Home » Language IDEs » AspectJ » Visualizer
Visualizer [message #45047] Sun, 19 December 2004 18:04 Go to next message
Originally posted by: sekar.gopinathan.fhlbny.com
I am new to the aspect programming. I installed AJDT 1.2.200x into
eclipse 3.0.1 on my laptop and tried opening up TracingExample project.
Everything worked as expected. I enabled version 3 build configuration
and switched to AspectVisualizer perspective. Sure enough, I saw the
nice visual representation of how the aspect was applied.
Since in our company everthing is kept on the network. I did the same on a
network installation of eclipse(JRE(1.4.2) will be that of the local PC
starting eclipse). To my surprise, I could not see anything in the
visualizer except the message
"Nothing to display. Select a project, package, or class from the
Package explorer". I had selected "tracing" in my package explorer.
I am not sure if there are any known problems with visualizer running on
eclipse installed on a network file server. To make sure, its not some
wierd configuration issue, I installed a copy of eclipse in my laptop and
then in my network fileserver, followed by installation of AJDT. I could
recreate the problem.
If this is something anyone has come across or resolutions I appreciate if
you could share it with me.
Note: I changed the prefereces of visualizer to other 'providers' to 'file
based to provider' and i could see the graphics but when is switch it back
to 'AspectJ provider' I do not see anything.
Also I turned on the AJDT event trace and here is the event trace. I
could not make much out of it. Anyway, I hope some one would be able to
understand it.
6:02:34 PM initialiseAJDE: switching configs -
from:t:\users\gopishes\final\HelloWorld\.generated.lst
to:t:\users\gopishes\final\Tracing Example\.generated.lst
6:02:34 PM Wiping StructureModelUtil caches
6:02:34 PM AJDTContentProvider.updateData() executed - took 93ms
6:02:39 PM AJDTContentProvider.selectionChanged(): Marking visualiser
content as out of date
6:02:39 PM AJDTContentProvider.updateData() executed - took 0ms
6:02:41 PM AJDTContentProvider.selectionChanged(): Marking visualiser
6:02:41 PM AJDTContentProvider.updateData() executed - took 15ms
Sekar
Re: Visualizer [message #45608 is a reply to message #45047] Wed, 05 January 2005 12:14 Go to previous messageGo to next message
> nice visual representation of how the aspect was applied. Since in our
> company everthing is kept on the network. I did the same on a network
> installation of eclipse(JRE(1.4.2) will be that of the local PC starting
> eclipse). To my surprise, I could not see anything in the visualizer
> except the message
> Package explorer". I had selected "tracing" in my package explorer. I am
We've managed to recreate this here, by mapping the network share to a
local drive. I've raised bug 82258 for this, which we should be able to
fix within a couple of days.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=82258
Matt.
Re: Visualizer [message #45726 is a reply to message #45608] Fri, 07 January 2005 17:01 Go to previous messageGo to next message
I have the following project structure in my workspace
1. AuditPolicy
>> except the message
> Matt.
Re: Visualizer [message #45755 is a reply to message #45608] Fri, 07 January 2005 17:01 Go to previous messageGo to next message
1. AuditPolicy
>> except the message
> Matt.
Re: Visualizer [message #45785 is a reply to message #45608] Fri, 07 January 2005 17:01 Go to previous messageGo to next message
1. AuditPolicy
>> except the message
> Matt.
Re: Visualizer [message #45815 is a reply to message #45785] Fri, 07 January 2005 17:16 Go to previous message
I apolgize for the incomplete replies. I think it must be the case of
Friday...;)
Anyway...I have the following project structure in my workspace(that is
setup on the network)
1. AuditPolicy: This is an aspect only project. Basically it has
pointcuts and advices that would insert an audit call.
2. XXXService: This project is a service layer and is also an aspectj
project but it does not define any aspects by itself. It simply uses the
aspects defined int the auditpolicy.jar
3. XXXDataAccess: This project contains all the DAO's
The service project references the data access project. When I change
the method signature on one data access component that is used by service
project, it is supposed to complain in the service project. But it does
not complain untill I clean all the projects. Can this be related to me
working on the network? May be this is totally unrelated issue. If so,
I can post it separately.
SG
> 1. AuditPolicy
>>> except the message
>> Regards,
>> Matt.
Re: Visualizer [message #585584 is a reply to message #45047] Wed, 05 January 2005 12:14 Go to previous message
> except the message
Matt.
Re: Visualizer [message #585640 is a reply to message #45608] Fri, 07 January 2005 17:01 Go to previous message
1. AuditPolicy
>> except the message
> Matt.
Re: Visualizer [message #585652 is a reply to message #45608] Fri, 07 January 2005 17:01 Go to previous message
1. AuditPolicy
>> except the message
> Matt.
Re: Visualizer [message #585665 is a reply to message #45608] Fri, 07 January 2005 17:01 Go to previous message
1. AuditPolicy
>> except the message
> Matt.
Re: Visualizer [message #585679 is a reply to message #45785] Fri, 07 January 2005 17:16 Go to previous message
Friday...;)
SG
> 1. AuditPolicy
>>> except the message
>> Regards,
>> Matt.
Previous Topic:Lastest AJDT with older versions of AspectJ?
Next Topic:Stable release of AJDT and AspectJ
Current Time: Mon Sep 01 02:41:30 EDT 2025
Powered by FUDForum. Page generated in 0.07285 seconds
