Home » Eclipse Projects » Standard Widget Toolkit (SWT) » A question about Menu
A question about Menu [message #447945] Tue, 21 December 2004 21:22 Go to next message
HI
Re: A question about Menu [message #447961 is a reply to message #447945] Wed, 22 December 2004 09:30 Go to previous messageGo to next message
Jesse, take a look at the link below, and if it does not help you then
you'll need to post a code snippet that shows your problem:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet97.java?rev=HEAD&a mp;content-type=text/vnd.viewcvs-markup
Grant
"Jesse" <denghaitao@jctx.com> wrote in message
news:cqalt0$rog$1@www.eclipse.org...
> HI
Re: A question about Menu [message #447995 is a reply to message #447961] Wed, 22 December 2004 21:42 Go to previous message
Originally posted by: hitdemo2002.yahoo.com.cn
are there some method to dynamicly refresh menus or reload menus in runtime
such as MenuManager's refreshxxx,reloadxxx?
> Grant
>> HI£¬Everyone
>> I have a question about loading the menu dynamic.I use a SWT Window to add
>> menu items and save them in database.And then I use MenuManager to add the
>> items which from database.But when I add a new item via SWT window,and
> save
>> in database, the menu does not add the new item ! That means,the menu can
>> not be added dynamic,How can I do?Does the Swt or Jface have any way to
>> resovle the question?
>> Thanks !
Previous Topic:Layout problem using CTabFolder in a form
Next Topic:Multiple lines of text in one tablecell?
Current Time: Sat Jul 12 00:59:13 EDT 2025
Powered by FUDForum. Page generated in 0.04050 seconds
