define($[1584],{extend:qx.core.Target,construct:fun ction($0){arguments....
rap (line 105)
rap (line 36)
I've been looking at the Google Maps example, as it seems to avoid these
two problems, but am having little luck in gleaning any help from it.
Thanks in advance,
Andrew
Re: custom widget with external JS [message #45242 is a reply to message #45123] Tue, 04 September 2007 15:00 Go to previous messageGo to next message
Originally posted by: b.muskalla.gmx.net
Hi Andrew,
Andrew wrote:
> Hello,
> beforehand?
How did you register your mootools.js?
Time of downloading the stuff does not mean that it's really parsed in
that order. Do you encounter any problems in this area?
> from loading:
> rap (line 36)
> rap (line 105)
> rap (line 36)
I think this is caused by the namespaces both of the frameworks are
using. See "JS Libraries in RAP" in this newsgroup.
> Thanks in advance,
> Andrew
Greets
Benny
Re: custom widget with external JS [message #45304 is a reply to message #45242] Tue, 04 September 2007 17:24 Go to previous messageGo to next message
Benjamin Muskalla wrote:
> Hi Andrew,
> Andrew wrote:
>> Hello,
>> code uses mootools classes, won't the mootools library need to be
>> loaded beforehand?
I'm registering it by extending the
"org.eclipse.equinox.http.registry.resources" point. It seems like the
file is getting loaded properly. I can't tell if my widget can access
the mootools classes, since the mootools library stops RAP from loading
(probably due to the namespace conflict you pointed out below).
However, looking at the source code for the HTML page, I see that all
the qooxdoo and custom widget code is placed prior to the loading of
external JS libraries, so even if I could resolve the namespace issue,
it seems like the widget code wouldn't have access to the mootools
classes...
Thanks for the quick reply,
Andrew
>> mootools library seems to be interfering with the qooxdoo library, as
>> when I include it I get the following errors which prevent the RAP
>> workbench from loading:
>> rap (line 36)
>> rap (line 105)
>> rap (line 36)
>> these two problems, but am having little luck in gleaning any help
>> from it.
>> Thanks in advance,
>> Andrew
> Greets
> Benny
Re: custom widget with external JS [message #45422 is a reply to message #45304] Wed, 05 September 2007 10:35 Go to previous message
Originally posted by: fappel.innoopract.com
seems as if you are working against the M6 build. The loading order problem
is fixed in the meanwhile (the demo did not work either, sorry...). If you
switch to the latest I-Build or CVS the loading order should be correct.
Ciao
Frank
"Andrew" <andrew_james_macdonald@yahoo.com> schrieb im Newsbeitrag
news:fbkiek$8hc$1@build.eclipse.org...
>> Hi Andrew,
>> Andrew wrote:
>>> Hello,
>>> beforehand?
> file is getting loaded properly. I can't tell if my widget can access the
> (probably due to the namespace conflict you pointed out below). However,
> looking at the source code for the HTML page, I see that all the qooxdoo
> and custom widget code is placed prior to the loading of external JS
> libraries, so even if I could resolve the namespace issue, it seems like
> the widget code wouldn't have access to the mootools classes...
> Andrew
>>> from loading:
>>> rap (line 36)
>>> rap (line 105)
>>> rap (line 36)
>>> Thanks in advance,
>>> Andrew
>> Greets
>> Benny
Previous Topic:M6 blocking Dialog and Virtual table
Next Topic:LCA class for custom widgets - JSON?
Current Time: Fri Jul 25 02:35:18 EDT 2025
Powered by FUDForum. Page generated in 0.05754 seconds
