Home » Eclipse Projects » Technology Project and PMC » Red Hat 8
Red Hat 8 [message #45074] Fri, 07 February 2003 14:35 Go to next message
Originally posted by: gbrethen.comcast.net
I can't seem to run eclipse on RH8. I downloaded and unzipped the
eclipse gtk to /opt/eclipse. I am using jdk1.3.1_07.
at the bash, using the command /opt/eclipse/eclipse -data
/home/gbrethen/workspace -ws gtk I receive the following error:
"error while loading shared libraries: libXm.so.2: cannot open shared
object file: No such file or directory"
can anyone help!
Re: Red Hat 8 [message #45121 is a reply to message #45074] Fri, 07 February 2003 14:55 Go to previous messageGo to next message
Originally posted by: jared-eclipse.mn.rr.com
You need to either add the Eclipse install dir to your LD_LIBRARY_PATH
("export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/eclipse/eclipse") or cd to
the Eclipse install dir when you launch.
Personally, I opt for the latter approach. I use a simple bash script that
cd's to the install dir and launches Eclipse with my preferred options.
- Jared
> can anyone help!
Re: Red Hat 8 [message #45152 is a reply to message #45121] Fri, 07 February 2003 15:34 Go to previous messageGo to next message
> - Jared
>>can anyone help!
ok, that seemed to work! Thank you.
Any way I can turn that command into an icon action?
Re: Red Hat 8 [message #45180 is a reply to message #45152] Fri, 07 February 2003 15:56 Go to previous message
Yep. It will vary by what desktop (Gnome, KDE, etc.) you use, but you can
either make an action that points to the Eclipse executable and includes
the arguments you need or you can point the action to your bash script.
The Eclipse install dir includes a file icon.xpm that works for shortcuts.
- Jared
Re: Red Hat 8 [message #589962 is a reply to message #45074] Fri, 07 February 2003 14:55 Go to previous message
- Jared
> can anyone help!
Re: Red Hat 8 [message #589972 is a reply to message #45121] Fri, 07 February 2003 15:34 Go to previous message
> - Jared
>>can anyone help!
Re: Red Hat 8 [message #589981 is a reply to message #45152] Fri, 07 February 2003 15:56 Go to previous message
- Jared
Previous Topic:Red Hat 8
Next Topic:Can't get Eclipse 2.0.2 to run on RH 7.3
Current Time: Sun Aug 31 16:08:21 EDT 2025
Powered by FUDForum. Page generated in 0.09116 seconds
