Home » Archived » M2M (model-to-model transformation) » [ATL] New ATL use case: QVT to ATL Virtual Machine Compiler
[ATL] New ATL use case: QVT to ATL Virtual Machine Compiler [message #44996] Thu, 07 June 2007 05:06
Dear all,
A new ATL use case is available: QVT to ATL Virtual Machine Compiler
This work provides a QVT compiler that targets the ATL Virtual Machine
(ATL VM), and thus provides executability of QVT programs on top of the
ATL VM. The code generator is written in the ACG (Atl Code Generation)
Domain-Specific Language (DSL). It takes as input a QVT model (typically
in XMI format) that may have been created by a QVT front-end (i.e., a
parser and type checker) like Eclipse/modeling/m2m/Procedural QVT, or
SmartQVT. The output of the code generator is a ".asm" file similar to
the ones generated by the ATL compiler, or the ACG compiler (both also
written in ACG).
The use case is available at:
http://www.eclipse.org/m2m/atl/usecases/QVT2ATLVM/
Frédéric Jouault
Previous Topic:[ATL] Using EMF for translation
Next Topic:[ATL] Problems to reference a non-default target pattern of a matched rule
Current Time: Mon Sep 01 05:19:35 EDT 2025
Powered by FUDForum. Page generated in 0.15477 seconds
