Home » Eclipse Projects » Standard Widget Toolkit (SWT) » AWT_SWT Adding Hidden Components
AWT_SWT Adding Hidden Components [message #447852] |
Sun, 19 December 2004 18:12 |
Originally posted by: still_aimless.wp.pl
I just stumbled upon a road block in my venture into SWT AWT land. The
application I'm working on requires that some of the Swing/AWT controls
(JButtons, etc) in the AWT panel have to be initially hidden and made
visible later at runtime. The problem is simple: I cannot unhide any of the
components, which were created and made invisible before the main window
was realized. I have tried everything from forcing repaint on individual
controls, invalidating areas, calling paint(..) directly, repainting the
AWT frame, repainting the SWT composite holding the frame ... nothing
worked. The controls are still not showing, even though they do have the
visible bit set to high. The only way to get them to show up is to manually
resize the window, in which they reside - obviously that's not a solution
I'm looking for.
What's interesting that after they are shown for the first time ( via the
window resize trick ) I can hide/show them at will, and from that point on
they behave as expected. It's only the first setVisible(..) call that
fails. Honestly it looks like SWT/AWT is not honoring the existance of
these components until a full flush of the window contents (like manual
resize).
I'm using JDK 5.0 and SWT 3.0 on Windows XP SP2. The AWT Frame has an AWT
Panel a child, which houses the controls that are initially hidden.
Example code.
The button at the bottom cycles the visibility of the center button,
however the first click, which should make the center button appear does
nothing. At this point if you resize the window, the center button will
appear as it should have instantly after the click event. Now, clicking the
bottom button cycles correctly the visibility state of the center button.
import org.eclipse.swt.layout.*;
import java.awt.BorderLayout;
import java.awt.Frame;
import java.awt.Panel;
import java.awt.event.*;
import javax.swing.JButton;
import org.eclipse.swt.SWT;
import org.eclipse.swt.awt.SWT_AWT;
import org.eclipse.swt.widgets.*;
class Snippet {
static boolean state = false;
final Display display = new Display();
final Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
Composite composite = new Composite(shell, SWT.EMBEDDED);
Frame frame = SWT_AWT.new_Frame(composite);
Panel panel = new Panel(new BorderLayout());
frame.add(panel);
final JButton invisibleButton = new JButton("I am invisible");
invisibleButton.setVisible(state);
panel.add(invisibleButton, BorderLayout.CENTER);
final JButton button = new JButton("Make my friend visible");
button.addActionListener(new ActionListener() {
public void actionPerformed(ActionEvent e) {
state = !state;
button.setText("Make my friend " + (state ?
"invisible" : "visible"));
panel.add(button, BorderLayout.SOUTH);
shell.open();
while(!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
- bartek
Re: AWT_SWT Adding Hidden Components [message #447877 is a reply to message #447852] |
Mon, 20 December 2004 18:33 |
Steve Northover Messages: 1636 Registered: July 2009 |
I believe that this has nothing to do with SWT. Here is your code hacked to
use AWT/Swing only. It seems to have the same problem.
class Snippet {
//Frame frame = SWT_AWT.new_Frame(composite);
Frame frame = new Frame();
frame.setVisible(true);
frame.add(panel);
state = !state;
+ (state ? "invisible" : "visible"));
shell.open();
while (!shell.isDisposed()) {
display.sleep();
display.dispose();
"Bartosz Frak" <still_aimless@wp.pl> wrote in message
news:Xns95C4C38116D4Bstillaimlesswppl@206.191.52.34...
the
manually
> I'm looking for.
> resize).
> Example code.
the
> class Snippet {
> public static void main(String[] args) {
> frame.add(panel);
> state = !state;
> shell.open();
> display.dispose();
> - bartek
Re: AWT_SWT Adding Hidden Components [message #447879 is a reply to message #447877] |
Mon, 20 December 2004 20:07 |
Jim Adams Messages: 160 Registered: July 2009 |
It should be noted that you can't really use Swing components without them
being in a JRootPane. The SWT_AWT frame returned is not a JRootPane. This
will cause you all sorts of refresh errors. Note that Javasoft did not
provide an implementation of JRootPane that you can derive from so you will
have to make your own. We have found that, once you parent from a
JRootPaneContainer that life is MUCH better. Maybe this is something that we
can get the SWT guys to provide? It really is not nice to have to re-invent
this wheel over and over...
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:cq75tg$p7c$1@www.eclipse.org...
to
> class Snippet {
> frame.add(panel);
> state = !state;
> shell.open();
> display.sleep();
> display.dispose();
> the
> manually
solution
> > I'm looking for.
the
on
> > resize).
AWT
> > Example code.
> the
button.
> > class Snippet {
> > frame.add(panel);
> > state = !state;
> > shell.open();
> > display.dispose();
> > - bartek
Re: AWT_SWT Adding Hidden Components [message #447896 is a reply to message #447879] |
Tue, 21 December 2004 16:00 |
Jim, is there a bug report that captures this?
"Jim Adams" <Jim.Adams@sas.com> wrote in message
news:cq7beh$bjs$1@www.eclipse.org...
will
we
re-invent
hacked
> to
> > class Snippet {
> > frame.add(panel);
> > state = !state;
> > shell.open();
> > display.sleep();
> > display.dispose();
controls
of
> > the
window
individual
the
the
> > manually
> solution
> > > I'm looking for.
> the
point
> on
manual
> > > resize).
> AWT
> > > Example code.
does
will
clicking
> > the
> button.
> > > class Snippet {
> > > frame.add(panel);
> > > state = !state;
> > > shell.open();
> > > display.dispose();
> > > - bartek
Current Time: Mon Apr 29 01:08:41 GMT 2024
Powered by FUDForum. Page generated in 0.04153 seconds
